RE: TURBINE OIL    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Fly Eagle Jet F-16 Project, 1/5.5 Scale, includes turbine - ARF
Seller:  Screamin Eagle
Details:   $6,300.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: TURBINE OIL
Page: <<   < prev  1 [2]
Login
RE: TURBINE OIL - 11/13/2010 5:08 PM
vpower
Score: 102
Last Login: 9/23/2012
Status: offline
*i am not trying to ruin this post but since its fuel related ima ask lol*(sry if i ruined to post)
where can i get the fuel for the turbine motor and what is it made of?(again sry if i ruined the post )
_____________________________
lOo nissan oOl
_(0 [::::] 0)_
Hide Signatures
(in reply to Zagzoo)
       Post #: 26
RE: TURBINE OIL - 11/13/2010 5:09 PM
gruntled
Score: 100
Last Login: 3/25/2012
Status: offline
kerosene or Jet-A
Hide Signatures
(in reply to vpower)
       Post #: 27
RE: TURBINE OIL - 11/13/2010 7:50 PM
vpower
Score: 102
Status: offline
both ^^
lOo nissan oOl
_(0 [::::] 0)_
Hide Signatures
(in reply to gruntled)
       Post #: 28
RE: TURBINE OIL - 12/1/2010 9:26 PM
Pegasus
Score: 100
Last Login: 6/6/2013
Status: offline
is this the right stuff?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Son of a.............................that'll leave a mark.
CF
Hide Signatures
       Post #: 29
RE: TURBINE OIL - 12/1/2010 11:59 PM
hooker53
Score: 100
Last Login: 6/19/2013
Status: offline
Pegasus, Yes-Thats what I been using. Good stuff. Roy
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to Pegasus)
       Post #: 30
RE: TURBINE OIL - 12/2/2010 12:05 AM
Pegasus
Score: 100
Status: offline
I will give it a go, thanks
CF
Hide Signatures
(in reply to hooker53)
       Post #: 31
RE: TURBINE OIL - 12/2/2010 1:47 AM
rcjetsaok
Score: 135
Status: offline
IIs anybody useing the Mobil DTE 24 Light in AMT engines????
Danno
The Hobby Express - Jet Central Tejas
Hide Signatures
       Post #: 32
RE: TURBINE OIL - 12/2/2010 4:41 PM
asimace
Score: 100
Last Login: 5/21/2013
Status: offline
Hi guys,
in Italy I managed to find this 20 litre can.
It's marked Mobli DTE Oil Light and not Mobil DTE 24...
Is it the same stuff?
Thanks, Mauri
Click for fullsize
Hide Signatures
       Post #: 33
RE: TURBINE OIL - 12/18/2010 4:11 AM
chad_voelkel
Score: 100
Last Login: 4/5/2011
Status: offline
What are you guys ratio are you guys mixing at. I know it is a stupid question
Hide Signatures
(in reply to asimace)
       Post #: 34
RE: TURBINE OIL - 12/18/2010 4:12 AM
chad_voelkel
Score: 100
Status: offline
New to turbines getting a Wren 54
Hide Signatures
(in reply to chad_voelkel)
       Post #: 35
RE: TURBINE OIL - 12/18/2010 5:25 AM
highhorse
Score: 116
Status: offline
Chad, just go with the ratio Wren says rather than what other guys are doing in other brands.
RCU Rocks, I''d hate to be without it !!
Hide Signatures
       Post #: 36
RE: TURBINE OIL - 12/18/2010 1:33 PM
joeflyer
Score: 105
Status: offline
Wren recommends 3% oil. I mix 3.5 to 4% in mine just to be a bit on the safe side.
Joe
Hide Signatures
(in reply to highhorse)
       Post #: 37
RE: TURBINE OIL - 12/18/2010 2:24 PM
hooker53
Score: 100
Status: offline
I mix one Qt. to five Gals of Jet-A in whatever I'm gonna run it in!!! In the Summer I Alt. between 5 Gals of Jet-A and K1 Kero. In the winter month's I burn Jet-A all the way. for the past two years I have use mostly Mobile DTE Lite 24 for turbine oil.
< Message edited by hooker53 -- 12/19/2010 11:41 AM >
Hide Signatures
(in reply to joeflyer)
       Post #: 38
RE: TURBINE OIL - 12/19/2010 8:56 AM
chad_voelkel
Score: 100
Status: offline
Thanks for all the responses. Im going to pick up my jet today!
Hide Signatures
       Post #: 39
RE: TURBINE OIL - 12/19/2010 9:29 AM
Boomerang1
Score: 120
Status: offline
I run Wrens (SS & MW44's) at the recommended 3%, no problems at all.
Using the DTE light. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 40
RE: TURBINE OIL - 12/22/2010 3:17 PM
gooseF22
Score: 103
Last Login: 6/13/2013
Status: offline
The wren 54 family can run at 3%-5%. Its in the manual.. RB runs DTE light at the shop if that helps. A few guys run DTE medium at 5%, since its easier to get in gallon jugs.
there are alot of excellent oils, just do a test by mixing some in a small jar and let it sit... if it separates, do not use it..
I run AMSoil synthetic two stroke and dTE light. I ran AMsoil this past season as a test. I ran SAber.. it worked fine at 3%. 5% its a little thick but still worked ok.. 4% was the optimum for all my turbines. THis season, I will probably running the AMSoil Dominator racing oil. Im making sure these oils are good for bearing wear. so far so good. Saber has a very high flash point, so it leaves a little oily residue. again, not bad for bearings though, but i was trying to find the balance. I was the only one running it in my bunch, so we could compare. No fuel/oil related issues seen..w the AMSoil though..
I had to get away from the real turbine oils because they were eating at my hands/skin..
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to Boomerang1)
       Post #: 41
RE: TURBINE OIL - 12/22/2010 3:30 PM
siclick33
Score: 125
Status: online
The 2 oils mentioned here (DTE 24 and DTE light) aren't the same. They are listed separately on the Mobil website. What the difference is I don't know but it isn't just that they are in different cans.
For what it's worth, I have been using the stuff in asimace's post and it seems ok. I haven't run that many hours on it though.
It was all going really well, then I suddenly ran out of talent!
Hide Signatures
(in reply to gooseF22)
       Post #: 42
RE: TURBINE OIL - 12/22/2010 4:27 PM
gooseF22
Score: 103
Status: offline
Im looking for a DTE light source in my area. Grainger is 110$ per 5 gal... I know it can be had cheaper somewhere..
Goose
Hide Signatures
(in reply to siclick33)
       Post #: 43
RE: TURBINE OIL - 2/6/2011 5:42 PM
rcjetsaok
Score: 135
Status: offline
DTE, DTE Lite, Mobil Jet II , Aeroshell 500...... Will it all work in all engines...??? What is the difference in the DTE and DTE Lite, and which one should we use.??? I am flying AMT and was wondering about switching from Aeroshell 500... Does anyone have a list of Engine Mfg's and what oil is approved for each ???... Dazed and Confused.... AGAIN !!!!
Danno
Hide Signatures
       Post #: 44
RE: TURBINE OIL - 2/6/2011 7:01 PM
yeahbaby
Score: 135
Status: offline
if it has the Milspec 23699?? 2399 ....whatever.....then it should be fine amigo. keep the mix ratio the same but as always the AMT boys should be able to answer, give 'em a jingle.
quote:
ORIGINAL: rcjetsaok
Danno
"Audentes fortuna iuvat"
Hide Signatures
(in reply to rcjetsaok)
       Post #: 45
RE: TURBINE OIL - 9/6/2012 5:37 PM
geonato
Score: 100
Last Login: 6/18/2013
Status: offline
                              Hello anyone can tell me if mobil oil dte light is hydraulic?
Hide Signatures
(in reply to yeahbaby)
       Post #: 46
RE: TURBINE OIL - 10/4/2012 1:06 PM
mjunior
Score: 103
Status: offline
quote:
ORIGINAL: geonato
yes.
Hide Signatures
(in reply to geonato)
       Post #: 47
RE: TURBINE OIL - 10/4/2012 2:58 PM
FalconWings
Score: 121
Status: online
Ive been using Mercury Premium Oil TCW-3 at 3%, same stuff they use up north.
All good so far, very clean burning.
If someone tells me not to use on their product, I'll simply switch engine brands. That easy.
http://www.mertenmarine.com/servlet/the-716/mercury-quicksilver-premium-plus/Detail
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to mjunior)
       Post #: 48
RE: TURBINE OIL - 10/4/2012 5:00 PM
ron Sweeney
Score: 100
Last Login: 5/30/2013
Status: offline
I am long retired but remember using Mobil dte light in both Hydraulic and mechanical variable speed gearboxes over 40 years ago so it is not a new oil unless, as is likely, some development has taken place.
I know from my petrol engines how difficult it is to remove exhaust oil residue from my models where I use tt two stroke oil so I have always stuck to turbine oil in my turbines. If there are any bragging rights my Wren ss has completed over 61 hours (4% oil) and Wren just tell me to keep running it. I guess there are lots of turbines with more hours but I have certainly had good value, Ron.
Hide Signatures
       Post #: 49
RE: TURBINE OIL - 10/4/2012 5:54 PM
highhorse
Score: 116
Status: offline
quote:
ORIGINAL: Pegasus
Pegasus,
My answer would be NO, that's NOT the right stuff. Todd at Dreamworks is selling 32 wt, not 24. Perhaps are others using 24(?) but the stuff is already pretty thin at 32, Todd is no dummy, and I wouldn't use a lighter wt.
My two cents,
Don
EDIT: I just realized the thread is pretty old, as is the Q I responded to. Oh well, perhaps the answer still applies to someone out there so I will let it stand.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
