RE: Gas engines and glow plug nitro engines, differences and can a new engine be born?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> RE: Gas engines and glow plug nitro engines, differences and can a new engine be born?
Page: <<   < prev  1 [2]
Login
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 6:19 AM
SLAYERDUDE
Score: 414
Last Login: 1/9/2013
Status: offline
Not getting "hostile", I used to be the moderator at AE Forums on the MGT and MMGT sections, trust me there are plenty of 8.0 turd engines and mine is set at around 3 turns out from factory between the MSN and LSN for it to run right, but then again I have carb #1.
Not my first rodeo either, I'm guessing there's a #2 above the flywheel on your carb.
Just trying to give you some advice on the FOC, and yes once again I'm frustrated with the POS MGT 8.0 that has broken down just as often as the T-maxxes I've had, thus I'm still a Savage XL guy.
As I've said, when it runs good the MGT 8.0 is an animal, WHEN it runs good.
Since I bought mine back after trading it in for the Savage XL, and after tuning WAAAY richer from stock specs on the bottom it's ran great, until lately...
Hide Signatures
(in reply to The_Shark)
       Post #: 26
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 6:50 AM
The_Shark
Score: 494
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: SLAYERDUDE
Not getting ''hostile'', I used to be the moderator at AE Forums on the MGT and MMGT sections, trust me there are plenty of 8.0 turd engines and mine is set at around 3 turns out from factory between the MSN and LSN for it to run right, but then again I have carb #1.
I never pay attention to how many turns it takes, if i get it to run great and it stays like that i'm happy. the engine has been running great, a little hot, but it's been great, only one flameout running too lean on a 100f day. im not sure what number carb it is, all i know is it has a tall heatsink, so I think its older.
I also rolled it going full speed, it cartwheeled at least 20 times, it TORE the proline extra thick body and bent the roll bar, I flipped it over and it was fine, I hit a cement block doing 30- nothing, ive landed at full throttle- no problem, its been wonderful for me, 100,000 times better than the T-crapp I had.
that mid-speed needle is very important, I notice if i tune the h/s and leave the M/s alone, I will have to adjust the L/s but if i adjust the M/s just a tad, it runs like clockwork- its not a easy engine to tune, and its pretty unconventional, but i'm happy.
I would replace ANYTHING that is worn, I have found out, If you only fix what breaks, it will break, and break and break, because the other parts are very close behind being broken, I replaced the knuckles, bearings, arm mount and diff case before I even ran because I know if I ignored those worn, but still functioning parts it would be nothing but a pile every 5 seconds.
_____________________________
Signature
(Max. 125 chars. 2 lines max)
Hide Signatures
(in reply to SLAYERDUDE)
       Post #: 27
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 7:13 AM
SLAYERDUDE
Score: 414
Status: offline
Some guys get them and they are bashproof, mine was brand new and was tight for about the first gallon or so.. beside breaking body mounts and I fixed that with springs.
Instead of clogging up this thread, here's where you can find all my MGT excursions.
http://www.rcuniverse.com/forum/m_10933009/tm.htm
Hide Signatures
       Post #: 28
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 1:23 PM
rgburrill
Score: 126
Last Login: 5/21/2013
Status: offline
To rmh: smell a problem?  No way.  I love the smell of nitro in the morning.
Hide Signatures
(in reply to rmh)
       Post #: 29
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 1:39 PM
savagecommander
Score: 171
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
The ignition system has little bearing on the temp at which an engine runs; its just coincidence that most ignition engines run on gasoline. Gasoline burns hotter because it doesn't have the cooling qualities that methanol does. Moreover, savagecommander, an ABC would get too hot and lose the piston seal relatively quickly and quit running. For the same reason 4-stroke model engines are AAC or ringed.
4 strokes are ringed because the fuel does not pass through the case- and lubercation is provided through the ring gap. Methanol does have a higher latent heat of vaporization, but the richer stoichometric ratio allows a hotter combustion event than gasoline- that=more power.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 30
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 3:03 PM
Foxy
Score: 2012
Status: offline
Its all about compression and speed of combustion.
Have a read of this...
http://en.wikipedia.org/wiki/Gasoline
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
(in reply to savagecommander)
       Post #: 31
RE: Gas engines and glow plug nitro engines, difference... - 7/18/2012 3:21 PM
MTK
Score: 203
Last Login: 5/22/2013
Status: offline
I bought a 1/5 scale truck with a small gas engine, 26cc, a few years ago. No CDI needed....magneto ignition with mechanical advance; simple simple!! Radio on 2.4 gig necessary and no issues with RFI....
Darned thing is practically impossible to kill and still goes like stink on regular gas and oil mix. Cheap to feed and even cheaper to maintain. No bearing issues, actually no issues of any kind in 5+ years of operation, just lots of fun
On a side matter, a gasoline engine may be operated as a glow engine putting out a bit more power, by mixing about 30% glow fuel with gasoline. That's a 30:70 ratio of 0% nitro glow with about 10% oil, to regular 30:1 gas il. The magneto or CDI would no longer be needed....But, other than that, why would one want to run glow fuel in a gasoline engine? Glow fuel causes the various maintenance issues we all experienced with glow engines. Gasoline does not cause those maintenance headaches
Regards,
MattK
Hide Signatures
(in reply to jonrocat)
       Post #: 32
RE: Gas engines and glow plug nitro engines, difference... - 7/20/2012 8:56 PM
proanti1
Score: 341
Last Login: 1/6/2013
Status: offline
quote:
ORIGINAL: proanti1
quote:
ORIGINAL: savagecommander
The idea is out there though, and there are conversion kits for glow engines to run spark ignition but gasoline is a no-no in an ABC engine.
im curious to why you think that
Ignition engines run a lot hotter than nitro engines. You would need a ringed engine.
... Ignition, meaning a gasoline burning engine, as apposed to a glow engine.
Her name was Lola. She was a show girl.
Hide Signatures
       Post #: 33
RE: Gas engines and glow plug nitro engines, difference... - 7/21/2012 4:02 AM
SLAYERDUDE
Score: 414
Status: offline
quote:
ORIGINAL: proanti1
quote:
ORIGINAL: proanti1
Technically "Ignition" is when the fuel ignites, whether spark induced or not, including a result of heat and compression...
Tell me a diesel engine does not rely on ignition to produce power, or even a rocket for that matter.
Ignition don't always mean that it burns gasoline, chief.
So, you are all wrong!
Hide Signatures
(in reply to proanti1)
       Post #: 34
RE: Gas engines and glow plug nitro engines, difference... - 7/21/2012 2:16 PM
proanti1
Score: 341
Status: offline
In the model aviation world, ignition means gasoline burning, whereas glow means nitro. It's just a term. Probably derived from the fact that gasoline burning engines rely on an ignition system other than compression and platinum.
Regardless, we're arguing semantics, chief.
Hide Signatures
       Post #: 35
RE: Gas engines and glow plug nitro engines, difference... - 7/21/2012 3:59 PM
SLAYERDUDE
Score: 414
Status: offline
That's why we're here isn't it?
Hide Signatures
       Post #: 36
RE: Gas engines and glow plug nitro engines, difference... - 7/22/2012 6:03 AM
The_Shark
Score: 494
Status: offline
I'm here to pick up some Chix
.....no luck yet
Signature
Hide Signatures
       Post #: 37
RE: Gas engines and glow plug nitro engines, difference... - 7/22/2012 1:27 PM
1QwkSport2.5r
Score: 155
Status: offline
I guess I should have gotten more specific in my last post and said Spark Ignition, instead of ignition.
I kinda feel like Darzeelon's spirit is roaming the forums...
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
       Post #: 38
RE: Gas engines and glow plug nitro engines, difference... - 7/25/2012 5:40 PM
Paulino01
Score: 100
Last Login: 5/14/2013
Status: offline
Hi to all,
 I had problems with my computer, i muste  buyed a knew motherboard and know i´m going to read your msg´s and after i´ll respond to all!
 Stay well, Paulino
Hide Signatures
       Post #: 39
RE: Gas engines and glow plug nitro engines, difference... - 9/7/2012 6:59 PM
Paulino01
Score: 100
Status: offline
Hi to all,
Tell me please and if you do´t mind ; the diameter of the  "spiral coil" of the 70´s FAI engines plugs is the same of the normal nitro glow plugs?!
 Best regards to you and to all here,
 Paulino                          Aveiro city :-) -  Portugal
Hide Signatures
       Post #: 40
RE: Gas engines and glow plug nitro engines, difference... - 9/8/2012 3:55 AM
downunder
Score: 123
Last Login: 5/20/2013
Status: offline
MWAHAHAAA...thanks for that...coffee all over my keyboard
As for the coil used in glow plugs for FAI engines, they're the same as used in glow engines that have nitro added to the base fuel but will normally be a hotter heat range than is generally used for a fuel with nitro added. FAI (no nitro fuel) engines are still used today but it only applies to 3 classes of international competitions, control line speed, RC pylon and free flight power. These 3 classes rely on ultimate engine power for performance so what's called FAI fuel (80% methanol and 20% castor) is used to exclude any exotic (and dangerous) fuels.
Hide Signatures
       Post #: 41
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
