AirRayInc
Joined: 12/30/2001 From: San Pedro, CA, USA Status: offline
Regarding the Holman Hellcat. I flew it with a Moki 1.8. At the time the plane was built, the 2.1 was not available. The all up weight was close to 24lbs on take off, well with in the Moki's power range. The Hellcat is a great looking plane in the air, I found myself sometime getting caught up in watching and forgetting I needed to fly it, a bad thing with this plane as it has some characteristics, that require you to stay in touch with the plane. As maybe a factor of the weight or just a fine recreation of it full size image, I found that in the corners I really needed to make sure that I co-ordinated the turns. Bank angle, relax, rudder input, hold, back pressure hold. Otherwise you really feel that inside wing losing some lift, and begin to slide and stall. Landings of the 80incher are pretty straight forward, you get alot of lift from the flaps, and they really put the brakes on. Gotta make sure you dial in some down elevator and run a bit of power on approach. In looking back, I would love to have flown it with a gas more, nothing less than a Brisson 3.2 or the like. As it took a bit of lead to get the c/g squared away. Nice available pace with this wingspan and airfoil. Nothing intimidating, but able to get you some good straffing run speed with the right props and powerplants. Since I love Hitec servos, it had 700 on the elevator, 425 on the couuple of non essentials, 605 and 545 everywhere else. Servo response was never a concern. 1 to 5 stars, I give it a 3.8 over all. Scale potential it gets a 4. build ability, you need to have some composite work under your belt before you tackle this one. sorry took so long to get back Ray
_____________________________
My Blog http://www.rcgroups.com/forums/member.php?u=9311 http://airrayinc.com
