RE: 1st R/C Airboat build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Airboats >> RE: 1st R/C Airboat build
Page: <<   < prev  1 [2]
Login
RE: 1st R/C Airboat build - 5/8/2011 9:58 AM
1QwkSport2.5r
Score: 155
Last Login: 5/21/2013
Status: online
Got a new engine on the way for this boat.. Super Tigre S90K! I think this should get 'er moving better than my poor old K&B Sportster .65...
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 26
RE: 1st R/C Airboat build - 5/21/2011 4:11 PM
1QwkSport2.5r
Score: 155
Status: online
Mounted the SuperTigre .90 on my Kamikaze airboat. Even with the engine stupid rich, it ran far better for me than my K&B .65 did. I know the K&B just needs a new carb to run right, but the .90 was the right price and it'll swing the same 13x6 prop 2000rpm faster than the K&B will. Seemed to be a no-brainer for me.
K&B .65 next to the ST .90 - both engines are about the same size but the mufflers are obviously different.
When the weather clears up around here, I'll get some videos up.
Hide Signatures
       Post #: 27
RE: 1st R/C Airboat build - 4/11/2012 2:39 AM
1QwkSport2.5r
Score: 155
Status: online
I'm in the process of dusting off the Kamikaze, and decided it was time for a new rudder. Much like the one I made for my Minikaze, I laminated strips of Black Cherry and added some Black Walnut in for color. I need to make the blade and finish putting coats on the rudder strut, but this thing should work as well as my other rudder and help with handling too.
Hide Signatures
       Post #: 28
RE: 1st R/C Airboat build - 4/13/2012 4:17 AM
1QwkSport2.5r
Score: 155
Status: online
I finished the rudder assembly for this boat. I might have to put a different control horn on it, but I wont know until I get off my keister and mount it up. The next one I make I'm going to experiment with different cutting techniques to get the grain of the wood showing in just the right way to give a really neat 3D effect.
Anyway.. here's a picture.
Hide Signatures
       Post #: 29
RE: 1st R/C Airboat build - 4/13/2012 12:47 PM
Altered1
Score: 106
Status: offline
That is just the ducks nuts man !
It looks awesome, and would work great.
Altered1
Hide Signatures
       Post #: 30
RE: 1st R/C Airboat build - 9/29/2012 7:09 PM
1QwkSport2.5r
Score: 155
Status: online
So I've been experimenting with my .60 4-stroke engine on my big Kamikaze... The problem I'm encountering is porpoising. The age-old wisdom (not that old, LoL) has been, AFAIK, to have the prop at 1/3 the length of the hull measured from the transom. I have the prop in this location. 32 1/2" long hull, prop is at about 10.75" from transom. The boat weighs about 8lbs with engine, full tank of fuel, Battery pack, etc. Lifting by the prop, the boat is very bow heavy. Moving the engine forward any more than it is will involve raising the engine even higher so the prop clears the hull. Not ideal. Instead, I strapped my 8oz GPS on top of the fuel tank and this helped it balance much better, nearly perfect. It still porpoises. I had the same problem with my .90 2-stroke, but worse since that engine is a lot more powerful. There isn't much I can do to lighten the bow much except using lighter servos but that isnt going to save more than an ounce or two. Not enough to make a difference. So.. Since there isnt a How-to in the Jigs/how-to section, I ask here to find out from the veterans (if any of them still visit the forum) as to how I can correct the bouncing up front. The 4-stroke .60 weighs just grams less than the .90 2-stroke, and the original engine (bushed crank .65 2-stroke) was installed about 1.5" further rearward than the engine is mounted currently. What does a guy do? I can't get a good speed run if the bow is bouncing like a pogo stick... Need some input, please.
Empty fuel tank, but RTR otherwise:
Empty fuel tank, with GPS on top of fuel tank (+8oz) - sorry I cut off the rearmost section of the boat in this picture. You should get the idea though..
Static picture of boat as I ran it last.
This is an older vid from a couple months ago, but you can see and hear it porpoising. This is without the GPS on it, but a total of 12 Standard alkaline batteries in the radio box for ballast. 4 of which power the receiver and servos.
http://youtu.be/fANKIgoe65Q
I dont really want to have to add that much more ballast... Is my only option to move the engine? Angling the prop up didnt change much. The GPS on the fuel tank helped some, but not enough.
Hide Signatures
(in reply to Altered1)
       Post #: 31
RE: 1st R/C Airboat build - 10/11/2012 11:55 AM
Got RPM
Score: 100
Last Login: 5/17/2013
Status: offline
Instead of adding weight, change the motor's thrust angle. Shim the motor or motor mount to raise the front of the motor, that will help hold the bow down without weight.
Hide Signatures
       Post #: 32
RE: 1st R/C Airboat build - 10/11/2012 2:21 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: Got RPM
I ran it a couple weeks ago and tried a few different things and the results of that require the engine to move forward. I've shimmed the thrust angle already with little change. Too high of AOA ends up causing a drop in speed which I don't want. I'll have to make a new engine mount allowing 2" of forward movement which will make the boat balance.
I've been running my 3-pointer lately so this boat has been idle. I may work on it over the weekend if I have time.
Hide Signatures
(in reply to Got RPM)
       Post #: 33
RE: 1st R/C Airboat build - 11/18/2012 4:17 AM
1QwkSport2.5r
Score: 155
Status: online
I'm in the process of making a new engine mount, in the mean time I shimmed the thrust line up quite a bit to smooth out the porpoising. It runs far better now, although not quite perfect. I think the prop will have to move forward at least 1.5" if not 2". I'll incorporate some adjustment as I have 3 engines I can run on this boat.
A couple short vids I made today running my Enya 60-4C on the Kamikaze
http://youtu.be/qAgUyZDCx1I
http://youtu.be/tHgkyInh1J0
http://youtu.be/zKZaxLuuzRw
Nothing special, it just sounds cool. The engine ran pretty well today. I'll try a few other props and test with the GPS.
Hide Signatures
       Post #: 34
RE: 1st R/C Airboat build - 11/18/2012 3:30 PM
rcairboater
Score: 110
Last Login: 5/19/2013
Status: offline
CG is based on weight. Move the engine to the rear and balance 1/3 the length of the hull, measured from the transom. Looks's like the engine is too far forward. Also, Put the silver spinner back on for the gold spinner is quite a bit heaver. The gold is used for adding weight for balancing purposes.
Hide Signatures
       Post #: 35
RE: 1st R/C Airboat build - 11/19/2012 12:01 AM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: rcairboater
If the prop was put at 1/3 length from transom, it hops real bad. The proper balance AFAIK is when holding the boat up by the prop that the hull stays level. This boat is not level holding it like this, it is very bow heavy. Moving the engine forward will balance it. Moving it back makes it worse.
My SI-3 .20 size hydro balances perfect at the prop and runs out perfectly.
The brass spinner nut is the only 7mmx1.0 nut the LHS had. Being a 4-stroke, it likes to have a little extra flywheel effect on smaller props. I have little to no intention of changing it.
Hide Signatures
(in reply to rcairboater)
       Post #: 36
RE: 1st R/C Airboat build - 11/19/2012 12:41 AM
rcairboater
Score: 110
Status: offline
Get a piece of round stock longer than the width of the hull. Lay the stock on a flat surface, and level as well. Mark on the hull on either side the balancing point and line up the round stock and see where the hull balances. You can move the hull back and forth on the stock to achieve your balance point.
Another method is to tape the round stock on the top of the hull at the balance point and lay either end on a end of a table or similar.
Give this a try and see.
Let me know how you make out.
Hide Signatures
       Post #: 37
RE: 1st R/C Airboat build - 11/22/2012 3:35 PM
rcairboater
Score: 110
Status: offline
Have not heard from you. How did you make out on the balancing issue?
Hide Signatures
       Post #: 38
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.936RCU1
