Tires/setup for Indoor carpet short course racing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Tires/setup for Indoor carpet short course racing
Page: [1]
Login
Tires/setup for Indoor carpet short course racing - 11/15/2010 2:57 AM
godofcable
Score: 100
Last Login: 4/20/2013
Status: offline
Won my first ever race today with my 2WD Slash!!
6 trucks: 2 SC10s, 3 Slashes, and a Losi Strike. Indoor carpet track, with homemade jumps.
Had two qualifiers, and the main. In the two qualifiers, I placed 5th and 4th. Then I won the main!
In the first two races, I had trouble keeping it right side up, kept rolling on me. I know, the Slash has a high center of gravity.
It was running great for the first 5 or 6 laps. But it seemed like as soon as the tires got warm it would flip at every turn.
I tried stiffening the suspension, by preloading the springs with spacers. That made it worse. Then I went way soft by taking all of the spacers out. This helped the rollovers, but the problem though was I bottomed out on every jump.
So, I need a happy medium. I know if I make the suspension stiff enough to not bottom out, it's going to flip. So what tire do you guys use on carpet? I need something that'll have some lateral slide, with enough traction that I'll won't just spin the tires when I squeeze the throttle (if that even exists).
_____________________________
www.rcsoup.com - R/C Reviews, News, and Tips
Hide Signatures
       Post #: 1
RE: Tires/setup for Indoor carpet short course racing - 11/15/2010 3:07 AM
FoamyVictim
Score: 141
Last Login: 5/8/2013
Status: offline
Find slicks or a very hard compound. Maybe something like these:
http://www.amainhobbies.com/product_info.php/cPath/1_26_1252/products_id/190586/n/Pro-Line-Street-Fighter-M2-SC-22-30-Truck-Tires-2
Hide Signatures
(in reply to godofcable)
       Post #: 2
RE: Tires/setup for Indoor carpet short course racing - 11/15/2010 4:09 AM
Brainanator
Score: 130
Last Login: 4/23/2013
Status: offline
you can also try dropping the clips out, but then putting much thicker weight oil in the shocks. I'd suggest around 60 weight (30 is stock)
OFNA Jammin CRT.5e, stock sprint 2 drift, Savage Flux (4S), slash (just a roller for now)
Hide Signatures
(in reply to FoamyVictim)
       Post #: 3
RE: Tires/setup for Indoor carpet short course racing - 11/15/2010 4:11 AM
ThunderbirdJunkie
Score: 1040
Last Login: 6/25/2012
Status: offline
Have you considered just doing a Rustler chassis conversion and stretching it with something like the STRC LCG kit?
"Some people can mess up an anvil with a rubber hammer" -46u
If you don''t allow yourself to fail, you''ll never allow yourself to succeed-ThunderbirdJunkie
Hide Signatures
(in reply to Brainanator)
       Post #: 4
RE: Tires/setup for Indoor carpet short course racing - 11/15/2010 4:12 AM
godofcable
Score: 100
Status: offline
i did pull the clips out, which seemed to help. But it was too much, because I kept bottoming out on the jumps.
How about shock position? Any benefits to moving them to a different hole?
Hide Signatures
       Post #: 5
RE: Tires/setup for Indoor carpet short course racing - 11/16/2010 4:08 PM
hchia25
Score: 100
Last Login: 5/11/2012
Status: offline
I found a lot of drivers are using http://prolineracing.com/tires/striker-ii-2.2-street-truck-tires/
works really well for indoor carpet
Hide Signatures
       Post #: 6
RE: Tires/setup for Indoor carpet short course racing - 11/16/2010 10:35 PM
plasmaedge
Score: 116
Last Login: 4/28/2013
Status: offline
Tyres -     http://prolineracing.com/tires/suburbs-sc-2.2/3.0-m4-super-soft-tires/
Shocks - low down
Oil - 55wt/60wt
should get you going prety good.
Team associated t4.1 (currently a roller)
Hide Signatures
(in reply to hchia25)
       Post #: 7
RE: Tires/setup for Indoor carpet short course racing - 11/16/2010 11:21 PM
Brainanator
Score: 130
Status: offline
quote:
ORIGINAL: godofcable
right, but you didn't change the shock oil to something heavier (about 60 weight is good). The heavier oil will keep you from bottoming out better. and it's not like bottoming out is the worst thing ever, flipping over is far worse.
Hide Signatures
       Post #: 8
RE: Tires/setup for Indoor carpet short course racing - 11/16/2010 11:33 PM
godofcable
Score: 100
Status: offline
what do you mean by shocks - low down
Hide Signatures
(in reply to plasmaedge)
       Post #: 9
RE: Tires/setup for Indoor carpet short course racing - 11/16/2010 11:34 PM
godofcable
Score: 100
Status: offline
quote:
ORIGINAL: Brainanator
agreed that flipping is much worse. The problem with me bottoming out was the rear tires would jump off the ground when i bottomed out, and for about 4-5 feet i had no control.
Hide Signatures
       Post #: 10
RE: Tires/setup for Indoor carpet short course racing - 11/17/2010 2:20 AM
ThunderbirdJunkie
Score: 1040
Status: offline
quote:
ORIGINAL: plasmaedge
Shocks - low down
Oil - 55wt/60wt
Since there's really no lack of traction on carpet, M2 Suburbs would be better. The harder compound would give you a stiffer sidewall and help prevent traction rolling.
Hide Signatures
       Post #: 11
RE: Tires/setup for Indoor carpet short course racing - 11/17/2010 8:08 AM
plasmaedge
Score: 116
Status: offline
true, and better tyre life.
Hide Signatures
(in reply to ThunderbirdJunkie)
       Post #: 12
RE: Tires/setup for Indoor carpet short course racing - 11/17/2010 7:01 PM
BuzzBomber
Score: 100
Last Login: 12/17/2012
Status: offline
AT my club's track, we only run stock brushed slashes with stock tires on our carpet track, but here's how we cope with traction rolling(yes, this is allowed under our rules): tape the front tires. One wrap of electrical tape around the outside edge of the front tires takes away just enough traction to keep the truck from rolling in every corner without pushing/plowing too badly. You have to experiment with how far inboard you place the tape for best results. FWIW, I run no spacers on the front, and one thick spacer in the back, with 40-50 weight oil. I'd rather have chassis slap than traction rolling......YMMV, since your tracks rules are different.
Matt Smith
If you''re not having fun, you''re missing the point.
Hide Signatures
       Post #: 13
RE: Tires/setup for Indoor carpet short course racing - 11/17/2010 7:07 PM
godofcable
Score: 100
Status: offline
we are still experimenting with the class. right now they are saying its "open", meaning run whatchya brung, but this was also knowing that all entrants were using brushed motors. if guys start showing up with brushless trucks they may change things.
i ordered the shock oil, should be here any day. someone had mentioned having the shocks "low down" . . . can someone clarify that?
< Message edited by godofcable -- 11/17/2010 7:33 PM >
Hide Signatures
(in reply to BuzzBomber)
       Post #: 14
RE: Tires/setup for Indoor carpet short course racing - 11/18/2010 3:52 AM
plasmaedge
Score: 116
Status: offline
hey, what i mean by low down is have the truck sitting lower down than you would for bashing, effectievly lowering the COG and helping with racing.
Hide Signatures
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.691RCU1
