RE: 30cc Edge 540 build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: 30cc Edge 540 build
Page: <<   < prev  12 13 14 [15] 16 17 18 19 20 21   next >   >>
Login
RE: 30cc Edge 540 build - 12/22/2011 7:45 PM
stingray528i
Score: 100
Last Login: 5/13/2013
Status: offline
I guess im having a senior moment too can you explane the ch 1 and 6 and then 2 and 5 for elevater
quote:
ORIGINAL: cloudancer03
anyone using a futaba 7c 2.4 radio with a 617 rx??I just realized if I use ch.1 and 6 and then 2 and 5 for elevator...I still need an open channel for my igntion....am I having a senior moment here.nobody is using a y harness are they or match box..
Hide Signatures
(in reply to cloudancer03)
       Post #: 351
RE: 30cc Edge 540 build - 12/22/2011 8:01 PM
greg palmer
Score: 100
Last Login: 4/2/2013
Status: offline
I believe channels 1 and 6 are for the ailerons and 2 and 5 are for the elevators.
Hide Signatures
(in reply to stingray528i)
       Post #: 352
RE: 30cc Edge 540 build - 12/22/2011 8:43 PM
stingray528i
Score: 100
Status: offline
so is ther any real advantage setting radio up like this over y harness
quote:
ORIGINAL: greg palmer
Hide Signatures
(in reply to greg palmer)
       Post #: 353
RE: 30cc Edge 540 build - 12/22/2011 9:29 PM
bemeson
Score: 100
Last Login: 5/5/2013
Status: offline
quote:
ORIGINAL: stingray528i
Yes,
There is big advantage to using separate channels for each surface. If needed, you can utilize sub trim, and most importantly, you do not split power coming out of the Y. If you use y's and additional extensions, you loose power going across each connection. Loss of power means loss of performance. If you spent the extra money on digital servos, spend a little extra money and use a proper reciever.
You really do need a channel for your ignition, and I would not suggest connecting anything from your ignition to your reciever...you are asking for trouble in the way of feedback. Set up your throttle kill correctly and there is one throttle kill the other is the switch.
Just my opinion,
Brian
Hide Signatures
       Post #: 354
RE: 30cc Edge 540 build - 12/23/2011 3:21 AM
stingray528i
Score: 100
Status: offline
thnx for the info, I have the reciever to do this I just havnt heard of setting up this way untill reading this thread.  By the way I just recieved my  AW Edge a couple days ago and just started the build.  Andy
Hide Signatures
(in reply to bemeson)
       Post #: 355
RE: 30cc Edge 540 build - 12/23/2011 3:24 AM
stingray528i
Score: 100
Status: offline
And I guess I wont be needing the 30.00 reversing y hanress I just got from TBM
Hide Signatures
       Post #: 356
RE: 30cc Edge 540 build - 12/23/2011 3:59 AM
bemeson
Score: 100
Status: offline
Read the thread from the beginning and it will give you all the answers you need to build the plane
Brian
Hide Signatures
       Post #: 357
RE: 30cc Edge 540 build - 12/27/2011 4:41 AM
stingray528i
Score: 100
Status: offline
hey yall, my bird is now ready to fly, all I need is decent wheather on a day off
Hide Signatures
       Post #: 358
RE: 30cc Edge 540 build - 1/10/2012 2:00 AM
jchorsejeff
Score: 100
Last Login: 5/19/2013
Status: offline
Just ordered my edge today and am new to gas. Got the 30cc dle. On aw website have two kinds of  ignition power systems one by smartfly for 20cc-150cc and another by aw for 20-30cc. Dont know which one is better or what I need. Thanks for any help! First time posting on a forum also.
Hide Signatures
       Post #: 359
RE: 30cc Edge 540 build - 1/10/2012 2:33 AM
bemeson
Score: 100
Status: offline
If you go back and read the build thread, those questions are answered. On a plane that small you really do not need one of those systems. The build thread contains a ton of information on build tips and items used.
Brian
Hide Signatures
(in reply to jchorsejeff)
       Post #: 360
RE: 30cc Edge 540 build - 1/10/2012 12:00 PM
jchorsejeff
Score: 100
Status: offline
Agreed build thread is great. Thanks for the help.
Hide Signatures
       Post #: 361
RE: 30cc Edge 540 build - 1/10/2012 2:53 PM
greg palmer
Score: 100
Status: offline
Use a 4.8 jr sport 1500 and you will be fine. I use it on my edge with a dle 30 and after all day of flying when I charge the battery a week later it usually only puts 500 to 700 mah back in it. You don't gain any advantage of using a 6v battery and dle ignitions don't like them, it tends to let the smoke out of the electronic ignition.
Hide Signatures
       Post #: 362
RE: 30cc Edge 540 build - 1/10/2012 8:04 PM
jchorsejeff
Score: 100
Status: offline
Sounds good. Thanks for the advice.
Hide Signatures
       Post #: 363
RE: 30cc Edge 540 build - 1/15/2012 3:52 AM
jchorsejeff
Score: 100
Status: offline
Are there any pros or cons between the bisson and jtec mufflers on the dle 30 and this plane?
Hide Signatures
       Post #: 364
RE: 30cc Edge 540 build - 1/15/2012 5:18 AM
bemeson
Score: 100
Status: offline
I have a JTEC and it works like a charm
Brian
Hide Signatures
       Post #: 365
RE: 30cc Edge 540 build - 1/15/2012 1:32 PM
jchorsejeff
Score: 100
Status: offline
Thanks! What kind of regulator are you running on your life battery on the ignition?
JEFF
Hide Signatures
       Post #: 366
RE: 30cc Edge 540 build - 1/15/2012 3:26 PM
bemeson
Score: 100
Status: offline
In line diode....it's light and has been perfect.
Brian
Hide Signatures
       Post #: 367
RE: 30cc Edge 540 build - 1/23/2012 1:20 AM
DLEVETT
Score: 105
Last Login: 5/20/2013
Status: offline
Hi Guys,
Is there room to run a tuned pipe in the 30cc Edge?
It doesn't appear so from the pics but I don,t have one yet to take the necessary measurements.
I,m thinking if some internal items like the servo try etc. are re-located it would be possible.
Any thoughts?
thx
Dave
Hide Signatures
       Post #: 368
RE: 30cc Edge 540 build - 1/23/2012 2:07 PM
cmoore806
Score: 100
Status: offline
Nope there's no room for anything other than a muffler forward of the firewall.
_____________________________
Chris Moore
AMA 497715
Hide Signatures
(in reply to DLEVETT)
       Post #: 369
RE: 30cc Edge 540 build - 1/23/2012 5:45 PM
Estang
Score: 105
Last Login: 3/6/2013
Status: offline
Where are you guys finding these awsome graphic kits for this plane?
-Eric-
Hide Signatures
(in reply to Sewerdude)
       Post #: 370
RE: 30cc Edge 540 build - 1/23/2012 5:53 PM
bemeson
Score: 100
Status: offline
Bad Brad Graphics, BandEgraphix
Brian
Hide Signatures
(in reply to Estang)
       Post #: 371
RE: 30cc Edge 540 build - 1/27/2012 2:22 AM
Estang
Score: 105
Status: offline
Here is a question for all you pros. When you install the pull-pull lines, how much tension do you put on the lines?
-Eric-
Hide Signatures
       Post #: 372
RE: 30cc Edge 540 build - 1/29/2012 1:51 AM
Estang
Score: 105
Status: offline
Here is another question. Has anyone had to trim the carbon rods for the tail? Mine seem to seat nice in each stab half, but when I put it on the plane, there is about 1/4 inch space between the fuse and a stab. If i was to cut of 1/4 inch of each tube it would fit. Is that normal or am I missing something?
Thanks in advance
-Eric-
Hide Signatures
       Post #: 373
RE: 30cc Edge 540 build - 1/29/2012 2:45 AM
Mark Dennis
Score: 100
Last Login: 5/17/2013
Status: offline
Shortening the stab tubes is not something that normaly needs to be done but it can happen. Are both tubes a 1/4" too long or just one? Either way, sanding them down with a disc sander will be the easiest/cleanest way of shortening them.
As for the pull pull cables, you should be able to push the cables towards each other by about half of their distance before they won't go any further. If they get closer they are too loose and if you can't push them together that far they are too tight.
Mark
Team Aeroworks
Hide Signatures
       Post #: 374
RE: 30cc Edge 540 build - 1/29/2012 4:27 AM
Estang
Score: 105
Status: offline
Thanks for the info Mark. I had to cut 3/16 of both tubes and all went to gether with out any problems. The wife is not too happy with how much room it is taking up in the living room, but I am really enjoying the 540. It is going together like nothing I have ever worked on before.
Thanks for all the hard work and time invested to give us top shelf kits.
-Eric-
Hide Signatures
(in reply to Mark Dennis)
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.719RCU1
