RE: Lightning Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Lightning Build
Page: <<   < prev  10 11 12 13 14 [15] 16 17 18 19   next >   >>
Login
RE: Lightning Build - 4/26/2012 3:36 AM
Viper Driver
Score: 100
Last Login: 5/25/2013
Status: offline
Tim,
You are welcome. You can use Profili or Compufoil to print out wing ribs. I am using Profili Pro version for a future project and it works very well. It has some nice features, such as the ability to adjust the trailing edge thickness, that come in handy for pattern plane design.
Jeff
< Message edited by Viper Driver -- 4/26/2012 6:23 AM >
_____________________________
Jeff Carder
Hide Signatures
(in reply to dfturnock)
       Post #: 351
RE: Lightning Build - 5/3/2012 3:20 PM
69 roadrunner
Score: 100
Last Login: 5/1/2013
Status: offline
I have a evolution 26 gas motor will that be a good choice. What does this plane come in at in the weight. Thanks RoadRunner
Hide Signatures
(in reply to Viper Driver)
       Post #: 352
RE: Lightning Build - 5/3/2012 3:27 PM
rcpattern
Score: 100
Status: offline
Weight shouldnt be a problem with this plane. I'm sure Jeff will chime in with the exact number, but I believe last year at the NATS he was around 4650. The plane is ultralight and flies very well,
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to 69 roadrunner)
       Post #: 353
RE: Lightning Build - 5/4/2012 5:56 AM
Viper Driver
Score: 100
Status: offline
RoadRunner,
It would be possible to use a gas engine, but the are a few changes that would have to be made. The Lightning was designed to use an electric motor, so there is no cowl. Additionally, since the electric motor has much less vibration, the airframe was designed lighter. With a gas motor, the front end of the fuselage should be strengthened. These modifications will add weight, but it should be posible to stay under 11 pounds. The official weight of mine at the 2011 Nats was 4612 grams.
Jeff
Jeff Carder
Hide Signatures
       Post #: 354
RE: Lightning Build - 5/4/2012 1:32 PM
rmh
Score: 252
Status: offline
Under 11 lbs - EZ.
I have built stuff using ZDZ40 -well under 11 lbs
The BIG problem in using gassers is was and will still be the power pulses inherant in the rpm band used
Good balsa construction is the best forsoaking up th pulses (motor mounts will NOT fix this basic condition-just soften the condition some)
So I am doing - again a design using balsa /spruce -
I do have carbon fibre but basics will be wood.
Libby is still watching you
Hide Signatures
       Post #: 355
RE: Lightning Build - 6/4/2012 3:03 PM
gdaddy
Score: 100
Last Login: 5/17/2013
Status: offline
My Lightning is done! Should be flying it this week. I will post pictures as soon as possible. Very excited to get this thing in the air. Since I have Dave Snow's Dynamic wings and stabs,, I am dubbing this plane "Lightning Dynamic"
More to come soon!
Hide Signatures
(in reply to rmh)
       Post #: 356
RE: Lightning Build - 6/4/2012 3:21 PM
astropuppy
Score: 100
Last Login: 5/24/2013
Status: offline
Congrats; Bring it up to the pattern contest in Boise, ID this coming weekend. We would love to see it.
http://www.nsrca.us/d8/2012/TreasureValleyPatternContest.pdf
Hide Signatures
(in reply to gdaddy)
       Post #: 357
RE: Lightning Build - 6/4/2012 3:29 PM
gdaddy
Score: 100
Status: offline
Thats the plan . If I cant get out to fly it a few times beforehand, I'll have to fly Jesky's 2M Osiris prototype. Sad,, I know...
Hide Signatures
(in reply to astropuppy)
       Post #: 358
RE: Lightning Build - 6/4/2012 3:36 PM
astropuppy
Score: 100
Status: offline
Is Andrew and Darrin coming up? I haven't heard from them and hate to pester.
Hide Signatures
       Post #: 359
RE: Lightning Build - 6/4/2012 4:05 PM
gdaddy
Score: 100
Status: offline
Yes. Darin and Andrew and I along with about 6 others as I understand it. We are all really looking forward to it!
Hide Signatures
       Post #: 360
RE: Lightning Build - 6/4/2012 4:06 PM
astropuppy
Score: 100
Status: offline
Maybe I need to plan on two flight lines....
Hide Signatures
       Post #: 361
RE: Lightning Build - 6/4/2012 4:30 PM
gdaddy
Score: 100
Status: offline
Maybe!! One for the Utah contigent and one for everybody else!!
Hide Signatures
       Post #: 362
RE: Lightning Build - 6/5/2012 2:04 AM
Viper Driver
Score: 100
Status: offline
Congratulations on completing your Lightning. I am looking forward to pictures and a flight report!
Jeff Carder
Hide Signatures
       Post #: 363
RE: Lightning Build - 6/7/2012 6:14 PM
gdaddy
Score: 100
Status: offline
Hmm,
I cant get the pictures to show up  Upload finishes fine. Just .  No.. Pictures!
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 364
RE: Lightning Build - 6/7/2012 6:15 PM
gdaddy
Score: 100
Status: offline
Whoops!  Lets try this again
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 365
RE: Lightning Build - 6/7/2012 6:23 PM
gdaddy
Score: 100
Status: offline
Once more with bigger size!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 366
RE: Lightning Build - 6/7/2012 6:29 PM
gdaddy
Score: 100
Status: offline
All pictures taken with my IPhone and my one good eye.
Plane flys well.  Moving the CG around right now.  Does everything it should.  My finish is ok,,, all paint.. I had started on a much more involved finish and ran into issues, I sanded it all back down and did this finish in a couple days with waterbase AutoAir and Chromaclear.  Using the inexpensive A60 7S motor, DX18 radio , Spektrum servos throughout.   Flying a contest this weekend with it.  I have been flying the 2M Osiris for awhile now and I really feel comfortable with it.  I will still fly this one, however, as I have been working on it since October and I'm pretty psyched!
Hide Signatures
       Post #: 367
RE: Lightning Build - 6/7/2012 8:06 PM
tschmidt
Score: 100
Status: offline
Excellent Job! I bet it shows up in the air good...
Hide Signatures
       Post #: 368
RE: Lightning Build - 6/7/2012 8:16 PM
gdaddy
Score: 100
Status: offline
Shows up pretty well.  The fuselage size is a fair bit smaller than the Big O.  It appears a little bit smaller to me.  I'm sure it will go away once I fly it a bunch more and pick my spot in the sky more appropriately
Excited to fly my first contest in 20 some odd years.  The last one I flew was in Vegas and I was flying one of my new Ariel's I had just started kitting.  This is going to be fun!
Hide Signatures
(in reply to tschmidt)
       Post #: 369
RE: Lightning Build - 6/7/2012 8:19 PM
69 roadrunner
Score: 100
Status: offline
Looks great going to order one today for my fathers day gift. The wife just dosnt know that is what they are getting me. Steve
Hide Signatures
       Post #: 370
RE: Lightning Build - 6/7/2012 8:20 PM
gdaddy
Score: 100
Status: offline
Wives are great that way.  Mine has ok'ed or bought me so much stuff she doesnt even know about.
Hide Signatures
       Post #: 371
RE: Lightning Build - 6/8/2012 1:03 AM
JRgraham
Score: 105
Status: online
gdaddy, what is different about the wings??
Looks great, Im sure you will be pleased with it. It will be interesting to see how you think it differs from the Osiris
JR Graham
D8, AMA 201522
Hide Signatures
       Post #: 372
RE: Lightning Build - 6/8/2012 2:04 AM
maustin
Score: 100
Status: offline
gdaddy,
How do you like the A60 7S V2 motor? What prop, bats and ESC are you running? I have a new A60 7S in my Pentathlon but need new bats to really tell what the motor will do.
maustin
Hide Signatures
(in reply to JRgraham)
       Post #: 373
RE: Lightning Build - 6/9/2012 4:11 PM
Viper Driver
Score: 100
Status: offline
WOW, your Lightning Dynamic looks fantastic! It is the first one I have seen, other than my own, and you made it look great. What a satisfying feeling to break ground with an airplane you have spent 6 to 9 months of your time on.
Good luck in your first contest back. I have had to take a few extended breaks from competition and everytime I realize I have missed it more than I thought.
Congratulations!
Jeff
Jeff Carder
Hide Signatures
       Post #: 374
RE: Lightning Build - 6/9/2012 11:38 PM
Jason Arnold
Score: 100
Status: offline
Nice job mate. Looking great!
Cheers,
Jason.
Hide Signatures
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
