RE: New Krill Spark Evo I- Build Thread.....    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: New Krill Spark Evo I- Build Thread.....
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: New Krill Spark Evo I- Build Thread..... - 12/22/2010 3:52 PM
Mvelez
Score: 100
Last Login: 5/23/2013
Status: offline
hello!
most (I'd say 60% or 70%) of the noise of an outrunner is made entirely by the prop tips. the falcon hobby 21 x 14 is ver efficient on this matter (i've been using it for like a month now. In our tests, and subsequently, my opinion, the real noise of the motor itself, say q80, q60, AXI, plett 30-10 is nothing compared to the real noise generator: the propeller. if you stand by the side of the propeller while turning and see the tip going back and forth from the propeller plane, that is generating a lot of noise. you do not see this on carbon props since they are much more sturdy.
two other things affect total final noise:
construction of the fuselage: wooden (say japanese or home made) kits are more silent than composite kits, like an integral, a spark or a Xigris. these last fuses work like a drum magnifying the vibrations in a sound box. BH made us realize this issue here in Colombia
how sturdy the firewall is: we've tried from an 1/8" lite ply one side glass laminated firewall, 1/8" lite ply one side glass laminated with a carbon rod firewall on the back, up to the 1/4" carbon fiber laminated plywood. this makes a real difference. you feel these effects specially on the integrated loop in the figure M, on the vertical 8 before the spin, etc.
but for the motor itself, alone: the outrunners are all so silent it makes no difference. even for the chinese (ok these are a little louder but not significant). when you hear an e plane at cruise speed you only hear an aerodynamical noise, just the sound of air.you hardly hear the noise of a bearing or the motor itself.
I remember my father fighting the noise in a Curare and on an Arrow while he had a Webra 61 Long stroke rear exhaust and a tuned pipe. they fought the noise a lot with the propeller selection.
Andrew, I did not mean to hijack the thread sorry...
Can't wait to see the Spark Evo on the air!
Marcelo Velez
Hide Signatures
(in reply to flyboy91)
       Post #: 51
RE: New Krill Spark Evo I- Build Thread..... - 12/30/2010 10:45 PM
Spark09
Score: 100
Last Login: 5/22/2013
Status: offline
 Here are the weights of my Evo:
Fuselage: 776 grams
Canopy: 171 grams
Bellypan: 67 grams
Right wing: 378 grans
Left wing: 377 grams
Right stabilizer: 126 grams
Left stabilizer: 124 grams
Landing gear: 122 grams
Wheelpants: 43 grams
Not very light, but ok.
Should be no problem to get it within the 5050 grams limit.
Hide Signatures
(in reply to Mvelez)
       Post #: 52
RE: New Krill Spark Evo I- Build Thread..... - 12/31/2010 6:07 AM
joenella
Score: 100
Last Login: 1/14/2013
Status: offline
quote:
ORIGINAL: Spark09
Fuselage: 776 grams
Canopy: 171 grams
Bellypan: 67 grams
I think that is very light - lets do some math:
Motor (Q80) = 630 gr
ESC = 70 gr
Prop = 70 gr
Wheels = 15 gr
Servoes = 210 gr
Ext cables. = 70 gr
Pull - Pull = 10 gr
Links inc rods = 30 gr
Battery tray = 20 gr
Glue = 30 gr
Batteri = 1150 gr
Receiver = 25 gr
Receiver battery = 70 gr
Total flying weight = 4584 gr.
I think that is a very very low weight, not easy to get lower.
Hide Signatures
(in reply to Spark09)
       Post #: 53
RE: New Krill Spark Evo I- Build Thread..... - 1/4/2011 9:40 PM
kochj
Score: 143
Status: offline
Glow may be dying but gasoline is live and well... How much in US dollars for the gas version?
_____________________________
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to joenella)
       Post #: 54
RE: New Krill Spark Evo I- Build Thread..... - 1/5/2011 8:53 PM
Jason Arnold
Score: 100
Status: offline
It's a little porky. Your estimated weights are a little on the low side compared to actual weights.
He's going to need to watch his weights if using the Q80 for sure. Use an Excel spreadsheet to get a better idea of the final weight.
Cheers,
Jason.
Hide Signatures
       Post #: 55
RE: New Krill Spark Evo I- Build Thread..... - 1/6/2011 12:24 PM
Spark09
Score: 100
Status: offline
 Here are the parts I intend to use:
Plettenberg Advance 565 grams
Schulze Future M 32.80+ 70 grams
2x JR DS3328 for elevator 2x 27 grams
2x JR DS8231 for ailerons 2x 49 grams
1x JR DS 8810 for rudder 65 grams
Power box digi switch 16 grams
Weatronic Smart 8 reciever 15 grams
Hyperion CX 4000 mAh 10s lipo 1015 grams
Hyperion 850 mAh 2s rx battery 49 grams
Aileron servo extension leads 8 grams
Self made rudder servo tray 3 grams
PT carbon prop 21x12WE 79 grams
Phillipe Marquette spinner carbon 29 grams
Hide Signatures
(in reply to Jason Arnold)
       Post #: 56
RE: New Krill Spark Evo I- Build Thread..... - 1/6/2011 5:28 PM
joenella
Score: 100
Status: offline
quote:
ORIGINAL: Spark09
Total together with the kit 4250 gr
Hide Signatures
       Post #: 57
RE: New Krill Spark Evo I- Build Thread..... - 1/6/2011 6:51 PM
elan120
Score: 100
Status: offline
Hi Spark09,
When you get a chance, could you advise the weight of the following components?
Rudder
Wing tube
Stab tube
Thank you,
Kevin
quote:
ORIGINAL: Spark09
Fuselage: 776 grams
Canopy: 171 grams
Bellypan: 67 grams
Hide Signatures
       Post #: 58
RE: New Krill Spark Evo I- Build Thread..... - 1/6/2011 10:43 PM
Spark09
Score: 100
Status: offline
Hello Kevin,
I don't have the wing tube yet because Krill forgot it, they will send it to me.
Tomorrow I will weight the components for you
Hide Signatures
(in reply to elan120)
       Post #: 59
RE: New Krill Spark Evo I- Build Thread..... - 1/7/2011 12:45 AM
Jason Arnold
Score: 100
Status: offline
They forgot your wing tube?
How did they assemble it in the photos you posted?
Do you think 4000mAh will be enough battery for the Advance in-runner?
Cheers,
Jason.
Hide Signatures
       Post #: 60
RE: New Krill Spark Evo I- Build Thread..... - 1/7/2011 1:33 AM
elan120
Score: 100
Status: offline
Spark09,
Thank you. Looking forward to your information.
Kevin
quote:
ORIGINAL: Spark09
Hello Kevin,
Hide Signatures
       Post #: 61
RE: New Krill Spark Evo I- Build Thread..... - 1/7/2011 12:02 PM
Spark09
Score: 100
Status: offline
Used a smaller wingtube just for the photos.
I hope so, but I don't know for sure.
With my C50 with 22x12E prop I can fly the F11 sequence with ease on a 4000mAh pack.
Hope the Advance will use the same amps as the C50..
quote:
ORIGINAL: Aussie_Knife_Edge
Cheers,
Jason.
Hide Signatures
       Post #: 62
RE: New Krill Spark Evo I- Build Thread..... - 1/7/2011 5:35 PM
Spark09
Score: 100
Status: offline
quote:
ORIGINAL: elan120
Hi Spark09,
Rudder
Wing tube
Stab tube
Thank you,
Kevin
quote:
ORIGINAL: Spark09
Fuselage: 776 grams
Canopy: 171 grams
Bellypan: 67 grams
Rudder: 71 grams
Stabilizer tube 16 grams
When I get my wingube I will post the weight for you..
Hide Signatures
       Post #: 63
RE: New Krill Spark Evo I- Build Thread..... - 1/7/2011 6:31 PM
elan120
Score: 100
Status: offline
Spark09,
Thank you for the information, and appreciate your help.
Looking forward to the wing tube weight when you have it.
Kevin
Hide Signatures
       Post #: 64
RE: New Krill Spark Evo I- Build Thread..... - 1/25/2011 8:54 PM
lyka
Score: 100
Last Login: 1/30/2012
Status: offline
Hey guys..
Today has arrived ...
First steps in the assembly.
GREY background values are for catalog and / or estimated in this thread.
Rest of actual values obtained in this kit for me
more coming soon
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
BLOG:
http://jonathangirabel.blogspot.com/
Hide Signatures
       Post #: 65
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 4:29 PM
Torben Parsberg
Score: 100
Last Login: 3/14/2013
Status: offline
Hi
nice plane
its only4771g
you have 2* stabilizer tube
Hide Signatures
(in reply to lyka)
       Post #: 66
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 4:33 PM
lyka
Score: 100
Status: offline
quote:
ORIGINAL: Torben Parsberg
Hi
nice plane
its only4771g
Ohhh...!!!...most best...-17grs. !!!!..thank you !!!!
BLOG:
Hide Signatures
(in reply to Torben Parsberg)
       Post #: 67
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 4:49 PM
flyboy91
Score: 105
Status: offline
I have received my spark Evo as well!! It looks amazing!! The fit and finish is even better than my sparks I have now. I have started working on the wings and stabs. The chin cowl and canopy are mounted. I have decided that I'm going to put a C50-14xl in this model as it's a worlds year I want to use equipment that I have used and know. This was a tough decision to make but its what I felt was best for my situation.
I'm actually driving right now to Yuma az for work so I dropped the evo off to darin peirce a great pattern pilot and builder to finish up. Once I'm back I'll give flight reports!!
Andrew
Hide Signatures
       Post #: 68
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 6:34 PM
geoflys
Score: 100
Last Login: 1/31/2013
Status: offline
Andrew,..Looking forward to flight reports and some photos!....Is the new Spark in "your scheme" ?!!
George
Hide Signatures
       Post #: 69
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 6:37 PM
Doug Cronkhite
Score: 105
Status: offline
quote:
ORIGINAL: flyboy91
Andrew
Ugh.. Yuma? On Purpose? I spent 13 months there with my father when I was a kid at MCAS Yuma..
Doug Cronkhite
Hide Signatures
       Post #: 70
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 8:34 PM
jon bruml
Score: 100
Last Login: 5/21/2013
Status: offline
Lyka
Can you please provide some details on how you plan to mount the q80. My Evo 1 arrived today and I also am planning to use the q80
thanks
Jon
Hide Signatures
(in reply to lyka)
       Post #: 71
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 9:15 PM
lyka
Score: 100
Status: offline
quote:
ORIGINAL: jon bruml
Lyka
thanks
Jon
Jon .....
Simply mount to the front with four screws M4 (on a 2mm carbon backplate) and from behind with a 10 mm dowel inserted into a backplate of 2 mm. This dowel was inserted into the rear bearing motor .
I seems to be no need to hold back, but for security reasons ,I consider it important.
Not be much weight gain.
If you believe another good system will be taken into consideration.
I enjoyed watching the quality of this new design is exceptional.
I feel good feelings.
The removable hinge system at the rudder is a great idea, which will save space in transport boxes, among others things.
cheers.
Andres Girabel. ( the builder)
BLOG:
Hide Signatures
(in reply to jon bruml)
       Post #: 72
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 9:29 PM
jon bruml
Score: 100
Status: offline
Andres
Thank you for the speedy response. Although I have not seen a Spark before the quality of this plane seems quite impressive
To be clear you are mounting directly to the nose of the plane with 4mm bolts? Are you placing the 2mm carbon plate between the motor and the spinner ring inside the plane?
Hide Signatures
(in reply to lyka)
       Post #: 73
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 9:43 PM
flyboy91
Score: 105
Status: offline
Yes the new spark is in my scheme!! I'm very excited to fly this production airplane as I have high expectations for it!!
Doug,
Yea Yuma for some Uav testing! Should be fun.
Hide Signatures
       Post #: 74
RE: New Krill Spark Evo I- Build Thread..... - 1/26/2011 10:26 PM
rcpattern
Score: 100
Status: offline
I'm sure the weather will be better in Yuma than it is in Utah right now.
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.798RCU1
