Cam timing on a YS 1.10    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> Cam timing on a YS 1.10
Page: [1]
Login
Cam timing on a YS 1.10 - 11/11/2010 8:24 AM
still4given
Score: 100
Last Login: 5/21/2013
Status: offline
Hi Guys,
One of my 1.10's puts out a little less power than my others. I have been tinkering with it to see if I can get it up with the others. One thing that has puzzled me is why YS didn't mark the cam or crank so that they line up properly. If you set the dot on the crank at 6:00 the dot on the cam will either be at 11:00 or 1:00. This particular engine has been apart before so I am not sure where the cam should be set. When I took it apart the cam was set at 1:00. Thinking this might be the reason I set it at 11:00. Funny thing is that it runs jusut about the same as it did before. Do any of you know which setting is right? Maybe one tooth doesn't matter but I'd like to get it where YS designed it to be.
Thanks, Terry
_____________________________
Live simply. Love generously. Care deeply.
Speak kindly. Leave the rest to God
Hide Signatures
       Post #: 1
RE: Cam timing on a YS 1.10 - 11/11/2010 4:58 PM
tande
Score: 100
Last Login: 5/19/2013
Status: offline
Hi Terry....You may already be aware of this, there is a dot on the crank counter/balance (need to remove backplate to see) that when positioned at 6:00, cam dot then at 12:00....This crank position is just before TDC (yes, I know; why not TDC?)....Anyway at TDC the cam dot will be at 1:00....FWIW
Hide Signatures
(in reply to still4given)
       Post #: 2
RE: Cam timing on a YS 1.10 - 11/11/2010 9:40 PM
Jimmy Skids
Score: 100
Status: offline
ditto.
Spitfire Brotherhood #99
Outlaw Racing CD 2001 to present
Hide Signatures
(in reply to tande)
       Post #: 3
RE: Cam timing on a YS 1.10 - 11/11/2010 10:51 PM
still4given
Score: 100
Status: offline
Thanks Guys,
I will change it back to 1:00. Weird thing is that it runs pretty much identical at 11:00as it did before. Maybe one tooth isn't that important.
Thanks again
Hide Signatures
(in reply to Jimmy Skids)
       Post #: 4
RE: Cam timing on a YS 1.10 - 11/12/2010 4:33 PM
still4given
Score: 100
Status: offline
OK, I took it apart. Here is what I found. If I set the crank at true TDC, I can set the dot on the cam at 12:00. When I do this and then move the dot on the crank to 6:00, the dot on the cam is at 11:00. With the dot on the crank at 6:00 you cannot set the dot on the cam at 12:00. One tooth is at 11:00 and the next tooth is at 1:00. I'll try talking to Richard today and see what he suggests. I'll report back.
Thanks, Terry
Hide Signatures
       Post #: 5
RE: Cam timing on a YS 1.10 - 11/13/2010 2:10 AM
tande
Score: 100
Status: offline
quote:
ORIGINAL: still4given
Thanks, Terry
OK, lets get more accurate...With the crank dot at 6:00, the cam dot should line up with the cam followers...
Hide Signatures
       Post #: 6
RE: Cam timing on a YS 1.10 - 11/16/2010 6:23 AM
still4given
Score: 100
Status: offline
quote:
ORIGINAL: tande
Thanks, Terry
What do you mean by "cam followers"?
If I set the dot on the crank at 6:00 the dot on the cam can not be set to 12:00 or 6:00. It is slightly askew to the right or left. The dot on the cam can only be straight up or down with the crank at true TDC.
Thanks, Terry
Hide Signatures
(in reply to tande)
       Post #: 7
RE: Cam timing on a YS 1.10 - 11/3/2012 4:05 PM
jimca
Score: 100
Last Login: 5/7/2013
Status: offline
trying to reassemble my 110 did the cam/crank alignment ever get confirmed.
cheers
jim
Hide Signatures
       Post #: 8
RE: Cam timing on a YS 1.10 - 11/3/2012 4:18 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
Use the two dots ! That's what they are there for.
Hide Signatures
(in reply to jimca)
       Post #: 9
RE: Cam timing on a YS 1.10 - 11/3/2012 6:05 PM
Dave Harmon
Score: 101
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: jimca
cheers
jim
Jim....follow the description in post #2.
This was confirmed in post # 3 and now in this post.
That's 3 verifications.....I'll bet the paperwork for the engine will show this as well.
Forget Mixing Your Own Fuel....It''s Easy But No Longer Needed!
Hide Signatures
(in reply to jimca)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> YS Engines Support >> Cam timing on a YS 1.10
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.727RCU1
