RE: C-ARF Ultra Flash build Thread + Video    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: C-ARF Ultra Flash build Thread + Video
Page: <<   < prev  61 62 [63] 64 65 66 67 68 69 70   next >   >>
Login
RE: C-ARF Ultra Flash build Thread + Video - 3/28/2012 8:33 PM
Ramz
Score: 106
Last Login: 5/14/2013
Status: offline
Thanks. I will check it out. Leaning towards building something myself.
Hide Signatures
(in reply to ricardinho)
       Post #: 1551
RE: C-ARF Ultra Flash build Thread + Video - 3/28/2012 8:49 PM
phjoker
Score: 100
Last Login: 4/27/2013
Status: offline
quote:
ORIGINAL: Ramz
How do you guys transport your Ultra Flashes? (Mainly the fuselage) I am going to build something... Perhaps some sort of cradle that will double as a stand for assembly and disassembly at the field. My UF will be transported in a trailer with lots of room. The major thing I am concerned about is making sure the paint does not wear or scuff when the trailer is rolling down a bumpy road. Pictures would be nice!
Thanks.
I just lay mine on foam in the trailer and use the flat bungee cords.
Click to see fullsize image.
Click for fullsize
_____________________________
Pete H
A Happy Jet Central Falcon & Rhino Owner
Hide Signatures
(in reply to Ramz)
       Post #: 1552
RE: C-ARF Ultra Flash build Thread + Video - 3/28/2012 8:57 PM
mtnflyer14
Score: 100
Last Login: 5/18/2013
Status: online
Just need to make sure the aft end of the fuselage is not resting on the elevator control horns. If so, you will probably cause delamination in the horizontal stab.
Regards,
Gus
AW Extra 260/ZDZ Super 80; Elan/K-80; C-ARF Ultra Flash/P-120; YA F-15C/K-140
Hide Signatures
(in reply to phjoker)
       Post #: 1553
RE: C-ARF Ultra Flash build Thread + Video - 3/29/2012 7:30 AM
consoleworld
Score: 100
Last Login: 3/5/2013
Status: offline
Here some pictures from the NACA inlet .
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by consoleworld -- 3/29/2012 11:05 AM >
Christian Lenakakis
Club: ....................
Hide Signatures
(in reply to mtnflyer14)
       Post #: 1554
RE: C-ARF Ultra Flash build Thread + Video - 3/29/2012 9:15 PM
jampl
Score: 100
Status: offline
I simply use a wooden storage box bolted to the bottom of the trailer. I also made a cradle with white insulating foam (found at building materials stores). The cradle is removable so that I can insert any other shape for different planes. I secure it with a couple of belts. Just check the pictures.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Ramz)
       Post #: 1555
RE: C-ARF Ultra Flash build Thread + Video - 3/30/2012 1:38 AM
BoomerSooner
Score: 100
Status: offline
Which electric retracts are folks using on the ultra flash? Anyone installed the electron units?
Hide Signatures
       Post #: 1556
RE: C-ARF Ultra Flash build Thread + Video - 3/30/2012 3:40 AM
SniperWj
Score: 100
Last Login: 5/15/2013
Status: offline
other then enlarge the retract wood mount the electron looks good everywhere
yiming
Hide Signatures
(in reply to BoomerSooner)
       Post #: 1557
RE: C-ARF Ultra Flash build Thread + Video - 3/30/2012 10:08 AM
Philip Baum
Score: 100
Last Login: 5/17/2013
Status: offline
Hi,
did anybody flown the UF with the saddle tanks?
I am wondering if you have to check the CG with the tanks or if you can easily fuel and fly?
Best regards
Philip
Failure Is Not An Option - my page http://www.tief-flieger.de.tl - IMPORTANT: Looking for a Firebird!!! -
Hide Signatures
(in reply to SniperWj)
       Post #: 1558
RE: C-ARF Ultra Flash build Thread + Video - 3/30/2012 11:38 AM
Robrow
Score: 100
Status: offline
quote:
ORIGINAL: Philip Baum
Hi,
Best regards
Philip
Just fuel and fly Philip, no issues that I can see.
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
(in reply to Philip Baum)
       Post #: 1559
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 1:36 AM
Mavrik!
Score: 100
Last Login: 3/27/2013
Status: offline
Had a great weekend at Wangaratta Jets in OZ over the weekend.
I know there is some debate about speed in prior posts, however my UF can do 400 kmph.
Here is a screen shot of my GPS reading Multiplex set for Spacial 3D max reading and horizontal max GPS speed. You can see they are very close readings so it is ACCURATE.
Note I did not fly to get a max reading, was just having fun!!!!
Mav
Click for fullsize
Love my Ultra Flash Merlin 140 and F22 Raptor P140 RX Multiplex Royal Pro 16
Hide Signatures
(in reply to Robrow)
       Post #: 1560
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 3:25 AM
mtnflyer14
Score: 100
Status: online
Great - your UF can do 240 MPH in Australia. But, the fact is, we have an AMA restriction of 200 mph in the US and we need to adhere to that rule for a lot of really good reasons, not the least of which is the FAA's scrutiny of our hobby here. Anyone who ignores the AMA restriction and excedes it is jeopardizing this wonderful hobby for everyone, and that is unacceptable.
Regards,
Gus
Hide Signatures
(in reply to Mavrik!)
       Post #: 1561
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 12:24 PM
Mavrik!
Score: 100
Status: offline
quote:
ORIGINAL: mtnflyer14
Regards,
Gus
Gus,
Not debating your governing body rules AMA, rather confirming the UF can reach 400 kmph plus quite easily!
This should satisfy some of the skeptics out there!
Mav
Hide Signatures
       Post #: 1562
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 12:28 PM
Robrow
Score: 100
Status: offline
What is the correct level of fuel left in the fuz tank to lank with without risking a flameout?
Rob.
Hide Signatures
       Post #: 1563
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 12:31 PM
Robrow
Score: 100
Status: offline
quote:
ORIGINAL: Mavrik!
Mav
Looks about right for a Merlin 140.
Rob.
Hide Signatures
       Post #: 1564
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 12:35 PM
Robrow
Score: 100
Status: offline
Regards,
Gus
How do the AMA/FAA enforce this rule?
Rob.
Hide Signatures
       Post #: 1565
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 2:20 PM
mtnflyer14
Score: 100
Status: online
To be honest, I don't know if the AMA or FAA attend jet fly-ins to monitor the airspeed of the jets. But given the FAA's interest in 'unmanned aerial systems', we don't want to give them any reason to get more involved in our hobby.
Regards,
Gus
Hide Signatures
       Post #: 1566
RE: C-ARF Ultra Flash build Thread + Video - 4/2/2012 5:34 PM
tp777fo
Score: 103
Status: offline
They were at the latest AZ rally to watch...there is a thread about it.
Tom Perry
In Dog beers, I only had one!
Hide Signatures
       Post #: 1567
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 12:11 PM
ricardinho
Score: 100
Last Login: 3/26/2013
Status: offline
basil i maidened the ultra lightning..wow what a nice plane. . easy to fly and very fast with the 180...so how are you makeing out with the flash...when doyou think you are comming up this way to fly?...pat
Hide Signatures
(in reply to basimpsn)
       Post #: 1568
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 12:54 PM
Dave Wilshere
Score: 108
Status: offline
quote:
ORIGINAL: Robrow
Rob.
Rob
I usually run my fuse tank down so that it shows 15-18mm of fuel at the front sitting on the deck, I can run lower with minimal air in the header, but it comes down to the fact I do very few long verticals in the last minute and a half of the flight, loops and 8's are fine as fuel is under G. I have never had more than a tiny bit of air in my header using the kit tank set up
Dave
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
       Post #: 1569
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 2:17 PM
basimpsn
Score: 120
Status: offline
Good job pat glad to hear all went well. I'm engine less for now can't seem to make up my mine between the K-170 and the K-180 I will give you a call.
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
       Post #: 1570
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 5:45 PM
Robrow
Score: 100
Status: offline
quote:
ORIGINAL: Dave Wilshere
quote:
ORIGINAL: Robrow
Rob.
Rob
Dave
Thanks Dave, this is my tank after a flight, probably a little on the safe side?
Rob.
Click for fullsize
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 1571
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 8:33 PM
ricardinho
Score: 100
Status: offline
i am not a speed demon so mine was about like that or a little more with 120sx..
Hide Signatures
       Post #: 1572
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 9:52 PM
tp777fo
Score: 103
Status: offline
I'm building one with saddle tanks. I plan on running the main to the saddles through a "y"so the main feeds first. The saddles will "y" to the uat. Thoughts?
Tom Perry
Hide Signatures
       Post #: 1573
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 9:55 PM
ricardinho
Score: 100
Status: offline
yes thats sound right..i believe thats the way my lightning is done...i will look when i get home and post back
Hide Signatures
(in reply to tp777fo)
       Post #: 1574
RE: C-ARF Ultra Flash build Thread + Video - 4/3/2012 10:12 PM
ricardinho
Score: 100
Status: offline
ok looking at my lightning with saddle tanks..you will have two sets of tees.. one will tee off the vent.. one will tee to the uat...looks pretty simple.. i didnt build this but it looks easy...pat
Hide Signatures
       Post #: 1575
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
