RE: C-ARF Ultra Flash build Thread + Video    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: C-ARF Ultra Flash build Thread + Video
Page: <<   < prev  85 86 [87] 88 89 90 91 92 93 94   next >   >>
Login
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 8:43 AM
miniman
Score: 100
Last Login: 2/11/2013
Status: offline
Ihave finally sorted out the fitting of the bypass cover. Finished all the wiring and fitted the wing to find the bypass and the cables and kerostart made fitting the wing very tough.
I made the stupid mistake of pussing too hard and broke the top of the kerostart....an expensive mistake.
The motor was fitted so that the kerostart was not at the bottom where it could sit in a pool of un burnt fuel. This has meant that the Kerostart is sitting out off the side of the motor (see the attached picture) but this stops the wing from seating properly.
I have marked the wing where it needs to be opened out too give clearence. I have read on this post and in the instructions that its ok to cut holes in the top of the wing as the spar is where the strength is. As you can see from the picture the marked area is well away from the securing bolts.
WHat do you guys think, has anyone had the same problem and cut into this area?
Peter
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by miniman -- 10/5/2012 9:31 AM >
Hide Signatures
(in reply to izzy)
       Post #: 2151
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 9:24 AM
miniman
Score: 100
Status: offline
double post
Hide Signatures
(in reply to miniman)
       Post #: 2152
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 10:46 AM
Robrow
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: miniman
Peter
Might be worth changing to internal kero start?
Rob.
_____________________________
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
       Post #: 2153
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 11:00 AM
miniman
Score: 100
Status: offline
The internal kerostart is not available as an upgrade.
I have just had a great telephone call with Dave from Motors and Rotors and he assured me that its ok to dremell a hole in the top of the wing to clear the Kerostart.
I now have a wing that fits, I just need a new Kerostart
That was an expensive mistake!!
Peter
Hide Signatures
(in reply to Robrow)
       Post #: 2154
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 11:42 AM
BaldEagel
Score: 118
Status: online
miniman
Ali sells a low profile Kero start, that may be the answer without cutting into the wing?
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 2155
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 5:16 PM
miniman
Score: 100
Status: offline
Ali has no stock and the guy on the phone did not know when they would have any in.
Peter
Hide Signatures
(in reply to BaldEagel)
       Post #: 2156
RE: C-ARF Ultra Flash build Thread + Video - 10/5/2012 5:50 PM
BaldEagel
Score: 118
Status: online
Worth a try?
Mike
Hide Signatures
       Post #: 2157
RE: C-ARF Ultra Flash build Thread + Video - 10/9/2012 11:52 AM
skaap2k
Score: 105
Last Login: 5/2/2013
Status: offline
My new Ultra Flash arrived late last week, I managed to get it outside for a few photographs over the weekend! Really looking forward to flying her!
Setup nearly done, just need weather like we had here last weekend!
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2158
RE: C-ARF Ultra Flash build Thread + Video - 10/9/2012 5:31 PM
wojtek
Score: 110
Status: offline
Well, im soon about to start on UF #2 :\ ... Still not sure what caused the fire. I went up, and rudder servo kept pulling hard over .. I later found out it was melting .. I landed the plane and when it rolled out, the rear burst into flame ..
~V~
Click for fullsize
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to skaap2k)
       Post #: 2159
RE: C-ARF Ultra Flash build Thread + Video - 10/9/2012 5:45 PM
Pinnacle Aviation
Score: 100
Last Login: 5/23/2013
Status: offline
All painted ready for the weathering
Photobucket Pictures, Images and Photos
Phil Noel
Pinnacle Aviation (Professional model builder and painter)
Hide Signatures
(in reply to wojtek)
       Post #: 2160
RE: C-ARF Ultra Flash build Thread + Video - 10/9/2012 6:13 PM
wojtek
Score: 110
Status: offline
wow, that looks great ! Best military finish on a sport jet I have seen in a long time
~V~
www.all-scale.com
Hide Signatures
(in reply to Pinnacle Aviation)
       Post #: 2161
RE: C-ARF Ultra Flash build Thread + Video - 10/9/2012 7:08 PM
Ruymán
Score: 100
Last Login: 1/24/2013
Status: offline
Precious ... after the red color like mine that was more than me he was pleasing, this one overcomes it!!!
You have still had it impressive!!!
That you enjoy!!!
Hide Signatures
       Post #: 2162
RE: C-ARF Ultra Flash build Thread + Video - 10/9/2012 7:53 PM
stevekott
Score: 105
Status: offline
quote:
ORIGINAL: wojtek
~V~
Sorry For your Loss.  At least got it back (well most of it) and its wasn't just a smoking hole.  Wow what an amazing photo.  I'm sure we would all be very curious to find out what your theory was in what went wrong.
Three weeks ago I had a buddy getting ready to maiden a new SM Viper and on a high power run up we heard a 'ping' and within seconds the right side of his rear fuse started turning brown, blistering and then flames.  We were lucky, he pulled the throttle and fire extinguishers were at the ready.  The spot welds (very poor quality weld) on the tab that centered the pipe gave out and it deflected to one side. It softened the Aluminum bell mouth and the exhaust got split with half of it being deflected into the side of the fuse.  It happened QUICK!
I don't think there is enough room in the UF to move the pipe to the side like that but the burn location looks to be in the same spot.
Hide Signatures
       Post #: 2163
RE: C-ARF Ultra Flash build Thread + Video - 10/10/2012 12:01 AM
Andrew Bird
Score: 110
Status: online
Voy - sorry to see that. Good save though, could have been a lot worse!
Phil - the UF looks great in that scheme.
Hide Signatures
(in reply to stevekott)
       Post #: 2164
RE: C-ARF Ultra Flash build Thread + Video - 10/10/2012 1:39 AM
Jack28
Score: 100
Status: offline
So sorry to see good jets destroyed. Here's my Ultra Flash at the same jet event (Hamburg) one day later. This would have been flight 12 for mine. First flight of day took off ,put gear up, flaps up,climbed to altitude and then noticed it was climbing excessively, went to 3/4 throttle, trimmed it level using all of the trim, flew 5 seconds more and then started diving all by itself, leveled out again then it porpoised up and down badly. Got level again and I handed to my buddy (help somethings not right) it flew a few more seconds then it stopped responding to any inputs as it slowly rolled to the left and went into a dive, It went straight in from about 500 feet. We spent 1 1/2 hours in the corn looking for it finally found it behind the cornfield in a pasture. It was scattered everywhere, didnt burn though. Really sucks to lose your best jet to an unknown radio issue. We recovered every little bit as it was a pasture for milk cows. Everything was brand new in this jet, two A123 battery packs, feeding a the reciever directlly, one of which is still fully charged the other was destroyed. I have the exact same set up (same reciever/batteries /servos/etc. in my Elan flying with the same radio and that jet has 268 flights on it.The turbine (Cheetah) looks like it can be repaired ,although it will need all of the electronics and some other parts.I can't fund another one, and don't want to fly the boomerang Elan until the radio is checked out. I really loved this jet! I was just starting to get comfortable with it. Time to take a break from this hobby. Jack.
Click for fullsize
Jack George
Hide Signatures
(in reply to Andrew Bird)
       Post #: 2165
RE: C-ARF Ultra Flash build Thread + Video - 10/10/2012 1:40 AM
Ramz
Score: 106
Status: offline
quote:
ORIGINAL: miniman
Peter
I don't know if it is critical with kero start or not but Jetcat recommends putting the in the vertical position, when mounted. +/- 75° of engine rotation, from the glow plug at top dead center, is the allowable deviation. Your install looks to be around 100 or 110 degrees from vertical? Something to think about. I have a P20 kero start at about 70 degrees and it starts every time.
Hide Signatures
       Post #: 2166
RE: C-ARF Ultra Flash build Thread + Video - 10/10/2012 2:53 PM
basimpsn
Score: 120
Status: online
quote:
ORIGINAL: Jack28
So sorry to see what happen, saw the whole thing. I do remember seeing you taking off with (Takeoff flaps) and i'm wondering if that could be a contributing factor base on how quicky it gain altitude ?
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to Jack28)
       Post #: 2167
RE: C-ARF Ultra Flash build Thread + Video - 10/27/2012 9:03 PM
izzy
Score: 100
Status: offline
Landing Gear covers
here is how i made fitting the covers easy
thought i would share with you
first - sand /cut the cover plates to shape
then i took some 6m ply , and cut 4 square shape blocks each 1cm x 1cm and drilled 4mm holes in each at centre, chicked the up in a long 4mm bolt and nut, and made them round
I used 4mm socket screws that i had lying around and screwed them into the struts , and slipped on the rounded ply spacers i made
then it was just a simple issue of testing the height of these spaces, sandin them slightly and then gluing the plates onto these spacers
lastly once glue was dry, slip off the plate and drill 4mm holes in the centre of the rounded spacers , fit the covers now with 4mm bolts ( i will go to thelocal hardware shop to look for some button head bolts)
izzy
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to basimpsn)
       Post #: 2168
RE: C-ARF Ultra Flash build Thread + Video - 10/28/2012 12:06 AM
BaldEagel
Score: 118
Status: online
Or glue them on with Silicon Mastic that way if they hit anything they rip off without damaging anything.
Mike
Hide Signatures
(in reply to izzy)
       Post #: 2169
RE: C-ARF Ultra Flash build Thread + Video - 10/28/2012 11:27 AM
Mavrik!
Score: 100
Last Login: 3/27/2013
Status: offline
quote:
ORIGINAL: BaldEagel
Mike
That's what I did. Took about 30 seconds including locating tape!
Mav
Love my Ultra Flash Merlin 140 and F22 Raptor P140 RX Multiplex Royal Pro 16
Hide Signatures
       Post #: 2170
RE: C-ARF Ultra Flash build Thread + Video - 10/28/2012 4:08 PM
izzy
Score: 100
Status: offline
quote:
ORIGINAL: Mavrik!
quote:
ORIGINAL: BaldEagel
Mike
Mav
so how did you make up the differnce in spacers between strut and cover that sits aprox 6mm higher
Hide Signatures
(in reply to Mavrik!)
       Post #: 2171
RE: C-ARF Ultra Flash build Thread + Video - 10/28/2012 6:02 PM
BaldEagel
Score: 118
Status: online
Silicon mastic some spacers to the legs and then do the same with the doors, epoxy spacers to the legs and silicon mastic the doors onto them, or epoxy the spacers to the doors and silicon mastic the spacers to the legs, many ways to skin a ..........................it is not Rocket science.
Mike
Hide Signatures
(in reply to izzy)
       Post #: 2172
RE: C-ARF Ultra Flash build Thread + Video - 10/30/2012 2:15 PM
Pinnacle Aviation
Score: 100
Status: offline
All done apart from fitting a pilot
Phil Noel
Hide Signatures
       Post #: 2173
RE: C-ARF Ultra Flash build Thread + Video - 10/30/2012 2:45 PM
PaulD
Score: 105
Status: offline
Very nice Phil. Well done.
PaulD
If it''s too LOUD - You''re too OLD
Hide Signatures
       Post #: 2174
RE: C-ARF Ultra Flash build Thread + Video - 10/30/2012 3:07 PM
basimpsn
Score: 120
Status: online
Sure looks better and different
Hide Signatures
       Post #: 2175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.189RCU1
