RE: *Official* Caldera 10E Video, Picture And Discussion Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: *Official* Caldera 10E Video, Picture And Discussion Thread
Page: <<   < prev  2 3 4 5 6 7 8 9 10 [11]
Login
RE: *Official* Caldera 10E Video, Picture And Discussio... - 1/15/2013 2:43 AM
Dads like rc too
Score: 540
Last Login: 5/26/2013
Status: offline
quote:
ORIGINAL: micah11
I can't seem to find any 8.4v batteries that fit, what did you use? Also, I'm looking to get a good body for it. Does Proline make any that fit the Caldera?
I've used these before http://www.ebay.com/itm/Racers-Edge-8-4-Volt-5000mAh-NiMH-7-Cell-Hump-Style-Battery-Pack-with-Traxxas-HC-/350571414823?pt=US_Character_Radio_Control_Toys&hash=item519faf4527
I have Traxxas connectors on all my ESC's so these work fine. If your still running bullet connectors you'll have to cut and solder new ends.
_____________________________
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
(in reply to micah11)
       Post #: 251
RE: *Official* Caldera 10E Video, Picture And Discussio... - 1/15/2013 2:49 AM
Dads like rc too
Score: 540
Status: offline
Forgot about the body question. I have a Volcano body on my son's Caldera right now, it's a little small. Not sure about Proline but the Traxxas Stampede body fits good.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Dads like rc too)
       Post #: 252
RE: *Official* Caldera 10E Video, Picture And Discussio... - 1/17/2013 6:09 AM
cuffs50
Score: 100
Last Login: 1/17/2013
Status: offline
 What is a good wheelie bar for the caldera? Will it be necessary once I upgrade to a 2s Lipo battery? What brand tires and rims will fit on it as I'm looking to upgrade them. I'm loving it so far but craving a little more speed. Any upgrades in addition to the wheelie bar I can put on for some increased stability/control? Thanks for any input.
Hide Signatures
       Post #: 253
RE: *Official* Caldera 10E Video, Picture And Discussio... - 1/17/2013 7:59 PM
micah11
Score: 100
Last Login: 3/27/2013
Status: offline
I'm going to upgrade to lipos, but I know practically nothing about them, other than the MaH is how much runtime you get. I see the imax b6 charger copy for $16, is there a difference between this and the genuine one?  I want a 2S lipo, but what C rating should I get?
Hide Signatures
(in reply to cuffs50)
       Post #: 254
RE: *Official* Caldera 10E Video, Picture And Discussio... - 1/17/2013 9:17 PM
Dads like rc too
Score: 540
Status: offline
quote:
ORIGINAL: micah11
The C rating kind of tells how fast the battery can discharge , the higher the C rating, the more power the battery can dump . The sky is the limit with the C rating. Most of us use 30-40 C lipos. I can link you to what I have when I get home but it's a Turnigy 30-40 C lipo. You can get them from Hobbyking for about $22 shipped. I think it's a 4000 or 4400 mah. My son gets 25 minutes out of it in his Caldera 10e. I'm not sure about that charger, I use a Hitec. I'm sure nitrosports will jump in here and be able to tell you more than I can about the charger. He's the guy to ask about electric, I run mostly nitro.
Hide Signatures
       Post #: 255
RE: *Official* Caldera 10E Video, Picture And Discussio... - 2/20/2013 2:20 AM
PetRock
Score: 100
Last Login: 5/23/2013
Status: offline
I've never seen a commercial wheelie bar for the Caldera, but I don't think you'll need one. The Caldera has a low chassis compared to other trucks (i.e. Traxxas Slash or Stampede) so it wants to wheelie less. I'd try it without one... or maybe even buy a second front bumper (the extra loop that goes out front on the SC 10E) and put it on the back to drag.
For rims anything for a Stampede 4wd or Stampede 2wd fronts (not rears) would fit (they're all the same size). Those are all 2.8" rims and there are tons of tires for them since Traxxas is sold everywhere. For example these are stock Stampede rims with ProLine Badlands tires on a Caldera SC 10E (thread here)
Or, any 1/10th-scale Short Course rims and tires will also fit - all the tires are the same size (2.2" outside, 3.0" inside"). Rims for something like an HPI Blitz (rear) will make it a bit wider, for a Slash 4wd they're just about the same, and for something like an Associated SC10 2wd (rear) your Caldera will be a bit narrower: your choice! If you already have the SC 10E you'll notice regular SC tires are a bit shorter but the rims are the same (here's stock Associated SC10 2wd rubber on the left and Caldera SC 10E rubber on the right)
For more speed I'd check earlier in the thread. For about $5 you can try a pinion with an extra tooth or so, and if you're willing to spend a bit more there are several good motors and ESC's from HobbyKing or HobbyPartz (or go all the way and drop in a 1/8th-scale motor ). To begin with switch to lipo: once you've made that change you'll never want to run NiMH's again (again look earlier in the thead for some good batteries: I like HobbyKing Turnigy nano-techs)
Hide Signatures
       Post #: 256
RE: *Official* Caldera 10E Video, Picture And Discussio... - 4/19/2013 11:50 PM
hemlock1
Score: 100
Last Login: 5/25/2013
Status: offline
Help please,
On my new redcat caldera sc 10e i plugged in the battery and smoke and small fire started from the ESC. Assume I burned the esc but why?
I guess I need to replace the esc but does anyone think it's another reason/part? I was running all stock, straight from box, incl 7.2v NiMH battery. Had approx 3 batteries of running several weeks ago and was to be the first run of the day.
Hide Signatures
(in reply to kchobbies)
       Post #: 257
RE: *Official* Caldera 10E Video, Picture And Discussio... - 5/20/2013 9:23 PM
Eg-r
Score: 100
Last Login: 5/22/2013
Status: offline
Will the wheelie bar on the valcano fit the caldera 10e?  I can find any wheelie bar for a caldera 10e. Anyone know of a place?
Hide Signatures
(in reply to Allnighters)
       Post #: 258
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
