RE: Lightning Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Lightning Build
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Lightning Build - 1/19/2011 8:34 PM
Mastertech
Score: 108
Last Login: 6/19/2013
Status: offline
I still object to you using the word "Work" when you're flying F-16's for a living.
_____________________________
Be a kid forever, fly models.
Hide Signatures
(in reply to Viper Driver)
       Post #: 51
RE: Lightning Build - 1/19/2011 9:25 PM
Doug Cronkhite
Score: 105
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Mastertech
I still object to you using the word ''Work'' when you're flying F-16's for a living.
+1
Doug Cronkhite
Hide Signatures
(in reply to Mastertech)
       Post #: 52
RE: Lightning Build - 1/19/2011 10:12 PM
Viper Driver
Score: 100
Status: offline
In my time away from "WORK" I managed some progress. Here, the lower stringers are installed. Also, a picture from nose on to show the curves a bit.
Next I will be doing some wetting and bending of balsa to fit the bottom.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 53
RE: Lightning Build - 1/20/2011 4:20 AM
Rendegade
Score: 105
Status: offline
Wow Jeff that's amazing.
Have you got plans for that?
It''''s easy to fly, just throw yourself at the ground and miss!
Hide Signatures
       Post #: 54
RE: Lightning Build - 1/20/2011 7:01 AM
Alex Voicu
Score: 100
Status: offline
Very nice work and the plane looks great!
I've been looking at this thread for a while and learned a few tricks here.
Thanks.
Hide Signatures
(in reply to Rendegade)
       Post #: 55
RE: Lightning Build - 1/21/2011 10:46 AM
Viper Driver
Score: 100
Status: offline
Rendegade, check your PM.
Alex, thank you for the complement. You know what goes into one of these first hand.
Jeff Carder
Hide Signatures
(in reply to Alex Voicu)
       Post #: 56
RE: Lightning Build - 1/24/2011 6:52 AM
alawel
Score: 100
Last Login: 6/12/2013
Status: offline
Nice work Jeff. Keep the pics and updates coming. I look forward to seeing the final product.
How have you been? It's been a long time since we conversed.
Alan Wellentin
Hide Signatures
       Post #: 57
RE: Lightning Build - 1/25/2011 1:47 AM
Viper Driver
Score: 100
Status: offline
Alan,
Great to hear from you. Don't hear much out of the old D8 crew these days. I would love to get back out there for a contest one of these days. The old days at the EAC contest were great! Keep checking in on the progress.
Jeff
Jeff Carder
Hide Signatures
(in reply to alawel)
       Post #: 58
RE: Lightning Build - 1/25/2011 1:49 AM
Viper Driver
Score: 100
Status: offline
My solution for light weight servo wire conduit.
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 59
RE: Lightning Build - 1/25/2011 1:56 AM
Viper Driver
Score: 100
Status: offline
I added a small piece to make the existing sheeting straight down the length of the fuselage to ease the difficult job of sheeting the bottom.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 60
RE: Lightning Build - 1/26/2011 2:19 AM
flyintexan
Score: 100
Status: offline
Beautiful work Jeff.
-mark
NSRCA 3656
www.NSRCA.us
Hide Signatures
       Post #: 61
RE: Lightning Build - 1/29/2011 4:02 PM
Viper Driver
Score: 100
Status: offline
Thanks Mark. Still waiting to see your new bird.
Jeff Carder
Hide Signatures
(in reply to flyintexan)
       Post #: 62
RE: Lightning Build - 1/29/2011 4:18 PM
Viper Driver
Score: 100
Status: offline
Now, on to the task of sheeting the bottom of the fuselage. This is more complicated that sheeting the top as the curves are more complex. In order to make it manageable, I am sheeting it in four sections. I don't have a good shape pre-mold like I did for the turtle deck sheeting, so it is all done on the fuselage. To keep it from getting waves, I only wet the inside of the wood, and I use balsa sticks pinned along the edges to keep them straight. When I tape the sheets to the fuselage, I only wrap it around where the formers are to prevent waves. I shape the edges of the wood prior to wetting, much easier to sand!
Here are pictures of the first two sections on the fuselage for molding, and after they dried and were removed.
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 63
RE: Lightning Build - 1/29/2011 5:03 PM
Bill Carder
Score: 100
Last Login: 11/23/2012
Status: offline
Looking good Jeff, did I tell you Alan is planning a pattern come back!
Hide Signatures
       Post #: 64
RE: Lightning Build - 1/30/2011 3:06 PM
Viper Driver
Score: 100
Status: offline
Now that the first sections are formed, it is time to glue them on.
Here is a little trick with Gorilla Glue that I can't believe I didn't think of earlier. I used a syringe for glue for application which made it much easier than trying to use the bottle and sticks to spread the glue. I was able to use much less glue as I could apply it exactly where I wanted it. The syringe cleaned up with alcohol so I can re-use it.
I placed the seam along one of the stringers to help keep the edge of the sheeting straight.
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 65
RE: Lightning Build - 1/30/2011 4:50 PM
Anthony-RCU
Score: 100
Status: offline
Hi Jeff,
Great work! Good to see getting back to r/c. How do you clean the syringe? I have tried that with some nyrod and made a mess.
Anthony Romano
Team Airtronics, Team Castle Creations
Hide Signatures
       Post #: 66
RE: Lightning Build - 1/30/2011 5:32 PM
Viper Driver
Score: 100
Status: offline
Anthony,
When I finished gluing, I squeezed as much glue out of the syringe as I could. Then I filled a bottle cap with denatured alcohol and filled and evacuated the syringe multiple times, which got most of it. To get the gunk out of the tip, I used a scrap of 1/8" square balsa stick, with a slightly sharpend tip. I stuck it through the back of the syringe and twisted it to bring out the remaining glue. Then I swished more clean alcohol through it. That left it clean enough for further use.
Jeff Carder
Hide Signatures
(in reply to Anthony-RCU)
       Post #: 67
RE: Lightning Build - 2/6/2011 12:24 AM
Viper Driver
Score: 100
Status: offline
Section three and four of the bottom sheeting are molded in the same manner as the first two. Balsa holds shape very well once it is dry. Once I removed the dry sections from the fuselage, I trimmed the edges to make nice seams. This is difficult as prior to having the sheeting glued on, the stringers and formers have a bit of flex. As you try to hold the parts into their final position to test the fit, you distort the structure with the pressure of holding them in place. It may look beautiful has you hold everything together, but when you take your hand away, everthing springs back into place and your seams open up. This is exactly why I keep large tubs of filler on hand.
Electrical tape was not required at the balsa sticks I used to hold the edges down while gluing are covered with a layer of clear packing tape. Easy mold release! The syringe technique also made for much cleaner seams.
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 68
RE: Lightning Build - 2/12/2011 2:07 PM
Viper Driver
Score: 100
Status: offline
I have finally cleared out a mountain of blue painter's tape in my garage to reveal a 99% complete fuselage. The only steps remaining are to install the wing and stab sockets, and then sand to final shape. Also, I left the sheeting off of the bottom of the subfin area to allow access to the stab socket. Once the socket is glued in, that area will be sheeted. Right now, the fuselage weighs in at 20.8 oz. For comparison, the prototype weighed 28 oz at the same stage. Now, on to wings and stab.
Click for fullsize
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 69
RE: Lightning Build - 2/12/2011 2:30 PM
tschmidt
Score: 100
Status: offline
Looks fantastic Jeff! Your a professional "balsa bender" keep up the good work!!
Todd
Hide Signatures
       Post #: 70
RE: Lightning Build - 2/12/2011 10:17 PM
rcpattern
Score: 100
Status: offline
Awesome work Jeff!!!
Arch
Team Futaba, Castle Creations, Tech Aero Designs, Hacker Motors, F3A Unlimited, Team BJ Craft,
Hide Signatures
(in reply to tschmidt)
       Post #: 71
RE: Lightning Build - 2/13/2011 2:40 AM
Viper Driver
Score: 100
Status: offline
Todd & Arch,
Thank you for the good words. I have put in quite a few hours in the last few days, making good progress. I made it out flying today as well...have to remember how to fly too!
Jeff
Jeff Carder
Hide Signatures
(in reply to rcpattern)
       Post #: 72
RE: Lightning Build - 2/13/2011 6:15 AM
RC_Pattern_Flyer
Score: 105
Last Login: 6/16/2013
Status: offline
Take your time remembering unless you are going to fly FAI
Jeff,
I remember the masters finals a few years ago, it wont take you long to return to that form!
Hope to see you are the field,
Chuck
Mark Hunt Designs
Hide Signatures
       Post #: 73
RE: Lightning Build - 2/19/2011 12:08 AM
Viper Driver
Score: 100
Status: offline
Chuck,
Good to hear from you! I miss the good old days of D6 post flying beverages. Glad to see you have one of Mark's Harmony kits, looks like a great plane.
Jeff Carder
Hide Signatures
(in reply to RC_Pattern_Flyer)
       Post #: 74
RE: Lightning Build - 2/19/2011 12:30 AM
Viper Driver
Score: 100
Status: offline
On to the wings. They are more or less conventional foam and balsa wings. I do use some strips of carbon fiber for reinforcement. I had the cores cut by Mark Hunt, Insight RC. The unique thing about the way Mark does wings and stabs is his "honeycomb" method. He drills a grid of 1/4" holes rather than the traditional square pattern. I use a 1/8" lightply rib at the end of the wing socket. I also cut the holes for the aileron servos and install balsa boxes prior to sheeting. I made a tool out of 1/16" wire to cut the hole for the aileron servo leads. It is a simple loop that plugs into my soldering gun.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Jeff Carder
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.188RCU1
