RE: The new Tornado sport jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: The new Tornado sport jet
Page: <<   < prev  106 107 [108] 109 110 111 112 113 114 115   next >   >>
Login
RE: The new Tornado sport jet - 9/30/2012 7:21 PM
ModellbauUK
Score: 101
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: 2FAS
 Yes, the stock tub and canopy are not good fits. I actually purchased two Noray V2 canopies before I knew they didn't fit the V3 well. I will purchase the V3 canopy and tub from Ray.
i agree they are not a good fit but can be made to fit if you use my frame technique.  Very solid and robust when completed.  The fact that the Norray canopies are less likely to split makes them a whole lot easier to work with when pulling them across the fuz canopy aperture.
Ian
_____________________________
www.modellbauuk.com
The Aurora Project
The Kestrel Project
FCT Kevlar & Hopper Tanks
Hide Signatures
(in reply to 2FAS)
       Post #: 2676
RE: The new Tornado sport jet - 9/30/2012 7:49 PM
r 3
Score: 100
Status: offline
This is how I did it for the V1 not very nice looking however it is all hidden and works well. On my Falcon 120 I had 4 screws holding the canopy down a bit of a pain. It is an aftermarket canopy I got from the good old USA can’t remember who from. However it is very good quality and it fitted.
Hide Signatures
(in reply to ModellbauUK)
       Post #: 2677
RE: The new Tornado sport jet - 9/30/2012 9:46 PM
Dblex
Score: 105
Last Login: 5/18/2013
Status: offline
Wow! Changing out a aileron servo after noticing some slop I was testing things when I found a burned up elevator servo! The other servo was operating the elevator on the last flight when I brought her in just cuz she didn't feel right....
225 mg must have been binding....my bad I guess....
Lucky lucky lucky.....
Hide Signatures
(in reply to r 3)
       Post #: 2678
RE: The new Tornado sport jet - 9/30/2012 10:06 PM
joeflyer
Score: 105
Status: offline
Are you using a 5 cell nicad or A123 receiver battery?  Hitec 225's don't like 6+ volts and are notorious for burning out.  Use a 4 cell pack or better yet different servos.  225's don't return to center very well either.
Joe
Hide Signatures
(in reply to Dblex)
       Post #: 2679
RE: The new Tornado sport jet - 9/30/2012 10:34 PM
BaldEagel
Score: 118
Status: offline
Or split the elevator and they will not fight each other.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to joeflyer)
       Post #: 2680
RE: The new Tornado sport jet - 9/30/2012 10:43 PM
Dblex
Score: 105
Status: offline
Yep, got them on 6 volts nimh packs
What can I replace them with???
Hide Signatures
(in reply to BaldEagel)
       Post #: 2681
RE: The new Tornado sport jet - 9/30/2012 11:50 PM
5skyhawk172
Score: 121
Status: offline
Just started putting mine together. Are HS/5245 hitec digital ok for the rudders and elevators using A123 6.6V?
Keith
Hide Signatures
(in reply to Dblex)
       Post #: 2682
RE: The new Tornado sport jet - 10/1/2012 1:07 AM
TUMBLER
Score: 104
Status: offline
I have 5245's on the elevator and 225's on the rudder. I am running dual 1100 a123 packs. I have 15 flights on mine so far.
quote:
ORIGINAL: 5skyhawk172
Keith
Hide Signatures
(in reply to 5skyhawk172)
       Post #: 2683
RE: The new Tornado sport jet - 10/1/2012 6:17 AM
Dieselman1220
Score: 110
Status: offline
5245s will work I almost went with them but Ive heard of alot of people having issues with them, I am a fan hitec servos btw. I ventured out and went with some Airtronics 94820s havent flown the new tornado yet about 80% built but so far they seem plenty strong and seem to center
perfectly, unlike my hitecs that seem to struggle with that sometimes
Joseph K
Hide Signatures
(in reply to TUMBLER)
       Post #: 2684
RE: The new Tornado sport jet - 10/1/2012 8:33 AM
phantom_najd
Score: 100
Status: offline
quote:
ORIGINAL: TUMBLER
Keith
I had Hitec HS-5245MG on the rudders and elevator with LiFe batteries in my V1 tornado that I sold last week and had well over 70 flights with no issues at all. One thing I must clarify, I programmed the elevator servos so that the don't bind at all through out the entire travel.
Azzam
Hide Signatures
       Post #: 2685
RE: The new Tornado sport jet - 10/1/2012 10:26 AM
aquaskiman
Score: 100
Status: offline
If you guys would just split the elevator it would end the binding trouble. The servos would just have to be close not exact and if one fails you have a chance of getting it back.
George
Hide Signatures
(in reply to phantom_najd)
       Post #: 2686
RE: The new Tornado sport jet - 10/1/2012 1:38 PM
Dblex
Score: 105
Status: offline
If anyone has split the elevators, please post a pic!!!!!!!
Hide Signatures
(in reply to aquaskiman)
       Post #: 2687
RE: The new Tornado sport jet - 10/1/2012 1:58 PM
phantom_najd
Score: 100
Status: offline
quote:
ORIGINAL: aquaskiman
You are absolutely right. I just thought about splitting the elevator too late when I was in the pain of programming the servos to match. I had a look into the already glued hinges and there were three of them so for me to split the elevator then, I had to cut and rehinge the elevator and it was easier to continue programming the servos to match. When I start the V3 I would most likely split the elevator, do you have any pics of your setup?
Azzam
Hide Signatures
       Post #: 2688
RE: The new Tornado sport jet - 10/1/2012 2:10 PM
Xairflyer
Score: 105
Status: offline
Put three hinges on each elevator half, no matter how small a surface is you should never use two, loose one and the surface is gone.
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
       Post #: 2689
RE: The new Tornado sport jet - 10/1/2012 3:42 PM
Stobe777
Score: 100
Last Login: 5/21/2013
Status: online
Maidened my V2 / Merlin 90 combo today. Pretty uneventful it was. The model behaves generally well, and with flaps down it crawls. Really an easy model to fly and land. Not very fast as the airframe is quite draggy. Its a bit painful to assemble in the field, mainly because of the tight fuselage and my big hands. The blind nuts in the booms seem to eat the screw's threads. I may redo them and inverse the wing bolts to be fastened from outside.
But, all in all, a working model it is....
TP.
MBA Tornado + Merlin 90, CARF MiG-15 in the works.
T-Rex 800E flybarless. Multirotors. Futaba 18MZ.
Hide Signatures
(in reply to Xairflyer)
       Post #: 2690
RE: The new Tornado sport jet - 10/1/2012 5:01 PM
aquaskiman
Score: 100
Status: offline
There is a post on the falcon thread on how to install wings from the bottom of fuselage
George
Hide Signatures
(in reply to Stobe777)
       Post #: 2691
RE: The new Tornado sport jet - 10/1/2012 5:06 PM
BaldEagel
Score: 118
Status: offline
That was my post on the Falcon thread, I put the T nuts inside the fus and drilled a hole through the wing with a guide tube for a Allen bot into the T nut, I retained the bolt with a lock nut recessed into the wing root, hope that helps, may be able to find the pics if I look long enough, its a long way back in the thread about page 90 or so.
Mike
Hide Signatures
       Post #: 2692
RE: The new Tornado sport jet - 10/1/2012 7:10 PM
jetflyr
Score: 100
Status: offline
In both the Falcon 120 and the Modellbau F-86 threads I posted photos of mine
I thread a bolt into the wing T-nut, then goes through a 1/4" wheel collar mounted to the inside of the fuse, which holds things tight wtih a cap-screw.
Greg
Hide Signatures
       Post #: 2693
RE: The new Tornado sport jet - 10/1/2012 7:29 PM
ModellbauUK
Score: 101
Status: offline
 Oracover codes for the Red White Scheme
White. 21-010-002
ferri red 21-023-002
yellow black scheme
cadmium yellow. 21-033-002
black 21-071-002
hope this helps
Ian
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
(in reply to jetflyr)
       Post #: 2694
RE: The new Tornado sport jet - 10/1/2012 9:57 PM
noray1
Score: 100
Last Login: 2/21/2013
Status: offline
Got it..
Ray
Good judgment comes from experience....
and a lot of that comes from bad judgment...
Hide Signatures
       Post #: 2695
RE: The new Tornado sport jet - 10/1/2012 10:36 PM
5skyhawk172
Score: 121
Status: offline
Hi guys!
This is my first jet and I'm getting ready to buy my first turbine.  I'm looking real hard at the King Tech K100G.  What do you think?
Keith
Hide Signatures
(in reply to noray1)
       Post #: 2696
RE: The new Tornado sport jet - 10/1/2012 11:59 PM
fw190pilot
Score: 100
Status: offline
The K 100 will be a bit to much for it a K 80 is a perfect match for the airframe. Thats what I have on mine easy 7 minutes with some reserve.
Hide Signatures
       Post #: 2697
RE: The new Tornado sport jet - 10/2/2012 12:33 AM
aquaskiman
Score: 100
Status: offline
Hi guys!
This is and fuel burn is the same my first jet and I'm getting ready to buy my first turbine.  I'm looking real hard at the King Tech K100G.  What do you think?
Keith
I would get the K100 you can always turn it down. The weight, size and fuel burn is a little more. But the 100 has 3 lbs more thrust. So it will work in a biger air frame when you move up. Just my 2cents
< Message edited by aquaskiman -- 10/2/2012 12:59 AM >
George
Hide Signatures
       Post #: 2698
RE: The new Tornado sport jet - 10/2/2012 12:46 AM
Sparhawk
Score: 100
Status: offline
Hi guys!
Keith
I would get the K100 you can always turn it down. The weight, size and fuel burn is the same. But the 100 has 2 to 3 lbs more thrust. So it will work in a biger ai frame when you move up. Just my 2cents
Agreed. If it is the same weight and size, get the K100. I have a Rabbit 100, and as far as I'm concerned, it's a perfect match. It never hurts to have more power on tap when you want/need it.
Dan
Oh great are the days my landings = my take-offs....!
Merlin 160, Jet Central Falcon, Rabbit 100
Hide Signatures
       Post #: 2699
RE: The new Tornado sport jet - 10/2/2012 2:58 AM
Modellbau USA
Score: 150
Last Login: 5/22/2013
Status: offline
 Buy any King Tech before Saturday and get $200 off and free shipping Or get Any king tech and get F86D for free. Call ASAP while supplies last. 954-224-1700 or henry@modellbauusa.com
Henry Castellanos
www.ModellbauUSA.com
Hide Signatures
(in reply to Sparhawk)
       Post #: 2700
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
