New Jato 3.3 BUT what motor should I get ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> New Jato 3.3 BUT what motor should I get ?
Page: [1]
Login
New Jato 3.3 BUT what motor should I get ? - 9/19/2010 5:28 AM
PeeBeMe
Last Login: 3/18/2012
Status: offline
Hi guys, My jato will be here on monday ! My jato is going to be used only for street racing, so what motor should I get ?
I hear that the o.s 18 & o.s 21 motors are good for the jato & they are straight drop ins ! I wanna go a little bit faster then 65mph guys so help me out.. I want more like 70 to 80 mph if I can ?
_____________________________
Oh I love my Savage !
Hide Signatures
       Post #: 1
RE: New Jato 3.3 BUT what motor should I get ? - 9/20/2010 7:04 AM
quietnas1
Last Login: 3/15/2013
Status: offline
It takes alot more than just dropping in an engine. I have the OS .21 TM in mines. But you also have to look at intake, exhaust, gearing, and weight reduction to obtain those kinds of speeds.
A wise man can play the role of a fool. But a fool can never play the role of a wise man...... This is so true.
Hide Signatures
(in reply to PeeBeMe)
       Post #: 2
RE: New Jato 3.3 BUT what motor should I get ? - 9/21/2010 5:48 AM
PeeBeMe
Status: offline
so please can you help me out then. whats a good setup & how fast does your jato go !
Hide Signatures
(in reply to quietnas1)
       Post #: 3
RE: New Jato 3.3 BUT what motor should I get ? - 9/21/2010 7:21 PM
quietnas1
Status: offline
I really cant say how fast it is for sure. It did clock 68 when I had my steel spur which I threw away and went back to stock gears cuz it killed my clutch bell. I verified it using the GPS on my phone (a G1) but I dont know how accurate it was. Being that I recently got beat by a Menace I'm gonne start messing with gearing again. Well here is my set up.
1) OS .21TM
2) MotorSaver Air Filter
3) RS4 2 Header
4) Buku Power Muffler (And man is it sick on the this motor)
5) Futaba Servos
6) Novak Receiver
7) RPM Front Bumper
8) RPM A Arms all the way around
9) Center Mounted Battery Pack
10) Integy Steel Spur (GOT RID OF IT)
11) GH Racing Aluminum Brake Arms
12) Hot Racing Dual Steel Brakes
13) Jaco Foam Tires (for the street)
14) Pro-Line Racing 30 series Badlands tires (for off road)
15) Dubrough Fuel Filter (dont know if I spelled that right)
Hide Signatures
       Post #: 4
RE: New Jato 3.3 BUT what motor should I get ? - 9/21/2010 8:58 PM
quietnas1
Status: offline
OS motors that will fit. .18TM, .21TM. These 2 accept the easy start if you want to use them. The .18TZ is one sick puppy also. That will pretty much drop in as well. You can also drop in the RB 523TM which is a .23 motor or the .26 PICCO MAX EZ START. All these motors are direct replacement drop ins and also accept the EZ- START, but dont need it.
Hide Signatures
       Post #: 5
RE: New Jato 3.3 BUT what motor should I get ? - 9/22/2010 10:26 PM
Darius69
Last Login: 9/23/2010
Status: offline
Honestly I have a jato with the 3.3 and had it radared at 78 mph before I supercharged it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 6
RE: New Jato 3.3 BUT what motor should I get ? - 9/23/2010 7:01 AM
joeseif
Last Login: 10/16/2012
Status: offline
How much will a full rollcage slow it down?
Hide Signatures
(in reply to Darius69)
       Post #: 7
RE: New Jato 3.3 BUT what motor should I get ? - 9/24/2010 5:33 PM
joeseif
Status: offline
quote:
ORIGINAL: Darius69
No it doesn't and no you didn't.
Hide Signatures
       Post #: 8
RE: New Jato 3.3 BUT what motor should I get ? - 9/26/2010 9:46 PM
1QwkSport2.5r
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: joeseif
quote:
ORIGINAL: Darius69
I recently acquired a Jato 2.5 and Rustler 2.5 both rollers (junk engines) and in the box of spare parts... I find a RB Innov. supercharger. I know for a fact they do nothing for a 2-cycle engine, and to cure my own curiosity, I took the supercharger apart. I laugh at every person that says a supercharger works on a 2-stroke nitro engine.. I laughed harder when I saw what was inside this thing. I don't have all of the intake tubes for it, but I don't care. I will never use it because its a proven fact they don't work. I may put it up for sale on E-bay - some poor idiot will buy it and use it.
For those that want to argue that they work: The way super/turbochargers work is by pressurizing the incoming air/fuel mixture and forcing more of it into the combustion chamber. The only way to achieve this is by sealing the Exhaust port on the intake stroke (ie: an exhaust valve). Not possible on a 2-stroke nitro engine.
I saw a nitro rustler with a 3.3 engine clocked at 76MPH on a radar gun, and it did NOT have a supercharger, either.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to joeseif)
       Post #: 9
RE: New Jato 3.3 BUT what motor should I get ? - 9/27/2010 12:29 AM
yakfish
Status: offline
quote:
ORIGINAL: Darius69
LOL
Hide Signatures
       Post #: 10
RE: New Jato 3.3 BUT what motor should I get ? - 9/27/2010 12:48 AM
Uncle Vinnie
Last Login: 12/16/2012
Status: offline
Honestly Darius69 get it together....if your going to post crap don't post at all.
If your going to make up crap as you go.....make sure you get it together......
On the subject "93.1 MPH jato. Anyone have any info" you posted on Sept/24, 2010 at 7:24 you had a Jato that does 98MPH
On this subject "New Jato 3.3 what motor should I get" on the same day at 7:26 you said you had a Jato that does 78mph before supercharged.
I personally don't even think you have a Jato never mind those crazy speeds...plus a 20MPH increase with a supercharger that don't even work with a 2 stroke engine and everyone knows that.
Please get it together and stop posting crap.
< Message edited by Uncle Vinnie -- 9/27/2010 1:22 AM >
Hide Signatures
(in reply to yakfish)
       Post #: 11
RE: New Jato 3.3 BUT what motor should I get ? - 9/27/2010 3:32 AM
1QwkSport2.5r
Status: offline
quote:
ORIGINAL: Uncle Vinnie
On the subject ''93.1 MPH jato. Anyone have any info'' you posted on Sept/24, 2010 at 7:24 you had a Jato that does 98MPH
On this subject ''New Jato 3.3 what motor should I get'' on the same day at 7:26 you said you had a Jato that does 78mph before supercharged.
Hey! On the bright side, it gave me a good laugh for a minute or two! LoL... Sshhhh.. don't tell anyone, but I have a LST2 with a Mach 427 that'll do 65mph.. NOT.. lol.. more like 45.. (on a good day)
Hide Signatures
(in reply to Uncle Vinnie)
       Post #: 12
RE: New Jato 3.3 BUT what motor should I get ? - 10/19/2010 12:57 AM
cbeck611
Last Login: 11/15/2010
Status: offline
i have a os 21tm with jaco tires does your jato hook up cause mine dont i have both the soft and hard jaco tires and im sliding all up and down the road
quote:
ORIGINAL: quietnas1
1) OS .21TM
3) RS4 2 Header
5) Futaba Servos
6) Novak Receiver
7) RPM Front Bumper
Hide Signatures
       Post #: 13
RE: New Jato 3.3 BUT what motor should I get ? - 10/19/2010 1:01 AM
cbeck611
Status: offline
quote:
ORIGINAL: Darius69
first of all your full of **** just about everybody on this forum owns a jato your not fooling anybody and second dont get a supercharger for your nitro engine it will destroy it fast and it doesnt make it that much faster you can get more speed from switching your gears then using a supercharger
Hide Signatures
       Post #: 14
RE: New Jato 3.3 BUT what motor should I get ? - 10/19/2010 1:09 AM
cbeck611
Status: offline
i would go with the os 21tm i just got my broken in today and its alot faster then the 3.3 os engines are very reliable and the 21tm is easy to tune but the only problem is traction i tried 3 different tires and none of them hook up the 21tm has too much power just use stock anaconda tires and revo gears 20T clutch bell and 36T spur gear those gears made my jato have alot more top end
Hide Signatures
       Post #: 15
RE: New Jato 3.3 BUT what motor should I get ? - 10/19/2010 8:43 AM
quietnas1
Status: offline
My Jaco Foams hook up great. Ask joeseif he has seen my Jato in action. One thing I have noticed. If you run on asphalt or cement they hook up amazingly well. If you run in a parking lot with a fresh black top you will be slipping and sliding all over the place.
Hide Signatures
(in reply to cbeck611)
       Post #: 16
RE: New Jato 3.3 BUT what motor should I get ? - 10/20/2010 1:01 AM
cbeck611
Status: offline
quote:
ORIGINAL: quietnas1
i have jaco foam tires i have the soft and hard ones and they both dont hook up for me on my road or drive way when i floor it the car spins around and slides
Hide Signatures
       Post #: 17
RE: New Jato 3.3 BUT what motor should I get ? - 10/20/2010 1:28 AM
quix
Last Login: 12/13/2010
Status: offline
Just change your gearing first. If you're not satisfied, drop a .28 in there. You'll be flying. Good luck with the tranny though.
Hide Signatures
       Post #: 18
RE: New Jato 3.3 BUT what motor should I get ? - 10/20/2010 6:43 AM
quietnas1
Status: offline
quote:
ORIGINAL: cbeck611
quote:
ORIGINAL: quietnas1
Man dont know what to tell you. Mines hook up great. Can you post a video?
Hide Signatures
       Post #: 19
RE: New Jato 3.3 BUT what motor should I get ? - 10/20/2010 7:47 AM
cbeck611
Status: offline
quote:
ORIGINAL: quietnas1
quote:
ORIGINAL: cbeck611
quote:
ORIGINAL: quietnas1
yea im going to make a video soon and put it up on youtube then ill post the link on here
Hide Signatures
       Post #: 20
RE: New Jato 3.3 BUT what motor should I get ? - 10/20/2010 8:14 AM
pimpala50
Last Login: 5/17/2013
Status: offline
hey fellaz which jaco foams for the jato is there a part num???
Hide Signatures
       Post #: 21
RE: New Jato 3.3 BUT what motor should I get ? - 10/20/2010 9:16 PM
cbeck611
Status: offline
quote:
ORIGINAL: pimpala50
go to amainhobbies.com on the search bar in the left side of the page type jaco foam tires or heres a link
https://www.amainhobbies.com/advanced_search_result.php?keywords=jaco+foam+tires&x=7&y=9
Hide Signatures
(in reply to pimpala50)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
