Reload this Page >
TURBINE OIL
TURBINE OIL
Old 11-10-2010, 11:59 AM
GIOMBO
Default TURBINE OIL
hello guys........ i'm looking for purchase a turbine oil, you know alternative for aeroshell500 and mobil jet oil ii?
someone uses the Mobil DTE Light??
thanks........
Old 11-10-2010, 12:17 PM
gruntled
Default RE: TURBINE OIL
I am using DTE light in a Jet Central turbine. Purchased from McMaster Carr.
Old 11-10-2010, 12:28 PM
Pegasus
I can't find it on Mcmaster do you have a part number?
Old 11-10-2010, 12:38 PM
bluescoobydoo
fully synthetic two stroke oil is ok wren recommend it for thier engines, outboard engines use the same oil if that helps
Old 11-10-2010, 12:42 PM
Greg G
Greg G's Avatar
From McMaster.com They have 1 gallon, full case (6x1 gallon), or 5 gallon prices.
search: Mobil DTE Oil
ISO Grade 32
Part no
2158K14
2158K34
Old 11-10-2010, 12:55 PM
Harley Condra
Since you are in Italy, why not ask some of the local jet flyers what they are using, and where they purchase it?
I would think that it would be cheaper to buy it locally than from the USA. You could try your local airport.
Some of the oils that are in use are BP 2380, BP 2197, Mobil II Jet, or any of the other turbine oils that conform to MIL-PRF 23699.
Old 11-10-2010, 02:34 PM
PaulD
My Feedback: (39)
PaulD's Avatar
ORIGINAL: bluescoobydoo
Don't agree. I know some mfrs may have indicated this but the sythetics tend to leave a "gummy" residue that will affect the turbine on start up. A buddy was running H1R oil and burned out four starters on one and was having flame-outs with another. He has since switched to BP and has no problems.
PaulD
Old 11-10-2010, 02:52 PM
Pegasus
This is true with the "gummy" residue, I have noticed it with two cycle oil also, does the DTE do this also?
Old 11-10-2010, 03:02 PM
Robrow
Robrow's Avatar
ORIGINAL: Pegasus
This is true with the ''gummy'' residue, I have noticed it with two cycle oil also, does the DTE do this also?
No, absolutely clean as a whistle even after years of running.
Rob.
Old 11-10-2010, 03:24 PM
Pegasus
After the engine has sat for 6 months does it still spin over as easily as with turbine oil in the fuel mix? Thats were I notice the difference, if I leave the engine for 6 months or so before the next run, I have to flush the turbine with kero because the rotor turns over very slowly due to the bearings being all gummed up.
Old 11-10-2010, 05:12 PM
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
You can also use pacemaker T32 from citco, exact same as mobil dte lite. It is also half the price of dte lite 5 gal pails.
Old 11-10-2010, 08:03 PM
causeitflies
causeitflies's Avatar
ORIGINAL: Zagzoo
Talk to me Franky
I only have a little more than five gallons of DTE left... enough for about 200 gallons of kero [:-]
Where did you find the T32?
Old 11-11-2010, 12:14 AM
John H.
John H.'s Avatar
I have been using chevron gst iso 32 in my p80 for over 1 year (150 gals+) with no problems.
John
Old 11-11-2010, 12:50 AM
sideshow
sideshow's Avatar
Yo, Pleasant Heights.....which engine are you using that stuff in?
Old 11-11-2010, 04:30 AM
Boomerang1
Boomerang1's Avatar
quote:
ORIGINAL: Pegasus
Rob.
I'll second that, had problems with hard starting on 2 stroke oil, fine with DTE light. - John.
Old 11-11-2010, 09:11 AM
rcjets12
My Feedback: (21)
rcjets12's Avatar
ORIGINAL: Zagzoo
Where could you purchase the T32 from and are you guys still using the same mix ratio as with turbine oil.
Old 11-11-2010, 09:28 AM
rcjetsaok
My Feedback: (7)
rcjetsaok's Avatar
I don't care if it's better.... I ain't putting no 2 cycle outboard motor oil in my Turbine Aircraft !!!!! That just ain't right !!!! If I was an a Southwest Airlines flight fixing to push the gate, and I looked out the window and saw maintence putting a quart if Quicksilver Outboard motor oil in the engine.. I would get the hell off the airplane... Pour the same oil in a Aeroshell can, No problem !!!! Outboard oil in your Pride and Joy at the flying field... Thats Ghetto White Trash !!!!
Danno
Old 11-11-2010, 09:33 AM
gruntled
ORIGINAL: Pegasus
http://www.mcmaster.com/#mobil-dte-oil/=9o7k7n
Old 11-11-2010, 11:16 AM
Pegasus
Sweet, thanks for all the info, I will give it a go.
Old 11-11-2010, 12:19 PM
tp777fo
My Feedback: (28)
tp777fo's Avatar
OK Danno..that's bs...I saw you pouring used MacDonalds french fry oil in your gas can. No wonder your jet smells like fried taters!
Old 11-11-2010, 12:52 PM
bluescoobydoo
my wren 54 has 37 hrs on the original bearings still going strong fully synth oil wont harm them at all even if they feel like the are a bit sticky at least you know that they are lubricated and being protected from corrosion while layed up
Old 11-11-2010, 07:04 PM
causeitflies
ORIGINAL: sideshow
Wren SS and Jet Central Super Eagle. I'll probably run it in my old P-60 too when I get that plane off the shelf and going again.
Old 11-12-2010, 02:22 PM
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
ORIGINAL: causeitflies
ORIGINAL: Zagzoo
Talk to me Franky
I bought is thru a oil distrubutor, should be able to find it at any local were citco products are sold. Use the same mix as manufactor calls for. I remember right, it was $45 for a 5gal pal.
Old 11-12-2010, 05:52 PM
joeflyer
My Feedback: (48)
Is this the stuff you guys are talking about? It's called "Citco Pacemaker ST-32".
http://www.docs.citgo.com/msds_pi/C10092.pdf
Old 11-12-2010, 10:45 PM
Zagzoo
My Feedback: (28)
Zagzoo's Avatar
ORIGINAL: joeflyer
Is this the stuff you guys are talking about? It's called ''Citco Pacemaker ST-32''.
This is the stuff: http://www.hkoil.net/product-detail/...aker-T-32.html Not ST-32, just T-32.
