RE: Downwind turn Myth    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Downwind turn Myth
Page: <<   < prev  35 36 37 38 [39] 40 41 42 43 44   next >   >>
Login
RE: Downwind turn Myth - 6/29/2011 11:59 PM
cfircav8r
Score: 218
Last Login: 5/23/2013
Status: offline
Again you are referencing the ground. If you used exactly the same inputs the aircraft would react the same, no closer to stall, only the turn would be elongated in the direction of the wind.
_____________________________
The three most useless things to a pilot, the sky above you, the runway behind you, and the fuel on the ground.
Hide Signatures
(in reply to flythesky)
       Post #: 951
RE: Downwind turn Myth - 6/30/2011 12:00 AM
rcjets_63
Score: 144
Last Login: 5/24/2013
Status: offline
Just 48 posts left. Come on guys, you can do it!!!
Hide Signatures
(in reply to cfircav8r)
       Post #: 952
RE: Downwind turn Myth - 6/30/2011 12:27 AM
Top_Gunn
Score: 134
Status: offline
quote:
ORIGINAL: flythesky
Consider a typical circuit at the field.  I'm fying parrallel to the runway into a headwind of 15mph and make a 180 turn to return the other way and then will make another 180 to get back on the origanal track.  I notice that on the second turn I need to bank more and use more elevator to complete the turn if I'm to approximate the first turn in size.  It seems like the second turn is the more dangerous one but I would consider that to be an upwind turn.  Do I have upwind and downwind reversed to what is being refered to here?
People have been using both terms. The way RC people usually use them your second turn, which gives people trouble for the reasons you describe, is the "downwind turn." People who think turning downwind loses you airspeed because the plane has to "catch up to the wind" or some such, call your first turn the "downwind turn."
Al Gunn
Ultra Sport Brotherhood No. 9
Hide Signatures
       Post #: 953
RE: Downwind turn Myth - 6/30/2011 12:28 AM
flythesky
Score: 110
Last Login: 2/15/2013
Status: offline
quote:
ORIGINAL: cfircav8r
I am on the ground, the runway is on the ground, the flying area is the space above an area of the ground.  When we fly our planes at most flying sites it's all in relation to the ground.  One of the explanations for the myth was that a pilot was trying to keep the plane in a certain orientation to the ground and made a mistake that caused a crash.  I know that most of the time I try to keep the size of my turns to a minimum because most manuvers are started on a straight line.  Just wanted to be sure my terminology was consistent with everyone elses.
Larry
Hide Signatures
       Post #: 954
RE: Downwind turn Myth - 6/30/2011 1:04 AM
rjbob
Score: 110
Last Login: 4/29/2013
Status: offline
quote:
ORIGINAL: flythesky
quote:
ORIGINAL: cfircav8r
Not true...that is neither an explanation for the myth nor a reason for the myth.
All pilots should know what adjustments should be made for following a ground track while flying in a windy condition. The myth is from the misunderstanding of basic principles of flight.
Alaska Bob - "Can I fly one of your jets? I crashed all of mine." Jet Modeler Magazine www.jetmodeler.com
Hide Signatures
       Post #: 955
RE: Downwind turn Myth - 6/30/2011 1:10 AM
cactusflyer
Score: 110
Status: offline
quote:
ORIGINAL: flythesky
That's it exactly! .......Now can we move on? I'm afraid that the FAA will get wind (pun intended)of all this and try to forbid us from turning our toy plans downwind .
Tailwinds,
John
Proud to be a rookie!
Hide Signatures
       Post #: 956
RE: Downwind turn Myth - 6/30/2011 1:40 AM
FILE IFR
Score: 120
Last Login: 3/31/2013
Status: offline
quote:
ORIGINAL: hugger-4641
Ok, so lets say that in this scenario,  the aircraft has a minimum stall speed of 58.5 mph. This means the aircraft is in danger of stalling when he makes the turn, correct?
Hugger, I think I know why you can't understand this 'myth'. When you're flying your plane(s), do you crank the bank angle over 45+ degrees during your turns, or do you give a gentle bank angle of 10 degrees (ish) during the turns.
If you're a 'Bank-n-Yank' pilot during your turns, I can see why you're having difficulty understanding the physics of lift/flight.
Mike * Intercepting The Localizer* AMA# 365566
Bud Nosen C-310 Club #32 * J.P.O. Member 2302
Hide Signatures
(in reply to hugger-4641)
       Post #: 957
RE: Downwind turn Myth - 6/30/2011 2:22 AM
hugger-4641
Score: 229
Status: offline
quote:
ORIGINAL: FILE IFR
You haven't answered my question yet, but I'll answer yours :
It depends on what plane I'm flying and what  I'm trying to do at the time. When I'm flying my 1/4 scale cub, even if it's windy, I'm usually just trying relax when I fly this plane so my turns are not too aggressive, but I have and can "yank" it if I want to with no problems because I'm very familiar with it.
 One evening a few weeks ago I maidened a new  .60 sized P51 with flaps.  I was trying to evaluate various flap settings to get a feel for the min and max speeds I could perform various manuevers. This would include landings, touch and go,  prolonged level flight 2 feet high, inverted flight 2 feet high, rolls, hard banks, innelmans, cubans, dead stick landings, etc. etc. All of these tested both with and against the wind..  I was flying in 7 to 10mph wind out of due South. Our flying field is oriented almost due North/South, and I was facing East at mid field. I flew both right hand and left hand circuits.  I didn't have any problems making down wind turns, even at low altitude, except when I pushed to far and it tip stalled. This of course was done at higher altitude.
However,  I did notice when I performed some very agressive stall turns at fairly low altitude that no matter what flap setting I used, when I turned from upwind to downwind,  I needed more elevator and more distance to pull out and start climbing again than I did coming back the other way.  Maybe just optical illusion, I don't know, but I was once told that "perception is reality".  I think in this case it is true regardless of the physics, and at the moment, I am still instructing my students to allow more altitude and/or be ready to add more throttle when they make a sharp turn down wind!
Jerry
AMA -922698 Nomal people scare me, but not as much as I scare them...
Hide Signatures
(in reply to FILE IFR )
       Post #: 958
RE: Downwind turn Myth - 6/30/2011 2:31 AM
cactusflyer
Score: 110
Status: offline
Yep.........RealFlight is a pretty cool simulator
Hide Signatures
       Post #: 959
RE: Downwind turn Myth - 6/30/2011 2:37 AM
hugger-4641
Score: 229
Status: offline
I wasn't on a simulator if that's what you mean, but yes, I do like Realflight also. Still using FS one on my PC at home, but it will be the last FS... product I buy!
Jerry
Hide Signatures
(in reply to cactusflyer)
       Post #: 960
RE: Downwind turn Myth - 6/30/2011 2:39 AM
BlueBus320
Score: 100
Status: offline
quote:
ORIGINAL: FILE IFR
It depends on what plane I'm flying and what  I'm trying to do at the time. When I'm flying my 1/4 scale cub, even if it's windy, I'm usually just trying relax when I fly this plane so my turns are not too aggressive, but I have and can ''yank'' it if I want to with no problems because I'm very familiar with it.
However,  I did notice when I performed some very agressive stall turns at fairly low altitude that no matter what flap setting I used, when I turned from upwind to downwind,  I needed more elevator and more distance to pull out and start climbing again than I did coming back the other way.  Maybe just optical illusion, I don't know, but I was once told that ''perception is reality''.  I think in this case it is true regardless of the physics, and at the moment, I am still instructing my students to allow more altitude and/or be ready to add more throttle when they make a sharp turn down wind!
yeah, when your talking real world rc flying, this is not a bad idea.. Stay a lil hot when its windy/gusty & bleed off the airspeed low. The discussion being held is about steady state wind though, & on the days the wind is 100% constant then any airplane doesnt know wind direction, only airspeed.
Call Sign blocked.
Hide Signatures
       Post #: 961
RE: Downwind turn Myth - 6/30/2011 4:30 AM
Dean Pappas
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: highhorse
Once an a/c has broken ground, steady state winds have no effect on airspeed (hence, lift) whatsoever, and airspeed does not change simply because one is flying upwind, downwind, crosswind, or even when alternating between any combinations of the above. Period. That is the beginning, middle, and end of the story.
Hello All,
The above is a misstatement. It should have been, "In unaccelerated flight, steady state winds have no effect on airspeed (hence, lift) whatsoever, and airspeed does not change simply because one is flying upwind, downwind, crosswind."
For the record, a turn is accelerated flight: in order to turn, the plane accelerates toward the center of the turn.
The airspeed will momentarily change during turns into and out of the wind.
A steady-state analysis is inadequate when discussing the downwind turn-stall scenario.
Regards to All,
Dean Pappas
Hide Signatures
(in reply to highhorse)
       Post #: 963
RE: Downwind turn Myth - 6/30/2011 4:37 AM
RZielin
Score: 115
Last Login: 5/9/2013
Status: offline
quote:
ORIGINAL: hugger-4641  Maybe just optical illusion, I don't know, but I was once told that ''perception is reality''.  I think in this case it is true regardless of the physics, and at the moment, I am still instructing my students to allow more altitude and/or be ready to add more throttle when they make a sharp turn down wind!
That advice will sort of work, but will also mislead your students into the same mental trap you're now struggling out of. It is a reasonable strategy that works to prevent crashes, but not for the reasons you suggest. I think it would be better to instruct your students to expect that a properly executed turn will LOOK different from the ground when turning upwind than the same properly executed turn LOOKS when turning downwind.
The properly executed turn into the direction of the wind (the dreaded "downwind" turn) will appear elongated and the plane will appear to accelerate in the direction of the wind as it rounds the second half of the turn. You had better make sure you ALLOW the plane to accelerate or "speed up" in relation to the ground as the turn progresses, in order to maintain airspeed. You do not NEED to add throttle any more than you would on any other turn direction, but you do NEED to expect the plane to move this way in relation to the ground. A proper turn has a unique APPEARANCE when turning "downwind". If you try to make the turn look like a turn looks on a calm day (ie maintaining a fairly constant GROUND speed) you will be forcing or allowing the plane to actually lose airspeed. You will be surprised when you stall and crash despite moving at great velocity. The problem is that you see the velocity in relation to the ground. You do not see the lack of adequate velocity in relation to the air mass.
Conversely, the "upwind" turn properly executed should appear to slow down or hover somewhat relative to the ground as it comes around the second half of the turn. (In fact, if wind speed is greater than current airspeed, the plane will actually appear to come to a dead stop mid turn, and then fly BACKWARDS as it completes the turn). Of course, you now know that the plane is only slowing down or hovering in relation to the ground, but is plowing ahead into the air mass at the same velocity it was before. Just be aware of the optical illusion induced by our "ground based" perspective (and the fact that wind is invisible). The illusion is more dramatic the faster the wind is blowing.
That's the real lesson every student should hear. Then the student can spend months and years integrating this knowledge and the illusionary visual cues to become a better and better pilot. Teaching them your "shortcut" lesson above may save them from crashing, but is ultimately crippling because it obscures the truth of what's really going on with the airplane. A good teacher illuminates the truth, rather than obscuring it. A good teacher would also never say "perception is reality". That is the mantra of feeble minds that survive only by bamboozling their way through reality, tricking others to carry their load in life. (Just call me Highhorse II).
Hide Signatures
       Post #: 964
RE: Downwind turn Myth - 6/30/2011 4:39 AM
highhorse
Score: 116
Status: offline
quote:
ORIGINAL: Dean Pappas
quote:
ORIGINAL: highhorse
Hello All,
The above is a misstatement. It should have been, ''In unaccelerated flight, steady state winds have no effect on airspeed (hence, lift) whatsoever, and airspeed does not change simply because one is flying upwind, downwind, crosswind.''
Regards to All,
Dean Pappas
OMG.......&&$(#&$((*#&@^^$*#& !!!!!!!!!!!
Breathe.....Breathe.........Breathe...........
RCU Rocks, I''d hate to be without it !!
Hide Signatures
(in reply to Dean Pappas)
       Post #: 965
RE: Downwind turn Myth - 6/30/2011 4:49 AM
cfircav8r
Score: 218
Status: offline
quote:
ORIGINAL: FILE IFR
Lets say your plane travels 60 mph and the wind is 10 mph. When you pull vertical from level with no wind lets say it covers 30 ft from initial pull to vertical. When you fly into the wind the pull-up will be shortend to about 25 ft. When flying with the wind it will be lengthened to about 35 ft. So to try to get it to pull in the same distance you attempt to pull harder slowing the plane further while still not totally overcoming the the difference. This gives the visual impression that the A/C is being pushed from behind. In the sense of ground track, or how it visually looks, it is being pushed from behind. In the sense of airspeed and performance nothing has changed. This is why pilots get hung up on wind. You do have to adjust your inputs to compensate, but you need to understand the real reason for the difference to be able to make the apropriate decision of whether or not you and/or your plane can handle it under the current wind conditions, or just let the pull-up use up more distance.
Hide Signatures
       Post #: 966
RE: Downwind turn Myth - 6/30/2011 4:52 AM
BlueBus320
Score: 100
Status: offline
quote:
ORIGINAL: highhorse
Hello All,
Regards to All,
Dean Pappas
Just curious Dean, what's your aviation background?
Call Sign blocked.
Hide Signatures
       Post #: 967
RE: Downwind turn Myth - 6/30/2011 4:53 AM
RZielin
Score: 115
Status: offline
quote:
ORIGINAL: highhorse
quote:
ORIGINAL: highhorse
Hello All,
Regards to All,
Dean Pappas
Take it easy highhorse, I'll handle this one for you while you get your blood pressure back in spec.
Dean, you are absolutely correct. The critical fact that you leave out is that the airspeed changes induced by any turning acceleration are EXACTLY THE SAME NO MATTER WHAT DIRECTION YOU TURN. It's already been discussed here that any turn involves increasing AOA to maintain altitude etc etc. The point of this thread is that all those "dynamic" factors are exactly the same whether you're turning upwind or downwind, crosswind or hyperwind.
Hide Signatures
       Post #: 968
RE: Downwind turn Myth - 6/30/2011 4:54 AM
rcjets_63
Score: 144
Status: offline
Dean,
Wrong.
While airspeed will change during turns, it's because you have to generate more lift (because the wings are banked) to maintain level flight. Thus you pull back on the stick a bit to increase your angle of attack (to generate the lift) and you also generate more drag. At that point you will either lose speed or you can add a bit of power.
It is totally irrelevant whether your turn is into or out of the wind.
The steady state analysis is just fine for the scenario. People seem to be having trouble with the basics of this simplified model, if we added gusts, boundary layers, and ground effect, who knows what half-baked analysis we would get here.
Still going.......(#969)
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 969
RE: Downwind turn Myth - 6/30/2011 5:05 AM
highhorse
Score: 116
Status: offline
Muchas Gracias, Rzielin. My patience with these gentlemen is simply...........shot.
Hide Signatures
(in reply to rcjets_63)
       Post #: 970
RE: Downwind turn Myth - 6/30/2011 5:12 AM
RZielin
Score: 115
Status: offline
OK, why is everyone too lazy to do the obvious?
Someone, PLEASE, make a little simulator video!!!
Set up a 20 kt wind right down the runway. Fly a cub in an oval circuit just above "stall speed" (I know, I know, there's no such thing as stall "speed", only stall AOA).
I think you can even do it with the little window that shows stick movements, can't you?
Then everyone can see the proof with their own eyes. The plane will NOT lose any more altitude turning downwind than turning upwind. At least not if the pilot keeps stick movements pretty much the same both ways. As I have said before, the turns will LOOK very different at each end of the circuit if stick movements are the same, and if you keep your thumb off the throttle.
Just don't anyone do it until we hit 1000, OK?
I admit I'm too lazy to do it. (Unless maybe the dinner offer applies to simulator videos too). I much prefer this armchair philosophizing. Seems to make time stand still, no?
#971 and honored to be part of the grand campaign to "1000"
Hide Signatures
       Post #: 971
RE: Downwind turn Myth - 6/30/2011 5:16 AM
BlueBus320
Score: 100
Status: offline
It's funny hearing people talking about turning into or out of a steady state wind..lol. Kinda defeats the whole point.. You take off into the wind and once airborne, there is no down wind.
Call Sign blocked.
Hide Signatures
       Post #: 972
highhorse
Score: 116
Status: offline
It's because those who don't want to believe now won't believe a vid either...they'll pick apart the software or something else rather than suffer the indignity of admitting they were wrong all along.
Hide Signatures
(in reply to RZielin)
       Post #: 973
RE: Downwind turn Myth - 6/30/2011 5:27 AM
RZielin
Score: 115
Status: offline
quote:
ORIGINAL: highhorse
Set up a 20 kt wind right down the runway. Fly a cub in an oval circuit just above ''stall speed'' (I know, I know, there's no such thing as stall ''speed'', only stall AOA).
highhorse, do NOT lose faith in humanity!
A sublime faith in human imbecility has seldom led those who cherish it astray.
Henry Ellis
Hide Signatures
       Post #: 974
RE: Downwind turn Myth - 6/30/2011 5:32 AM
highhorse
Score: 116
Status: offline
I posted months ago about having actually done 3 consecutive 360's into and out of a 100+ knot wind (well over 200 kts cumulative groundspeed difference) in a 320,000 lb airplane that was within 30 kts of stall speed for those conditions. Once established in the turn, with a million $$ worth of auto pilot doing the flying so I could stay kicked back and relaxed.....
Nothing. No trim changes, no throttle changes, NO AIRSPEED CHANGES......nothing. Why? Cus what I said in post #1 is absolutely true. An airborne aircraft is completely unaffected and doesn't give s sh^t where the (steady state) wind is from. PERIOD. If that weren't the case then I'd have been 170kts below stall speed when downwind and would not be alive to type here in this thread.
What else is there to talk about?
Hide Signatures
       Post #: 975
Jump to:
Google
SITE MAP!   : :   FORUM RULES
5.813RCU1
