Aftershock or XXL
NC
RE: Aftershock or XXL
well the steering has dual servos and will not work with one servo and you should not mix them both servos should be the same as they work on a y splitter which means that one signal goes to both servos at the same time if you have one fast / strong and one slow / weak one will be dragging the other down and will probably act screwy at best
NC
after you get them installed put one of the the old servos on the throttle/brake for better braking and throttle pull ...by the way what servos are you getting
They won't fit the truck, they're too big. Try these:
http://www.overdriverc.com/proddetai...C37955S&cat=26
333 oz/in @ 6.0V
333 oz/in @ 6.0V
ORIGINAL: thepope43
Is there anything wrong with buying two of those servos?
#35
ON, CANADA
You can Run Hitec's you just need the MGT Hitec Servo Savers (Use the Tops from the Stockers), http://www.losipartshouse.com/servle...ec-cln-/Detail
LST Servo Upgrades-Modding the steering servos
