DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: offline
GuamJan, bgi, The Webra excels at higher RPM, with its high volume muffler, which is not tuned, as far as I know. The MVVS .49 spins heavy props at RPM levels that you are probably used to seeing with .60 engines. The MA 11x6 prop is spun at about 14,600 RPM, which is close to the top the tuned muffler's range and it would unload very little in flight. I would not recommend this prop with the tuned silencer. If you want to use MA, go with an 11x7 minimum. An APC 11x6 offers more load. An 11x7, 12x6, 12x7, 13x4 are among the good sizes. If you want a 10" prop, an APC 10x8 would be the absolute minimum, to keep it around 14K. All this is achieved with cheap, 0-5% nitro fuel. If you try a 10x6, it will resemble "full throttle in neutral gear". Wrong prop. A Webra will spin a 10x6 at over 15K, however. For the MVVS to run on 15% nitro, you will likely need two head shims. Can't you mix your own fuel with 5% nitro, in Guam? It would be preferable to modifying your engine. The MVVS would show 150-200 more RPM, if "shimmed" and run on 15%, than it would unaltered, on 5% nitro. It would run better (idle, response) if used as it was originally engineered and designed.
< Message edited by DarZeelon -- Aug 6 2003 1:14PM >
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
