F6F Hellcat kits?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> F6F Hellcat kits?
Page: <<   < prev  1 [2]
Login
F6F Hellcat kits? - 8/20/2003 8:57:47 AM
Capt. Winters
Status: offline
Heritage is now Skyshark RC , and they advertise on this web site. Hope that helps Take care Capt. Winters
(in reply to dugman)
       Post #: 26
F6F Hellcat kits? - 8/20/2003 10:51:52 PM
Chad Veich
Status: online
mcrouchman, I was not aware Ziroli had an 86 inch Hellcat. Are you sure it's a Ziroli? Is it possibly 96 inches? Or has Ziroli just come out with a plan set I was unaware of? Thanks a bunch.
       Post #: 27
F6F Hellcat kits? - 8/21/2003 12:22:12 AM
smchale
Status: offline
mcrouchman, the ziroli hellcat is a pretty straightforward build. i did one fully built up...see pics in my gallery or some construction pics on my website, under Projects. His plans show you everything, and they also come with a list of steps as a 'guide'. Plus, there are a lot of very experienced folks here on RCU when it comes to his designs (which all follow a very similar design philosophy). Just ask away on RCU!
_____________________________
Cheers, Sean McHale
www.strictlyscale.com....and Revver Brotherhood #101
       Post #: 28
F6F Hellcat kits? - 8/21/2003 1:33:38 AM
luckyb001
Status: offline
Stuka Berry, I also have a Ziroli Hellcat. I found that the gear dont like to extend fully for landings either, so what I do is throttle back deploy full flaps and slow her down as much as she will stand then deploy the gear. This works then throttle up and set up to land. Mike
"No hanger Queens"
       Post #: 29
OOPS!! - 8/21/2003 3:52:55 AM
mcrouchman
Status: offline
I Strongly appolagize, my plans that I bought were for a F8F 1&2 BearCat...I was told on the site from the guy I bought it from that they were Hellcat Plans, but nonetheless, they are good enough for me to start out with. If there are any sugestions from all of you "veteran" builders, it would be GREATLY appretiated!
       Post #: 30
Hellcat - 8/21/2003 4:08:02 AM
L454S
Status: offline
The American Eagle glass and foam kit is not available yet. I should have the first out of the mold within a couple months. I am flying a Holman 80in Hellcat now. It weighs 24lb and has a G62(yup, its a rocket). I added 2 inches to the center of the wing sections(foam), this gave a little more wing area and spread the gear out a bit. Its like flying a sweet stick, very quick and nimble.
Click to see fullsize image.
Click for fullsize
From the swamp, Lenny ....Bayou Boys R/C
http://www.eatel.net/~l454s
       Post #: 31
F6F Hellcat kits? - 8/21/2003 8:12:27 AM
MarkShapiro
Status: offline
Hey dugman,
I never posted the finished Byron Hellcat I wrote about last year as being almost completed. I am attempting to attach a picture. The Hellcat has flown numerous times already and really is an outstanding flyer. Very very stable and predictable. Also very quick with the G-62 up front. My fears about five pounds of lead in the nose were all for not.
Click for fullsize
       Post #: 32
Byron Hellcat - 8/21/2003 8:14:41 AM
MarkShapiro
Status: offline
and another . . .
Click for fullsize
       Post #: 33
Byron Hellcat - 8/21/2003 8:15:28 AM
MarkShapiro
Status: offline
another
Click for fullsize
       Post #: 34
Byron Hellcat - 8/21/2003 8:16:35 AM
MarkShapiro
Status: offline
another. Sorry for poor quality
Click for fullsize
       Post #: 35
Byron Hellcat - 8/21/2003 8:17:39 AM
MarkShapiro
Status: offline
That's me at the nose cranking over the G-62. One or two flips is all it takes.
Click for fullsize
       Post #: 36
Heritage Kits - 8/21/2003 9:53:35 AM
Darren40-RCU
Status: offline
If you were interested in the Heritage Hellcat you're in luck! That same kit is still available from Skyshark. Check out skysharkrc.com Same kits with some improvements to the f/g cowlings. In the same size range the Marutaka kit is another option, a bit larger but count on much more work.
       Post #: 37
hellcat - 8/21/2003 8:09:20 PM
bridog
Status: offline
I know it's an Arf and not a Kit But how about the Giantscaleplanes Hellcat Is it any good or what .. I've been thinking about buying one....
Bridog
       Post #: 38
Hellcat - 8/22/2003 3:19:54 AM
mcrouchman
Status: offline
I have Plans for the Ziroli Bearcat, not the hellcat, I think it is 5 or 6 sheets...full notes on blueprints with much detail. Ziroli gives option as to the height of the rudder to make it handle more controlling, he found that the original plan of the rudder made the plane more "loose", so he heightened it to give it more control. I think there were a few other mods that he changed from the original plan, but nonetheless, they are great!
< Message edited by mcrouchman -- Aug 23 2003 1:51AM >
       Post #: 39
F6F Hellcat kits? - 8/22/2003 3:36:26 AM
MikeChilson
Status: offline
mcrouchman,
By offering to make a copy of Nick's plans and sharing them you are violating the copyright. And also opening yourself up to legal action. I'm sure most folks here appreciate your offer though.
Just wanted to make sure your aware.
< Message edited by MikeChilson -- Aug 21 2003 10:45PM >
Mike Chilson
RCSCALEBUILDER.COM Founder
       Post #: 40
