RE: Don Smith Cessna T-50    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: Don Smith Cessna T-50
Page: <<   < prev  31 32 [33] 34 35 36 37 38 39 40   next >   >>
Login
RE: Don Smith Cessna T-50 - 11/28/2012 7:08 PM
rhsmrt50
Score: 100
Last Login: 4/25/2013
Status: offline
....Thanks, I forgot to mention that............also, I forgot that we talked of this paper procedure earlier it the thread...........but, it helps to mention it again on a different subject....
Rich.
Hide Signatures
(in reply to Murphey)
       Post #: 801
RE: Don Smith Cessna T-50 - 11/28/2012 7:19 PM
rhsmrt50
Score: 100
Status: offline
.....Joel, you mentioned a material that the jet guys use to reflect heat.......do you happen to know the product name?........I would be interested in it to help protect the servo.........I thought of just using a heat barrier between the exhaust and the servo.........
Thanks so much......Rich.
Hide Signatures
(in reply to jdhughen)
       Post #: 802
RE: Don Smith Cessna T-50 - 11/28/2012 10:06 PM
rhsmrt50
Score: 100
Status: offline
.......here is a couple of shots of the lower aft fuselage inspection panel that Murphey and I discussed earlier.....the hardened paper method of making light weight non-stressed parts.......such as any kind of detail parts added......
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 803
RE: Don Smith Cessna T-50 - 11/28/2012 10:20 PM
rhsmrt50
Score: 100
Status: offline
....I hope you guys are kipping up!...........in the meantime, back to the jungle..
here are two photos of the the carb air inlet and filter........as featured on my engines as cooling for the lower cylinder of the OS-160..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to rhsmrt50)
       Post #: 804
RE: Don Smith Cessna T-50 - 11/28/2012 10:30 PM
rhsmrt50
Score: 100
Status: offline
.......Here is ......some funny stuff......then I need to get back to work..........enjoy.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 805
RE: Don Smith Cessna T-50 - 11/28/2012 11:16 PM
rhsmrt50
Score: 100
Status: offline
.....I used to have a dog named Ruuuuuuuuf.........
Hide Signatures
       Post #: 806
RE: Don Smith Cessna T-50 - 11/28/2012 11:18 PM
rhsmrt50
Score: 100
Status: offline
....Here he is.
Click for fullsize
Hide Signatures
       Post #: 807
RE: Don Smith Cessna T-50 - 11/30/2012 9:15 AM
jdhughen
Score: 100
Last Login: 3/27/2013
Status: offline
Rich,
This is a links to the heat stuff I was talking about. one is a fabric blanket and the other is a ceramic coating you can put it on most anything that you want to place between the exhaust and the servo. In my case I put it on some glass fabric but can put it on just about anything like a balsa "shield". You could also use it to coat the inside of your cooling ducts ?? And it's fuel proof.
Blanket
http://shopbvmjets.com/zencart/index.php?main_page=product_info&products_id=30
Coating
http://shopbvmjets.com/zencart/index.php?main_page=product_info&products_id=29
Also Reynolds now makes a teflon coated aluminum foil that you can get in the food store. works great as a non stick surface with your CA/paper process and I've used it for flat sheet glassing ie coated light/med weight glass fabric with resin to make a flat sheet that can be used much like your paper process.
Joel
Hide Signatures
       Post #: 808
RE: Don Smith Cessna T-50 - 11/30/2012 6:01 PM
rhsmrt50
Score: 100
Status: offline
.....Thanks Joel........I especially like the idea of using the ceramic coating............and your suggestion for using it on the interior of the cooling ducts and the fabric blanket could be wrapped around the exhaust where it passes close to the servo.....plus using a ceramic coated barrier........that should work great.........the teflon coated alum is another good idea............I have a huge roll of sticky-back Teflon.......18" wide that I use quite a bit for laminating paper and mounting photos on illustration board, foamcore, etc........so, I have plenty of this backing film...........but, I am also going to try the coated alum...........I worked for the Vought Aircraft Company in Dallas for 31 years......mostly as an illustrator in presentations, technical arts, graphic arts and finally in tool design as an AutoCad illustrator.
......When I went to work at Vought in 1968, our work station was a six foot wide drafting table......no computer......that came along about ten years later..........so, all of our work was done "lick-n-stick".......cut-an-paste to you.........we used the drafting machine and triangles to draw horizontal and vertical lines.......using drafting pencils, ruling pens or repido-graph pens to create those lines, etc.
......anyway, I ended up with a roll of this 3-M double sticky back product that we affectionally called "Mothern-inlaw-paper".........because it was sticky on both sides..............thanks again for your input Joel.
Rich.
Hide Signatures
       Post #: 809
RE: Don Smith Cessna T-50 - 12/8/2012 12:27 AM
rhsmrt50
Score: 100
Status: offline
T-50 update.........
.....Well I am about to finish the right engine........most of the parts for the left engine have also been fabricated....but I am using the right one as the test bed, so all of the changes will have been corrected before installation.....
photos included .........so, sit back and enjoy...
Rich.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 810
RE: Don Smith Cessna T-50 - 12/8/2012 12:45 AM
SpaceRanger
Score: 100
Last Login: 4/28/2013
Status: offline
Looking good!. You ought to sell your dummy engine as a kit.
_____________________________
Michael McMurtrey
Carrollton, TX
Hide Signatures
       Post #: 811
RE: Don Smith Cessna T-50 - 12/8/2012 12:55 AM
rhsmrt50
Score: 100
Status: offline
.....Thanks Mike..................thats a possibility!
Rich.
Hide Signatures
(in reply to SpaceRanger)
       Post #: 812
RE: Don Smith Cessna T-50 - 12/8/2012 2:09 AM
redtail
Score: 105
Last Login: 5/20/2013
Status: offline
Wow, I want to power my Bobcat with two G26's, I would buy two of your dummy engine kits. Really great workmanship Rich. Chic
Never has so many Owed so much To so few.
Hide Signatures
       Post #: 813
RE: Don Smith Cessna T-50 - 12/8/2012 5:34 PM
rhsmrt50
Score: 100
Status: offline
Chic, I did make a set for Murphey.......but, it consisted of the cylinders, crankcases and gear cases only....I think he also installed them on the G26......he installed some detail to finish them enough for his project.............I dont think he had to modify the castings to fit his G26........I can cast the fourteen cylinders , two crankcases and two gearcases along with the alum pushrod tubes if you wish........but, to include the finer detail would be too time consuming..........but as an option, I can install the gearcases to their crankcases with the fine .080 brass hex bolts.......that will give them a more finished look..........take a look back at Murpheys finished Bobcat to veiw his installation.....
Rich.
Hide Signatures
(in reply to redtail)
       Post #: 814
RE: Don Smith Cessna T-50 - 12/8/2012 5:52 PM
rhsmrt50
Score: 100
Status: offline
......Chic, it has taken me a month to get this far on the Right engine.....and, I have barely started on the left one.....but, it should go faster since I have already gone thru the trial and error phase of this endevor.......and, I have been spending as much time per day at the bench as I possibly can.............I still have a few days to go to completion of the right engine............so, here are a few more pic's of my progress...........enjoy.
Rich.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 815
RE: Don Smith Cessna T-50 - 12/8/2012 6:00 PM
rhsmrt50
Score: 100
Status: offline
....This series of photos will show the wire harness manifold....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 816
RE: Don Smith Cessna T-50 - 12/8/2012 6:11 PM
rhsmrt50
Score: 100
Status: offline
.............More photos..
Hide Signatures
       Post #: 817
RE: Don Smith Cessna T-50 - 12/8/2012 9:13 PM
rhsmrt50
Score: 100
Status: offline
....sorry, lets try again....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 818
RE: Don Smith Cessna T-50 - 12/8/2012 9:24 PM
rhsmrt50
Score: 100
Status: offline
More photos...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 819
RE: Don Smith Cessna T-50 - 12/8/2012 9:39 PM
SpaceRanger
Score: 100
Status: offline
That is a piece o' work! I'm gobsmacked!
Michael McMurtrey
Carrollton, TX
Hide Signatures
       Post #: 820
RE: Don Smith Cessna T-50 - 12/8/2012 10:18 PM
rhsmrt50
Score: 100
Status: offline
Thanks Mike............I hope it's not catching!.................I am getting close to painting the parts.....the cylinders and heads will be Satin Black.......the crank and gearcase will be Med Lt Grey.....wires are natural copper color and all of the Alum parts exceept the pushrod housings will be natural Alum.........the pushrod housings will be gloss black.....
Rich.
Hide Signatures
       Post #: 821
RE: Don Smith Cessna T-50 - 12/9/2012 7:04 PM
redtail
Score: 105
Status: offline
Rich, when you finish your engines and get a few moments to breath, go right ahead and make me a set. I'll add the details as Murphy did. Just send me an email to redtailpilot@aol.com with your snail mail address and price plus shipping. You should see the smile on my face. Chic
Hide Signatures
       Post #: 822
RE: Don Smith Cessna T-50 - 12/10/2012 1:07 AM
rhsmrt50
Score: 100
Status: offline
......Except for some final adjustments..........this engine is ready to install..........photos to show the completion....
Rich...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 823
RE: Don Smith Cessna T-50 - 12/10/2012 11:14 AM
redtail
Score: 105
Status: offline
Now that is a work of art. I'm afraid to try that all by myself. Chic
Hide Signatures
       Post #: 824
RE: Don Smith Cessna T-50 - 12/10/2012 3:01 PM
rhsmrt50
Score: 100
Status: offline
.....Finished at last........
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 825
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
