Charging Rates
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Charging Rates
Page: [1]
Login
Charging Rates - 7/30/2003 1:56:31 AM
BaronSchwab
Status: offline
Doen any of you know a formula to determine what amperage to use when field charging a battery.
_____________________________
Non esse sine aircraftus.
       Post #: 1
Charging Rates - 7/30/2003 4:29:11 AM
3DFanatic
Status: offline
ALl depends on what type of battery.
For quick-charging a NiCd:
Never charge and more the 3C (3 times its rated capacity)
For NiMH:
Never more then 2C
For all Lithium based:
Never more then 1C
-Aaron
3Dfoamy.com
(in reply to BaronSchwab)
       Post #: 2
Charging Rates - 7/30/2003 9:11:11 AM
tunnelvishon
Status: offline
I've charged some nicads at 4C(usually 2-3C) but have watched them closely and its worked fine for me. I presume their life may be a little shorter but it hasn't been an issue yet for me.
       Post #: 3
Charging Rates - 7/30/2003 3:02:33 PM
BaronSchwab
Status: offline
I have a battery with cells that are 2.5in long. Are these "A" sized?
       Post #: 4
Charging Rates - 7/30/2003 7:46:24 PM
cobalt
Status: offline
Here's a cool chart with cell size referrences and a listing of lot's of different cells with actual weights. (NiCD AND NiMH despite the url.)
http://www.tnrtechnical.com/NICAD_Choices.htm
Hope that helps,
Jason
       Post #: 5
Charging Rates - 7/30/2003 7:57:48 PM
BaronSchwab
Status: offline
I assume that the measurements are in mm.
       Post #: 6
Charging Rates - 7/30/2003 8:12:00 PM
cobalt
Status: offline
yes, http://www.onlineconversion.com/length_common.htm
       Post #: 7
Charging Rates - 7/30/2003 9:21:13 PM
BaronSchwab
Status: offline
Thanks all for the help!
       Post #: 8
Charging Rates - 7/31/2003 6:18:49 AM
Geistware
Status: offline
While you can charge at higher rates, both Sanyo and Panasonic state that 1C is the max charge rate.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU2
