ugly but cheap... and it works    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> ugly but cheap... and it works Page: [1]
Login
ugly but cheap... and it works - 9/15/2010 6:58 AM
rangerfredbob
Score: 115
Last Login: 5/23/2013
Status: offline
Got the hull at a swap meet for $20, traded a converted 21cc weedeater engine for the 4 stroke (I think it's a 27cc) that I put on it, since the engine had a crankcase it's not the best airplane candidate so I figured this was the best option... the pictures show it before I lowered the engine 1.5", the COG was too high with that large prop and it didn't spin it very fast so I stuck a 15x8 prop on it and it's now getting the rpm it's supposed to turn. I don't know how fast it is but it's good enough for now... have $45 in the radio, $20 in the hull and the rest is pretty much just time...
the pull starter is pretty handy... starts the engine on the first pull almost every time.
Hide Signatures
       Post #: 1
RE: ugly but cheap... and it works - 9/15/2010 10:03 AM
Mr Cajun Gator
Score: 100
Last Login: 9/25/2012
Status: offline
Save some money and take some time to build a stronger engine mount.
_____________________________
Catch a Gator by the Tail and hang on for the Ride!
Cajun Gator Airboats, M.AB.A
Hide Signatures
(in reply to rangerfredbob)
       Post #: 2
RE: ugly but cheap... and it works - 9/15/2010 6:09 PM
rangerfredbob
Score: 115
Status: offline
it looks better with the engine lower, and is stronger than it looks for that wimpy little weedie motor, entering the rpm figures in a thrust calculator it's like .6hp and 6 pounds of thrust...
Hide Signatures
(in reply to Mr Cajun Gator)
       Post #: 3
RE: ugly but cheap... and it works - 9/15/2010 8:16 PM
crispyspa
Score: 137
Status: offline
It's so ugly I threw up a little. LOL Just kidding. I absolutely love the pull start! Very ingenious! I think you've solved an age old problem.
After all is said and done, more is said than done.
Hide Signatures
       Post #: 4
RE: ugly but cheap... and it works - 9/16/2010 7:16 AM
rangerfredbob
Score: 115
Status: offline
yeah, the pull start is very handy, I know how hard it is to hand prop a magneto engine and that I would eventually get a prop cage for this thing so it needed an easy to transport starting system, saw someone on youtube years ago that had a much more complex setup that was somewhat similar and simplified it. The guy I got the idea from used a standard starter cone, some dowel running through the middle of the handle and was just too complicated and I don't like spinners so I came up with this idea.
Hide Signatures
(in reply to crispyspa)
       Post #: 5
RE: ugly but cheap... and it works - 9/16/2010 9:41 AM
spede18
Score: 100
Last Login: 5/21/2013
Status: offline
When you gonna have soe video of this thing running?
Put a "WRAP" on it vinyl and graphics are my specialty!
Contact me in you are in need of any and all decals or letteri
Hide Signatures
       Post #: 6
RE: ugly but cheap... and it works - 9/16/2010 10:16 AM
rangerfredbob
Score: 115
Status: offline
when the rain stops my pond will have more water, I'll try to get video then. my pond is really small, but enough to run it around a bit
forgot to share the materials of this thing, it's solid blue foam with plywood skinned sides, bottom and top wrapped with what looks like cotton covered with epoxy... has a fin on the bottom which I'll probably shave off soon...
Hide Signatures
(in reply to spede18)
       Post #: 7
RE: ugly but cheap... and it works - 9/17/2010 8:02 AM
rangerfredbob
Score: 115
Status: offline
finally got some vids of the boat in action:
at the end of the second video you can see it flop... it was fine afterwards, only problem is the top plywood sheet is unglued from the foam again... I'll have to figure out a better solution for that issue... I have some ideas.
this thing doesn't use any fuel... I think I've put about an hour on it and have gone through about a tank...
Hide Signatures
       Post #: 8
RE: ugly but cheap... and it works - 9/17/2010 9:14 PM
crispyspa
Score: 137
Status: offline
Is that full throttle? You seem to be a tad overpropped if it is. Sounds like it's running in the 5000RPM range, you should be up around high 9's. Looks like it handles pretty good though....except for the "incident" at the end. LOL
Hide Signatures
       Post #: 9
RE: ugly but cheap... and it works - 9/18/2010 12:08 AM
rangerfredbob
Score: 115
Status: offline
it's a 4 stroke so it sounds different, and it's actually spinning at 6400rpm at full throttle which should be about right, I might drop the pitch down a little and try that sometime but it goes pretty well as is. It's not the sturdiest engine, the connecting rod is spot welded steel...
Hide Signatures
       Post #: 10
RE: ugly but cheap... and it works - 9/26/2010 10:29 PM
rangerfredbob
Score: 115
Status: offline
about the full throttle thing, no, that was about 3/4 which is about what my little tiny pond can handle. And I agree with the engine mount, my steel strap isn't sufficient, it's broken twice now even with heating it to relieve stress...
it flips WAY too much, this time it broke the glue seam on the vertical stab, gorilla glue to the rescue . seriously though, I'm going to lower the engine some more and put a 14" prop on in place of that 15". I'll get some new pics once I lower the engine more. I'm going to have to run some long bolts through the hull, the top plywood plate delaminated from the foam. I'm thinking recessed T nuts on bottom with the rod JB welded in then nuts on top.
would adding some material to the side of the hull that is angled so it can slide easier help? I think it's just catching the back corners and flopping it.
Hide Signatures
       Post #: 11
RE: ugly but cheap... and it works - 10/2/2010 11:21 AM
rangerfredbob
Score: 115
Status: offline
boat is torn apart in several pieces. I trimmed the front of the mount to lower the engine 5/8" for now, might go further... but that's how much room I had between the current prop and hull. the gorilla glue on the rudder is drying, I'll add a couple supports to it so that it doesn't break as easy in further flips.
it'll also get a few other tweaks while it's apart, radio box is getting set into the hull to clear the gas tank, crank vent moved from air filter housing to a pill bottle or something to help keep the water out of the oil... and make a remote oil drain. I don't think I'll change to a 14" prop, it does pretty well with this one, I need to lean it out a bit and it'll pick up a little rpm and hopefully throttle response. It'll also get some fresh paint on the thing so it's not quite so ugly...
anyone have any thought about adding some angled pieces to the side so it'll slide over the water easier instead of catching the corners?
Hide Signatures
       Post #: 12
RE: ugly but cheap... and it works - 10/2/2010 6:57 PM
1QwkSport2.5r
Score: 155
Last Login: 5/25/2013
Status: online
quote:
ORIGINAL: rangerfredbob
boat is torn apart in several pieces. I trimmed the front of the mount to lower the engine 5/8'' for now, might go further... but that's how much room I had between the current prop and hull. the gorilla glue on the rudder is drying, I'll add a couple supports to it so that it doesn't break as easy in further flips.
it'll also get a few other tweaks while it's apart, radio box is getting set into the hull to clear the gas tank, crank vent moved from air filter housing to a pill bottle or something to help keep the water out of the oil... and make a remote oil drain. I don't think I'll change to a 14'' prop, it does pretty well with this one, I need to lean it out a bit and it'll pick up a little rpm and hopefully throttle response. It'll also get some fresh paint on the thing so it's not quite so ugly...
The sides of the boat need a little rake so it'll just slide.. Take a look at my airboat and notice the sides have a shallow angle - it slides pretty nice at speed and doesnt want to flip much, either.
http://www.rcuniverse.com/forum/m_10032160/tm.htm
If your boat looks like a river barge, its going to handle like one. A better choice may be to make an entirely new hull and use the right adhesives to hold the skin onto the foam, and also will allow you to build a better engine stand. You could easily make one from thin plywood - 2 layers of 1/4" 5 ply would work plenty fine.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 13
RE: ugly but cheap... and it works - 10/2/2010 8:37 PM
rangerfredbob
Score: 115
Status: offline
the problem with mounting this engine, is there isn't really a good way to do it and still get to the dip stick which is why I used the plywood and that strap, which I think I'm going to redo with a different material that's more hearty... I have some 1/8" aluminum sheet, now I just need a blade for my band saw.
I think I'm going to pick up some blue foam to add to the sides of this thing. flat sides are fine for going straight but not for hiarpin turns
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 14
RE: ugly but cheap... and it works - 10/3/2010 1:57 AM
1QwkSport2.5r
Score: 155
Status: online
the problem with mounting this engine, is there isn't really a good way to do it and still get to the dip stick which is why I used the plywood and that strap, which I think I'm going to redo with a different material that's more hearty... I have some 1/8'' aluminum sheet, now I just need a blade for my band saw.
You should get the right prop on the engine before re-building the engine stand. This way if you can run a smaller length prop, you can drop the engine that much further.
Hide Signatures
       Post #: 15
RE: ugly but cheap... and it works - 10/3/2010 6:39 AM
rangerfredbob
Score: 115
Status: offline
The way I'm modifying things it'll be easier to lower the engine in the future if needed. The engine runs good with the prop it has if it just didn't flip over I'd be happy and it seems to be more of a hull shape issue than COG at this point, if the sides were angled I think it would skip better. I'm not really rebuilding the engine mount as much as I'm just taking out a couple of the hack things I did last time, making it look cleaner, including paint.
Hide Signatures
       Post #: 16
RE: ugly but cheap... and it works - 10/5/2010 5:03 AM
DONS BOAT WORKS
Score: 100
Last Login: 5/20/2013
Status: offline
Ugly but cheap, sounds like my ex.
Over the years I have spent nearly all of my money on boats, beer, and women. The rest of it I just wasted.
Hide Signatures
       Post #: 17
RE: ugly but cheap... and it works - 10/5/2010 11:16 AM
jg2009
Score: 100
Last Login: 7/20/2012
Status: offline
quote:
ORIGINAL: DONS BOAT WORKS
Lol, Mine too
The only reason I go to work is to pay for my R/C habit.
Hide Signatures
(in reply to DONS BOAT WORKS)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
