Crashed and Don't know why    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Thunder Tiger - Raptor 30, 50, 60, 90 >> Crashed and Don't know why
Page: [1]
Login
Crashed and Don't know why - 10/2/2010 12:19 PM
baron56
Score: 100
Last Login: 4/2/2012
Status: offline
I'm kinda new to the flying thing, I bought a raptor 50 ? se,titian about a year ago. in a box totaled out. Bought a lot of new parts, anything questionable was replaced. Radio used is 6EX, 401 gyro. Now I flew this bird several time without fail. NOTE: I don't do 3D What I am doing is teaching myself to fly to set up for Scale. I have several hours on sim and Like I said I have flown about 5-6 flights on this bird. I do my range checks , the wind was 1-3 mph, clear and about 75 degrees. I lifted off into what little wind there was and proceeded downwind. When I turned it back into the wind I could not get it out of the turn it proceeded to roll right and nose down, Which is where it found Earth. Post crash investigation: The only linkage that failed was the forward elevator, due to canopy contact on impact. also when I returned to the point of departure, I checked the radio, It all worked fine, with the exception of elevator of course. So I didn't see linkage problem or radio. I know my skill level is such I didn't panic or get disoriented. I was wondering if anyone has had similar experience? What should I be looking for?
Hide Signatures
       Post #: 1
RE: Crashed and Don't know why - 10/2/2010 11:25 PM
lje553
Score: 100
Last Login: 4/18/2013
Status: offline
I know i have had the tail linkage guide slide up into the tail servo and bind up. But that was on a tail mounted servo. But it keep the heli in a slow pero that I had to try to land.
_____________________________
If you haven''t broke it yet you are not trying!
Raptor 50 and 30, trex 450 V2, DX8
Hide Signatures
(in reply to baron56)
       Post #: 2
RE: Crashed and Don't know why - 10/3/2010 5:37 AM
helifan06
Score: 100
Last Login: 11/26/2011
Status: offline
could be linkage locked-out
Hide Signatures
(in reply to lje553)
       Post #: 3
RE: Crashed and Don't know why - 10/3/2010 2:28 PM
baron56
Score: 100
Status: offline
I checked Linkage when I was disassembling the bird, Couldn't find anything noticeable. However, in reading some of the other discussions, I think I found my problem, Its in the servos. I am using the wrong ones they are the stock ones that came with my Spectrum DS7. OK. New parts on the way, Will order new Servos. I have the info and I thank you guys for the help. I will let all know how it comes out.
Hide Signatures
       Post #: 4
RE: Crashed and Don't know why - 10/3/2010 9:34 PM
lje553
Score: 100
Status: offline
Were those servos to weak to move it or something? Just wondering.
Hide Signatures
       Post #: 5
RE: Crashed and Don't know why - 10/5/2010 4:57 AM
BarracudaHockey
Score: 280
Last Login: 5/20/2013
Status: offline
The DS821's come with a warning not to use them in 50 size nitro helicopters because they can fail due to vibration.
Usually one of two things happen. The amplifier dies and they stop responding, or the output shaft shears off the top of the servo flush with the case.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 6
RE: Crashed and Don't know why - 10/7/2010 4:59 PM
baron56
Score: 100
Status: offline
Nothing like finding out the hard way, I thought I could get by since I was doing hover practice and nothing 3-D. Live and learn. Will be ordering the good stuff when I rebuild. I will most likely replace the Gyro just for good measure, I seemed to get some tail hunting, the first time I found the pitch slider to have a quite a bit of slop in it. Snugged it to zero play but not too tight, this improved handling. as I flew more it started to wonder around a bit. It had to be the servos. BTW from the time I built my Kinetic to rebuilding the raptor the first time was over a year. I learned valuable lesson too, read. I can't quote the numbers on the servos I put in the Kinetic,but rest assured they were recommended by people who had been flying helis for a long time, and thats what I will go back too, regardless of cost. On another note, I hvae a brand new Caliber 5, anything I should watch-out for?
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 7
RE: Crashed and Don't know why - 11/16/2010 1:42 AM
Callouscade
Score: 100
Last Login: 12/27/2012
Status: offline
Could it have been your battery? Was it too low?
Blade MCX, Blade MCPX, Half a Blade CX2, Trex 450SA, Trex 600E Pro, Trex 600N 3G, Aeolus 50.
Hide Signatures
       Post #: 8
RE: Crashed and Don't know why - 2/6/2011 5:07 PM
poison
Score: 100
Last Login: 9/15/2012
Status: offline
Man I tell you I have had to crashes already been flying helies for 2years now and both crashes was due to my servos going out its better to do your homework and put good servos in and not have to worry about a crash. My raptor 50 just went down because of the jrds821 went out on me all together this servo performs awesome does everything I want it to but I just found out about the viberation issue with them so I am replaceing them all because it just not worht risking another crash think I am going with Hitecmg 5654 or futaba 3050 what you guys think?? Last time she went down it was full right into the field if it was left it would have hit problem 3 or 4 people that was watching it it would suck to hit someone with your helicopter you know man I would feel bad. Wounder why some servos can handle the viberation better than say the 821 does man it sucks to have to replace them all
Hide Signatures
(in reply to Callouscade)
       Post #: 9
RE: Crashed and Don't know why - 3/16/2011 8:41 PM
rcagpilot83
Score: 100
Last Login: 3/2/2013
Status: offline
would the ds 821's be alright in a 30 size nitro heli?
Hide Signatures
(in reply to poison)
       Post #: 10
RE: Crashed and Don't know why - 3/16/2011 8:49 PM
BarracudaHockey
Score: 280
Status: offline
They fall within the specs from the manufacturer for 30 size nitros.
Personally, for my personal helicopters, if you throw them in a bucket of water and they float, they will work on a nitro heli, if it sinks to the bottom, don't.
Your milage may vary.
Don't get me wrong, I fly a lot of JR/Spektrum gear, but those particular servos have issues.
www.JaxRC.com
Hide Signatures
(in reply to rcagpilot83)
       Post #: 11
RE: Crashed and Don't know why - 7/17/2011 2:47 PM
charliew
Score: 100
Last Login: 7/22/2011
Status: offline
http://youtu.be/Us6rSxNPjbQ
Hide Signatures
       Post #: 12
RE: Crashed and Don't know why - 4/1/2012 1:29 AM
baron56
Score: 100
Status: offline
OK guys, Sorry i have been away for awhile, Had this thing called heart attack and triple bypass, such an bother, doing fine though, I found the root of crash on the raptor, it was a faulty switch harness, the switch itself was soft, in that it did not have positive on/off locking indent, so ergo I got smacked. Thanks for all your input, I hope this will help others avoid disaster. look for my new problem under title TAIL SPIN.
Hide Signatures
       Post #: 13
RE: Crashed and Don't know why - 4/1/2012 3:23 AM
poison
Score: 100
Status: offline
Well its nice to here that you are doing fine after your surgey thank God for that. I am glad you found your problem always a good thing to find out the reason you crash so you can prevent the samething form happening twice. Good luck with your next flight attempt
Hide Signatures
       Post #: 14
RE: Crashed and Don't know why - 7/21/2012 4:51 AM
Lins
Score: 100
Last Login: 5/13/2013
Status: offline
quote:
ORIGINAL: baron56
I prefer to run dual batteries/switches in my aircraft that are either helicopters .30 or larger, or any plane larger than .40 size. My Raptor 50 was on single battery, but I'm now rebuilding it after a tail rotor servo failure and will be setting it up with dual batteries and switches.
Glad to hear you're doing better!
Cub Brother #10
Waco Brother #221
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
