RE: The new Tornado sport jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Aviation Design Super Scorpion
Seller:  Modellbau USA
Details:   $6,750.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: The new Tornado sport jet
Page: <<   < prev  69 70 [71] 72 73 74 75 76 77 78   next >   >>
Login
RE: The new Tornado sport jet - 12/1/2011 4:10 AM
MrPheer
Score: 120
Last Login: 5/24/2013
Status: offline
My Tornado arrived today. I had originally ordered the red & white one but was then told they were out of stock, so I had to settle for the grey & orange. I'll be repainting & recovering.
Hide Signatures
(in reply to DrYankum)
       Post #: 1751
RE: The new Tornado sport jet - 12/1/2011 7:09 AM
Boomerang1
Score: 120
Last Login: 5/25/2013
Status: offline
quote:
Not quite sure I understand how you do this...can you supply a photo showing the release point ?
I use a nail file as shown.
I slide it down between the side frame & trunion then lever the sliding bar along using the plastic end of the cylinder as the fulcrum. - John.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 1752
RE: The new Tornado sport jet - 12/1/2011 1:56 PM
DrYankum
Score: 100
Last Login: 5/22/2013
Status: offline
Thanks John....I will give that a try
Hide Signatures
(in reply to Boomerang1)
       Post #: 1753
RE: The new Tornado sport jet - 12/1/2011 2:55 PM
essyou35
Score: 100
Status: offline
Is TBM the only place to buy the tornado?
Hide Signatures
       Post #: 1754
RE: The new Tornado sport jet - 12/1/2011 3:22 PM
dmscpu
Score: 100
Status: offline
quote:
ORIGINAL: MrPheer
Congrats! Sorry to hear about the color, white and red does look good.
Mike in AL
Hide Signatures
(in reply to MrPheer)
       Post #: 1755
RE: The new Tornado sport jet - 12/1/2011 3:27 PM
dmscpu
Score: 100
Status: offline
quote:
ORIGINAL: skydve76
The only dog in town right now, and only gray and orange with red canopy ..
Mike in AL
Hide Signatures
(in reply to essyou35)
       Post #: 1756
RE: The new Tornado sport jet - 12/1/2011 3:28 PM
dmscpu
Score: 100
Status: offline
quote:
ORIGINAL: skydve76
Is TBM the only place to b uy the tornado?
There is a good used one for sale in Alabama.
Mike in AL
Hide Signatures
       Post #: 1757
RE: The new Tornado sport jet - 12/1/2011 7:17 PM
dabevan
Score: 100
Last Login: 2/26/2013
Status: offline
Hi,
I've got a spare Jetcat P80SE - I know its more than 18lbs thrust, but since its only 2 ounces heavier than a Kingtech K80 would it be suitable if I dialed it down to 18lbs?
I know it wouldn't be the turbine of choice for this airframe, but would it fit? would it be too heavy? etc..
David Bevan
Hide Signatures
(in reply to dmscpu)
       Post #: 1758
RE: The new Tornado sport jet - 12/1/2011 7:22 PM
bigplumbs
Score: 120
Last Login: 12/20/2011
Status: offline
quote:
ORIGINAL: dabevan
Hi,
David Bevan
Far too big hanging out the end of this plane
Dennis
It ain''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
Hide Signatures
(in reply to dabevan)
       Post #: 1759
RE: The new Tornado sport jet - 12/1/2011 8:54 PM
dmscpu
Score: 100
Status: offline
quote:
ORIGINAL: dabevan
Hi,
David Bevan
Weight wise no problem
Thrust wise FANTASTIC
Dimensions ?????? that would need to be compared to K-80
Mike in AL
Hide Signatures
       Post #: 1760
RE: The new Tornado sport jet - 12/1/2011 9:11 PM
DrYankum
Score: 100
Status: offline
quote:
ORIGINAL: Boomerang1
Tried your method but couldn't slide it in to find the spot so I filled the air supply, retracted the gear, taped the retracts in place with blue masking tape and then disconnected the quick connects. Tape is holding them closed. Not sure how healthy it is for the springs to keep them in that position over time.
Jerry
Hide Signatures
       Post #: 1761
RE: The new Tornado sport jet - 12/2/2011 2:35 AM
MrPheer
Score: 120
Status: offline
quote:
ORIGINAL: dmscpu
True. But I have a friend of a friend that does those really cool vinyl wraps for cars, motorcycles, jetskies etc and I think he is kind of excited with the thought of testing his product on a jet
Hide Signatures
       Post #: 1762
RE: The new Tornado sport jet - 12/2/2011 5:00 AM
SKYPILOT
Score: 100
Status: offline
When i used to use Spring-Air's back in the day,
After the last flight, I would put the plane on stand, retract the gear, zip-tie the strut to the cyl/frame assy., and pack it in the van. Then cut the zip-tie's once home, then repeat the process to go back to the field.
Regards, Scott
Global Jet Club
Hide Signatures
       Post #: 1763
RE: The new Tornado sport jet - 12/2/2011 3:53 PM
essyou35
Score: 100
Status: offline
For people using the k-80, is throttle management necessary on this?  I know the falcon 120 needs to be babied a bith with a 19lb turbine but wasnt sure if this one could take all teh k-80 and dish out.
Hide Signatures
(in reply to SKYPILOT)
       Post #: 1764
RE: The new Tornado sport jet - 12/4/2011 11:19 AM
ModellbauUK
Score: 101
Last Login: 5/23/2013
Status: offline
Just to let you know that you can now buy our range of ModellbauUK products in the UK via our online store section.
Kingtech K80's also available on there
This will will be developed further over time.
Hope you like it.
Ian
www.modellbauuk.com
The Aurora Project
The Kestrel Project
FCT Kevlar & Hopper Tanks
Hide Signatures
       Post #: 1765
RE: The new Tornado sport jet - 12/5/2011 3:08 AM
rcman35
Score: 100
Last Login: 5/9/2013
Status: offline
Finally got my jet running after a month of building and if weather permits we will give it the mainden flight. next week. The amt 180 should be good The kit was ok need alot of work  alot of little things Over all it is nice
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ModellbauUK)
       Post #: 1766
RE: The new Tornado sport jet - 12/6/2011 3:48 AM
Jetfan20
Score: 107
Status: offline
What CG are you guys using? It appears the 12 3/4 is nose heavy is this the case?
Hide Signatures
(in reply to rcman35)
       Post #: 1767
RE: The new Tornado sport jet - 12/6/2011 3:56 AM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: Jetfan20
12 3/4 works fine, it depends on your flying style if you need to adjust it.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
(in reply to Jetfan20)
       Post #: 1768
RE: The new Tornado sport jet - 12/7/2011 8:08 PM
Jetfan20
Score: 107
Status: offline
quote:
ORIGINAL: KC36330
quote:
ORIGINAL: Jetfan20
Thank You, I will use that for starters. Also, Thanks to the guys who posted pics of their motor mount ideas. I used the one supplied, had to modify it a little but my engine fits like a glove.
< Message edited by Jetfan20 -- 12/8/2011 1:24 AM >
Hide Signatures
(in reply to KC36330)
       Post #: 1769
RE: The new Tornado sport jet - 12/9/2011 1:20 AM
4wheelin711
Score: 100
Last Login: 4/9/2013
Status: offline
 Can anyone tell me or recommend a can of orange paint that matches the tornados orange color? Mine came with a mis-matched red canopy and I need to paint it orange to match the plane.
Hide Signatures
       Post #: 1770
RE: The new Tornado sport jet - 12/9/2011 3:24 AM
djrnav
Score: 100
Last Login: 9/1/2012
Status: offline
PPG omni 60376
Hide Signatures
(in reply to 4wheelin711)
       Post #: 1771
RE: The new Tornado sport jet - 12/9/2011 10:01 PM
Dieselman1220
Score: 110
Status: offline
quote:
ORIGINAL: rcman35
THats what I fly mine with I think its a perfect match
Joseph K
Hide Signatures
       Post #: 1772
RE: The new Tornado sport jet - 12/9/2011 10:06 PM
Dieselman1220
Score: 110
Status: offline
quote:
ORIGINAL: rcman35
Joseph K
Hide Signatures
       Post #: 1773
RE: The new Tornado sport jet - 12/13/2011 12:23 PM
MrPheer
Score: 120
Status: offline
quote:
ORIGINAL: djrnav
PPG omni 60376
Thank you. Mine came with a red canopy as well.
Hide Signatures
(in reply to djrnav)
       Post #: 1774
RE: The new Tornado sport jet - 12/13/2011 4:43 PM
4wheelin711
Score: 100
Status: offline
Yeah, thanks djrnav, I cant find this paint anywhere though. Can you tell me were to get it?
Im currently soldering the linkages. What a pain.. Did anyone go a different route on the linkages?
Hide Signatures
(in reply to Dieselman1220)
       Post #: 1775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
