seagull edge 540 servos    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Beginners >> seagull edge 540 servos
Page: [1]
Login
seagull edge 540 servos - 9/16/2010 5:47 PM
bbrown2828
Score: 150
Last Login: 5/3/2013
Status: offline
ok well i have been runing nitro on my edge 540 now i am going to go to the dle 20cc for a power house i was wondering if i would need to change my servos out to metal gear servos right now i have 3310 on alerions and elevator and then a metal gear 3305 on rudder
Hide Signatures
       Post #: 1
RE: seagull edge 540 servos - 9/16/2010 5:52 PM
bbrown2828
Score: 150
Status: offline
futaba 3010 no 3310
Hide Signatures
(in reply to bbrown2828)
       Post #: 2
RE: seagull edge 540 servos - 9/16/2010 7:07 PM
bigedmustafa
Score: 134
Last Login: 5/16/2013
Status: online
If your existing servos have been working well previously, you won't need to change them.
_____________________________
To a tree, balsa wood and MonoKote taste just like chicken!
Hide Signatures
       Post #: 3
RE: seagull edge 540 servos - 9/16/2010 11:34 PM
bbrown2828
Score: 150
Status: offline
my question is that the 3010 do not have metal gears they are nylon will they hold up to the gas vibration
Hide Signatures
(in reply to bigedmustafa)
       Post #: 4
RE: seagull edge 540 servos - 9/17/2010 12:59 AM
opjose
Score: 280
Last Login: 5/22/2013
Status: offline
Actually Nylon geared servos do BETTER under vibration because they "give" a bit without damage.
Conversely metal gear servos wear more under vibration.
However even a grossly out of balance system is not likely to cause problems with either, as long as the engine is not in direct contact with a servo rod/horn, etc...
If you are talking about say a throttle servo, things may be a bit different, and you may want to make sure that the throttle servo can "give" a bit to deal with vibration.
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 5
RE: seagull edge 540 servos - 9/17/2010 1:04 AM
RCKen
Score: 411
Status: online
quote:
ORIGINAL: opjose
To add a little to what OPJose has said. The throttle servo will actually have a little extra dampening from vibration because you need to use nylon pushrods with a gasser, and not metal pushrods. Metal pushrods on the throttle servo on a gasser can cause interference from the ignition system to be transferred back to the radio system which can cause a lose of the plane.
As to your original question, your original servos will do just fine with the new gas engine in the plane.
Ken
The take off is optional, but the landing is MANDATORY!!
RCU Forum Manager
Ultra Sport Brother #1
www.gettingairborne.com
Hide Signatures
(in reply to opjose)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
