RE: C-ARF Ultra Flash build Thread + Video    Gallery
Logged in as Guest
Users viewing this topic: P Arias, rcand, SMBJets
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: C-ARF Ultra Flash build Thread + Video
Page: <<   < prev  50 51 [52] 53 54 55 56 57 58 59   next >   >>
Login
RE: C-ARF Ultra Flash build Thread + Video - 12/26/2011 11:39 PM
mtnflyer14
Score: 100
Last Login: 5/21/2013
Status: online
Dave,
Thanks, and Merry Christmas to you and your family! I may try filling the wing tank first, then fuselage, or-just keep doing what I'm doing and be careful! Have a great 2012.
Regards,
Gus
_____________________________
AW Extra 260/ZDZ Super 80; Elan/K-80; C-ARF Ultra Flash/P-120; YA F-15C/K-140
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 1276
RE: C-ARF Ultra Flash build Thread + Video - 12/27/2011 1:04 AM
wojtek
Score: 110
Status: offline
quote:
ORIGINAL: Ali
Jose.
I find that reducing the amount of flap used for landing and compensating it some crow ( Both ailerons up 4-6mm) improved the way the model landed for me. I found that with too much flap it was quite easy to misjudge the power required to '' balance' the model in the landing configuration. The crow set up keeps the drag required as well as changing the angle of attack.
Regards Al
Hi Ali,
so how much flap do you use with the 6mm crow ?
Voy
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to Ali)
       Post #: 1277
RE: C-ARF Ultra Flash build Thread + Video - 12/27/2011 3:05 AM
quist
Score: 116
Status: offline
I am using 3 3/4" flap with 1/4" of crow (measured from the outer edge). Cg 225. This requires lots of down elevator, about 1/2" at the root.
I only have 9 flights so I am still tweaking throws, but this feels good.
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
(in reply to wojtek)
       Post #: 1278
RE: C-ARF Ultra Flash build Thread + Video - 12/27/2011 10:47 AM
Robrow
Score: 100
Status: offline
What is the consensus on the use of crow with the UF? Is it needed, does it make life easier if used? I have seen it used with great success on a SF giving a slight nose up attitude when landing and very consistent.
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
(in reply to quist)
       Post #: 1279
RE: C-ARF Ultra Flash build Thread + Video - 12/27/2011 12:50 PM
ricardinho
Score: 100
Last Login: 5/20/2013
Status: offline
I have about 50 or so flights on my ultra and and I must say its a a great sport jet...best I have flown and most forgiving...the bird is very slick so it loves lots of flaps..I think I have 4 inch ....the more the marrier. I have takeoff flaps at about 10 degrees and full flap for landing...I like setting full flap on downwind and slow fly and drag it in on final...seems to slow down best that way....
Hide Signatures
(in reply to Robrow)
       Post #: 1280
RE: C-ARF Ultra Flash build Thread + Video - 12/27/2011 1:32 PM
jampl
Score: 100
Status: offline
quote:
ORIGINAL: KC36330
quote:
ORIGINAL: jampl
....How fast you do the approach and how far from the runway do you chop the throttle?
i pull most of the power out on a turn to upwind (this bleeds speed quick), then drop the gear and do a gear pass, use less then 1/4 throttle to turn out and downwind, drop to take off flap on the turn to base, and pull most all the power and hit landing flap on the turn to final, use throttle to adjust rate of decent and drop it to idle again when i cross the threshold, it'll float all the way to touchdown. the big mistake i've seen made on landings with the Flash is people are scared to slow them down and then they have to force the landing or they shoot way past them.
Thanks KC. This is exactly my problem. I am afraid of slowing down too much and I force the landing with bad results. On the other hand if I slow down too much I can get, as happened twice already, a sudden wing drop. Happily this happened very close to the ground and resulted in minor scratches to the wing tip.
Hide Signatures
(in reply to KC36330)
       Post #: 1281
RE: C-ARF Ultra Flash build Thread + Video - 12/27/2011 1:34 PM
jampl
Score: 100
Status: offline
quote:
ORIGINAL: Ali
Jose.
Regards Al
Thanks Ali. I will try your set up.
Hide Signatures
(in reply to Ali)
       Post #: 1282
RE: C-ARF Ultra Flash build Thread + Video - 12/28/2011 11:55 PM
igorcar
Score: 100
Status: offline
Hello guys,
I need one help I like to know if the PowerBox Sensor is enough? (http://www.powerbox-systems.com/e/powerbox_systeme/powerbox_sensor/start.php)
I'm using 8411 on everything! And I like to use alot of flap!
Hide Signatures
(in reply to jampl)
       Post #: 1283
RE: C-ARF Ultra Flash build Thread + Video - 12/29/2011 12:23 AM
KC36330
Score: 328
Last Login: 5/19/2013
Status: online
powerbox sensor is plenty for the Flash. careful with too much flap though, the Ultra is a little more forgiving to flap then the Classic but neither like excessive amounts.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
(in reply to igorcar)
       Post #: 1284
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 2:42 PM
Ali
Score: 135
Status: offline
Managed to get 4 flights on my UF this friday just gone.
The first with the Jet Cat Telemetry fitted. I managed to read that my UF was landing between 35- 40 Mph. Which when compared to other sport jets it pretty slow. I know the lowest that we ever managed to read on boomerangs when we had eagle tree fitted was 30 Mph on an XL. So I am pretty impressed that such a slick and fast sport jet can slow down to this... Even more so when you factor in that there was very little head wind to slow us down.
Regards Al
Al''''s Hobbies. Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, FEJ, pull over, Tomahawk, Skygate, C-ARF, Jet-Teng,Kingtech
Hide Signatures
       Post #: 1285
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 2:57 PM
quist
Score: 116
Status: offline
Can you tell us more about the telemetry? What was the top speed?
Hide Signatures
(in reply to Ali)
       Post #: 1286
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 3:00 PM
quist
Score: 116
Status: offline
I installed the conformal tanks friday. When i installed the wing, the wing bolt punctured the right tank. Needless to say, it caused a mess.
Hide Signatures
(in reply to quist)
       Post #: 1287
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 3:04 PM
Ali
Score: 135
Status: offline
quote:
ORIGINAL: quist
LOL 15 Mins.... That took longer than I expected
Hide Signatures
(in reply to quist)
       Post #: 1288
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 4:45 PM
quist
Score: 116
Status: offline
That's because we are still hungover from NYE. But you didn't answer the question. Tell us more about the telemetry, is it info that is downloaded after the flight? is it sent back live? What ecu's does it work with?
Hide Signatures
(in reply to Ali)
       Post #: 1289
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 5:00 PM
Ali
Score: 135
Status: offline
Its a live system that feeds back to a hand held unit with an LCD screen on the ground which my caller reads out. It's not just speed info it provides either.
The system was originally from ProJet, but if I am not mistaken a specific Jet Cat version was produced... See here
http://www.projet-ecu.de/english/html/telemetry.html
I am sure Bob W can tell you more about availability in the U.S
I have used it with version 5 5.5 and 6 ECU's
Regards Al
Hide Signatures
(in reply to quist)
       Post #: 1290
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 5:04 PM
KC36330
Score: 328
Status: online
i've seen the JetCat version, it was $750 not practical for my budget.
Spektrum has 'announced' that they are releasing a telemetry system that interfaces with the JetCat ECU, but that's about all the info you can get out of them.
Hide Signatures
(in reply to Ali)
       Post #: 1291
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 10:20 PM
AFTERBURNER1
Score: 135
Status: offline
quote:
ORIGINAL: Ali
Regards Al
Still didn't get the answer to T's question.
JetCat USA Rep
Hide Signatures
(in reply to Ali)
       Post #: 1292
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 10:28 PM
Ali
Score: 135
Status: offline
Its nearly fast enough
Hide Signatures
(in reply to AFTERBURNER1)
       Post #: 1293
RE: C-ARF Ultra Flash build Thread + Video - 1/1/2012 10:47 PM
ddlstang
Score: 110
Status: online
You don'nt have a speed limit there do you.
Cough it up.
Dale
Hide Signatures
(in reply to Ali)
       Post #: 1294
RE: C-ARF Ultra Flash build Thread + Video - 1/2/2012 1:03 PM
sailing1
Score: 100
Status: offline
That is a great landing speed. Could you share your configuration for landing. Flap setup. Any Crow? Any down elevator for the given flap setting?
Thanks in advance.
Hide Signatures
(in reply to ddlstang)
       Post #: 1295
RE: C-ARF Ultra Flash build Thread + Video - 1/2/2012 1:14 PM
Ali
Score: 135
Status: offline
I will get my UF on the bench later this evening and take some photos and measurements as I have a few PM's relating to this. Please be aware. I am not stating that this is the only, or the best set up for a Ultra Flash. I am a firm believer that every plane has an ideal set up, and that is the one that the pilot is most happy with. I would never be as presumptuous to say that any other set up is wrong. Instead I try and advise people to have a play with their radio and balance set up till they get it how they like it. Just because it states it in the manual, does not make it right. I have found this true to so many different aircraft over the years, and now a days I am always flying and thinking " what can I do to make this feel better" Example... My UF set up is great at slowing the model down, but I need to find a way to get the flap to elv mix coming in slowly so that I don't get the ballooning up that I get if I drop the flaps too suddenly, and while the model is flying too quickly.
Regards Al
Hide Signatures
       Post #: 1296
RE: C-ARF Ultra Flash build Thread + Video - 1/2/2012 1:18 PM
BaldEagel
Score: 118
Status: offline
Ali
You need a 18MZ to do that, even the humble 12FG has that facility, have a word with schrodem he has two 18's.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to Ali)
       Post #: 1297
RE: C-ARF Ultra Flash build Thread + Video - 1/2/2012 1:21 PM
AFTERBURNER1
Score: 135
Status: offline
quote:
ORIGINAL: Ali
Regards Al
Yup....
JetCat USA Rep
Hide Signatures
(in reply to Ali)
       Post #: 1298
RE: C-ARF Ultra Flash build Thread + Video - 1/2/2012 1:22 PM
Carsten Groen
Score: 100
Status: offline
quote:
ORIGINAL: BaldEagel
... have a word with schrodem he has two 18's.
Mike
Nope, one of them is with me
I have around 1.5 second "slowdown/servoslow" on the flaps, elevator at around 1 sec, at moderate speeds, I don't even notice when I apply flaps, plane just slows down, no pitching etc (at least that I as an n00b can feel/see )
Carsten Groen
Hide Signatures
(in reply to BaldEagel)
       Post #: 1299
RE: C-ARF Ultra Flash build Thread + Video - 1/2/2012 1:23 PM
Robrow
Score: 100
Status: offline
Is it not as simple as using the servo slow function Ali?
Rob.
Hide Signatures
(in reply to Ali)
       Post #: 1300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
