Start working on the Hooben’s T55A!
Knowing that I have built a King Tiger before, my friend asked me to build his newly
acquired T55A for him.
Have a quick look into the box today, building work leaves until tomorrow..
Printing and box art are not bad, with lots of information inside. Box quality is only fair when compare with
those of Tamiya…
Box presentation is the same as of Tamiya, and the photo of the field that toke the sound effect recording is a
nice touch
Tin alloy sprocket wheel and suspension blocks
This seems to be the suspension arm..
The hull and plastic parts are placed inside the box
Dedicated electronics equipment, sound effect claims to be live recorded with a real tank
Aluminum main gun barrel, unlike the shiny look of those provided by Tamiya, the barrel is roughed out to catch
paint better,.
Small box to hold the gear box..
Quality of the hull is ok, but the surface texture could be have been better.
Moldings marks which is a signature on all Russian main gun turrets are presented well and should not be sanded
away later
Road wheels and rubber tires
Road-wheels and aprons
Tracks are not pre-assembled and may be very tedious to get them up..
Some more metal parts
Looks to be a gear box inside the turret
A wood dowel, cannot figure out what it is for at the moment.
More photos later…
those of Tamiya…
nice touch
paint better,.
away later
More photos later…
AB, CANADA
RE: Start working on the Hooben’s T55A!
HMMMm Electronics too.
I left a big hint for my Bride that one of these under the tree would be most welcome. Even left the website open. All she had to do was load it up in the shopping basket!!!!!,
Individual track links though. UG. I have an extra set of T-34 metal tracks. Would these fit??????
I really want one now.
Is there anyone out there making a metal track for the T-55 yet I'm not looking forward to putting them link by link together .
Jimmy
Jimmy
let's go on!
This manual thick book, is a little scary, but according to former experience, the description is largely fake, I always not follow the instructions!
Today first observing body and road-wheels installed.This suspension system about hooben is very special! It is made of metal fixed block connected full sets of suspension system,and then put the fixed block with four screws to vehicles,after all installed,we can feel the bodywork thick texture instead thin!
1)Installation fixed block to vehicle square hole are matched,but it is intevitable to Use smaller file to fix because it's domestic goods not Japanese.If someone to do the wading in functional rbis about the fixed block and bodywork combining parts,in my opinion,you shoud made sealant, after all there are gaps.
2)The suspension system is difficult to installation because of the compact design.
3)At the first when you installation it,you can removal flash,with small fault hem arm shaft plier, so that it could plug into fixed block inside flexible rotation.
4)Then put on spring, again on the limit device, limit device small pillars tucked into fixed block the pores, so swing arm can elastic rotation.
At the end,the card reed is too small to installation that you need with forceps between live stuffed swing arm card slot, 10 rounds clip ten times made me sweat.
5)Special remind: the spacing device is around,do not install wrong like me since of I read the intro.careless.
6)This is a road wheel inside, the first and last road LunDai shock absorber, swinging arm is to take small triangle, don't make a mistake.
I was bursting to installed a gearbox up, using four screws through the bodywork fixed, also is sturdy, gear previous level is plastic.
I don't know what kind of plastic, slippery stiff, behind were of brass, it is to reduce the noise and increase wearability consideration, but who knows if they like hell.
Pack road-wheels photos, road wheels are parted, inside pack a bearing, then glue together,hoho, that's all!
Notice on the metal suspension supports, the left side had 4 'lefts' and one right, the right side has 4 'rights' and one left. However, you can not install them in the wrong position, so this is just FYI.
The wooden dowel is indeed to hang on the back as a ditching beam.
Only maker of T 55 tracks in metal at this time is AFV, but they are a little dear, and I don't know it they will fit the Hooben model.
AB, CANADA
ORIGINAL: sevoblast
How much different is the T-34 tracK???
Also do you think you could order in just a set of wheels and rubber?
Looks good only thing i don't like are the springs they use in the swing arms those types of springs always break,
Also there is a lot of bolts and stuff holding the parts together be sure to use thread lock like tamiya's so everything stays put.
T 34 track is totally different geometry and drive system. The drive sprocket does not use outside teeth, but internal drive lugs on the sprocket. I can order in spare parts, but not until late January.
Senlonco, springs appear to be high quality. I started my build this PM, and I'll be starting a thread shortly. And you are correct, use thread lock for sure, although the suspension support screws do come with lock washers, and flat washers to go on the outside of the plastic hull to give more strength to the screw holes in the plastic.
I know Hooben's been catching a lot of you-know-what over delays and everything, but kudos to them on this kit - from the pictures it looks really, really good and no doubt will build into a very sweet tank.
Hopefully, we'll see the Elefant from them someday soon.
Shep
Shep
I have seen the gear boxes in person. There will be a problem with them. They use "E"clips to hold the gears in place and the clearance between the gears is not enough to clear the clips. This WILL cause the clips to tear into the gears causing failure. Be aware of this and take the proper measures to make certain the clips clear the gears on all shafts.
ORIGINAL: Panther G
I have seen the gear boxes in person. There will be a problem with them. They use "E"clips to hold the gears in place and the clearance between the gears is not enough to clear the clips. This WILLcausethe clips to tear into the gears causing failure. Be aware of this and take the proper measures to make certain the clips clear the gears on all shafts.
ORIGINAL: bigfiver69
Shep
Shep
ORIGINAL: FFR2608
Looks nice. I bet the wood dowel is the simulated tree log that is occasionally hung from the back of the tank.
D
D
ORIGINAL: sevoblast
I don't want to ruffle feathers that much. I was responding to the concern about having to assemble tracks. This is supposed to be model building .....
Jerry
Jerry
AB, CANADA
ORIGINAL: Tanque
Jerry
Jerry
Yes, but nothing says you have to enjoy every aspect of it. Putting together tracks is tedious and time consuming.
There really is no art to it, and the skill of pinning links is mastered quickly. I would pass on calling track pinning an enjoyable part of this hobby. However that is just my opinion and the great thing about a hobby is that it is recreational, and the time you spend on it is yours. How you do that is very much a personal choice.
I am halfway through pinning some 1/35 scale metal tracks. I doubt I will ever get them done. I am happy to find somehting else to work on.
So if someone offers me a kit and there is a choice of assemble your own tracks or they are supplied RTR. I'll take the RTR tracks everytime. However back on topic of this Hooben. It appears as if the tracks are ones you assemble yourself without a choice, so I will have to endure the hardship and tedium Can't be any worse then the slat armor I made for the Leopard.
I would aver that the track assembly will be a cake walk compared to the slat armor, which, by the by, was quite the work of art.
Panther G, my Hooben TU's seem to run grand, no problems from the 'E' clip after a couple hours break in run. We'll see with time. If needs be, it's an easy fix anyway. Daryl has already addressed the problem if needs be, simply and effectively. Think brass tube instead of 'E' clips.
I tested my gear box,although it seems that pick up close, but the actual usage of time should not met!
Any engine sound demo is possible?
