RE: 30cc Edge 540 build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aero-Works Support >> RE: 30cc Edge 540 build
Page: <<   < prev  12 13 14 15 16 17 18 [19] 20 21   next >   >>
Login
RE: 30cc Edge 540 build - 4/10/2012 12:35 PM
greg palmer
Score: 100
Last Login: 4/2/2013
Status: offline
I used a xoar 20 x 6 with very good results, aand the same servos. For batteries I used Hobbico 2s life 2100 unregulated with no problems and just 4.8 nimh on the ingnition.
Hide Signatures
(in reply to schutter)
       Post #: 451
RE: 30cc Edge 540 build - 4/10/2012 3:08 PM
stevehookem
Score: 100
Last Login: 5/22/2013
Status: offline
Many of us have tested various prop combos with the DLE30. The final verdict seems to be that the best pull and braking comes from the Xoar 19x8. I can tell you that I lift off and can go vertical out of site. It always brings out the hoots and hollers from the pit area! haha
For batteries, I use a HydraMax 4.8V 2000mah for the ignition. I had popping and missing when I used a LiPo and regulator. Since going back to the 4.8V, not one pop or miss. It's perfect.
For receiver I use the LiPo from Fromeco with a regulator from Smart-Fly. Again, it just works perfectly.
Hide Signatures
(in reply to greg palmer)
       Post #: 452
RE: 30cc Edge 540 build - 4/10/2012 7:33 PM
jchorsejeff
Score: 100
Last Login: 5/23/2013
Status: offline
My set up is as simple as it gets because I'm a simple minded sucker. Nimh 4.8v 2000mah on the ignition and Nimh 6v 2000mah on the receiver with a rxcel kill switch. I flew eight flights sunday morning and had plenty of battery to spare. I could have gone with a smaller ignition battery. I have a 19*8 xoar sword. The black prop looks cool. Had to change the tail wheel to cf my other developed a crack right behind the last bolt. Ended up with a 5% rudder to elevator mix to help ke. This is a fun plane and the dle is runnin like a top. Couldn't ask for better.
Jeff
Hide Signatures
(in reply to stevehookem)
       Post #: 453
RE: 30cc Edge 540 build - 4/10/2012 9:48 PM
bemeson
Score: 100
Status: offline
I believe I have over 300 flight on my plane. I broke the motor on a 19X7 Xoar beach prop. After about a gallon, I changed to a Xoar 19X8 laminated prop. The plane has great verticle as well as breaks well on the down line. The reciever is powered by a life 2100 mah battery and the ignition is powered by a 1600 life with no regulator. I believe I was getting six plus flights on a single charge with quite a bit left as a safety margin. One thing to consider is the type of servos you are going to use. If you use digitals, they use a bit more juice than non-digitals. It would be a crime to not put high end digitals in this plane.
Brian
Hide Signatures
(in reply to jchorsejeff)
       Post #: 454
RE: 30cc Edge 540 build - 4/10/2012 11:10 PM
schutter
Score: 100
Last Login: 5/6/2013
Status: offline
I also now will be using a 2100 LiFe for the Rx and 1500mah for ignition now that I see it's working for others well.
So I will be using Hitec 5645's(in the mail) so those that have used them do they come with the proper servo horns that I'm going to need or am I going to have to buy different servo horns?   Thanks
_____________________________
Aeroworks Edge 540 (Building!!!)
Alpha .40 w/ Evo .46
Hide Signatures
(in reply to bemeson)
       Post #: 455
RE: 30cc Edge 540 build - 4/10/2012 11:37 PM
greg palmer
Score: 100
Status: offline
I used Hanger 9 metal arms ( the black ones) and they worked real good.
Hide Signatures
       Post #: 456
RE: 30cc Edge 540 build - 4/11/2012 3:22 AM
jchorsejeff
Score: 100
Status: offline
My hitec 5645 servo's came with nylon and a blue metal servo arm. The nylon one's have been working for me great.
Jeff
Hide Signatures
       Post #: 457
RE: 30cc Edge 540 build - 4/11/2012 9:38 AM
gorgin4325
Score: 100
Last Login: 4/11/2012
Status: offline
Hide Signatures
(in reply to tripower222)
       Post #: 458
RE: 30cc Edge 540 build - 4/12/2012 11:52 PM
DLEVETT
Score: 105
Last Login: 5/21/2013
Status: offline
Well guys, I got lucky.
AeroWorks is sold out of this airframe so I had started to look for alternatives.
This morning I decided to head out early for Toledo and catch a ball game tonight. Not being in any great hurry I dropped into a hobby shop ( Skycraft Hobbies) along the way.
Tucked away in the back corner of the store was a unmarked box, since they had other AW airframes in stock I pulled it out only to find myself a 30cc AW Edge 540.
I couldn't stop grinning and it only got better. I inquired about the present Toledo sale offering 20% off and the guys there matched the sale price.
I couldn,t believe it, well I turned around and drove home to inspect my new plane.
It looks awesome, I'll get some weights tonight and post them here.
A Saito 180 is going in mine, so I'm hoping for 10lbs even AUW.
Dave
Hide Signatures
(in reply to gorgin4325)
       Post #: 459
RE: 30cc Edge 540 build - 4/13/2012 6:19 AM
schutter
Score: 100
Status: offline
Dave, Thats good to hear i wasent sure if you were going to find one in Canada!!
I just recived mine today, and ofcoarse its a fairly big box, so anyone thinkin of getting one shipped keep in mind the dimesions on the Shipping Box are 20"(W) X 13"(H) X 55" (L), for me it was worth the $50 shipping as i would have been a 12 Hour round trip to pick it up.  I just got it unpacked and took a look at everything and took a peak at the DLE 30cc  too. Looking forward to the build, but still im waiting for shipments from Aeroworks and another place to complete everything. I also built a Plane stand out of PVC which i found plans for online, i think its gonna be real helpful.
Heres a couple pics;
Hide Signatures
(in reply to DLEVETT)
       Post #: 460
RE: 30cc Edge 540 build - 4/14/2012 1:22 AM
DLEVETT
Score: 105
Status: offline
Schutter, I too am really suprised to find one especially in a hobby shop.
Yours is looking good am I look forward to your build up.
I will post mine as well since we are going with different power plants.
Dave
Hide Signatures
       Post #: 461
RE: 30cc Edge 540 build - 4/14/2012 1:30 AM
airborne2.4
Score: 105
Status: online
I'll be saving my cash for the DA35cc/AW 30cc Edge 450
If you think you can or think you can''''t, you''''re right.
Hide Signatures
       Post #: 462
RE: 30cc Edge 540 build - 4/14/2012 1:52 AM
jchorsejeff
Score: 100
Status: offline
I have a question. I took my muffler off my dle 30 and the dang exhaust gasket came off in about four pieces. Went to the auto shop and the only gasket material they had he didn't think would stand the heat very good. Anybody have any idea's on a replacement?
Hide Signatures
(in reply to airborne2.4)
       Post #: 463
RE: 30cc Edge 540 build - 4/14/2012 2:11 AM
mach2
Score: 125
Last Login: 5/12/2013
Status: offline
you can buy every gasket and part for the DLE engines on towerhobbies, but I use high temp RTV and it works fine. Local auto parts store has it...
70" Revolver, DLE20
67" Goldberg Edge 540, DLE20
Hide Signatures
       Post #: 464
RE: 30cc Edge 540 build - 4/14/2012 11:40 AM
greg palmer
Score: 100
Status: offline
Pitch the gasket and use high temp rtv silicone.
Hide Signatures
(in reply to mach2)
       Post #: 465
RE: 30cc Edge 540 build - 4/15/2012 9:41 PM
DLEVETT
Score: 105
Status: offline
quote:
ORIGINAL: airborne2.4
I,m with you there. When its released I,ll switch out my Saito 180 for a DA35 EScomposites tuned pipe.
Dave
Hide Signatures
       Post #: 466
RE: 30cc Edge 540 build - 4/16/2012 2:26 AM
airborne2.4
Score: 105
Status: online
quote:
ORIGINAL: DLEVETT
Dave
That DA 35cc will no doubt be a winner
Hide Signatures
       Post #: 467
RE: 30cc Edge 540 build - 4/17/2012 5:46 AM
schutter
Score: 100
Status: offline
Guys with DLE 30CC, i tried to mount engine tonight i drilled the hole 13/64 as per addendem, but i could not find any of the Black mounting bolts that mount from inside the firewall to the DLE standoffs? there are 4 bolts in the AW kit bit they are too small, and the definatly are not in the DLE kit, the only bolts in the DLE kit were the (4) stainless ones for mounting from engine to standoff/supports , can someone shead any light to this, am i missing them or something.
Derek
Hide Signatures
       Post #: 468
RE: 30cc Edge 540 build - 4/17/2012 9:24 PM
bemeson
Score: 100
Status: offline
You need to supply them yourself.
Hide Signatures
       Post #: 469
RE: 30cc Edge 540 build - 4/30/2012 8:17 AM
schutter
Score: 100
Status: offline
Just finishing build everything went really good, im just at the point of putting the decals on it, when i took apart the decals package there was only one full length piece of Transfer tape, and that piece isnt even long enough to do the biggest EDGE wing decal??? am i missing somthing or is this tape something im supposed to go track down and buy myself again?
Hide Signatures
       Post #: 470
RE: 30cc Edge 540 build - 4/30/2012 8:35 AM
mach2
Score: 125
Status: offline
HAHA!.   As I have been following this thread because I am planning on doing a 30cc build (this being the most likely), I wondered why this QB kit is made so well and is such an easy build;  why do they make the decals so hard to apply?  Yeah, I've read the manual and addendum multiple times, and I've thought, "who makes decals that aren't made with cut-out transfer tape already applied on top of them???"
Plane is easy to build.......the decals....well; get ready to pull your hair out!
Strange.
Jeremy
70" Revolver, DLE20
Hide Signatures
       Post #: 471
RE: 30cc Edge 540 build - 4/30/2012 12:09 PM
jchorsejeff
Score: 100
Status: offline
I completely agree about the decals. They are a serious pain. Takes longer to place them correctly than it did to build the plane. I didn't even use some that I was going to because my transfer tape wore out. I have been flying my plane that way for many months and since I like it so much I'm going to  get some custom graphics put on it. This plane is a blast you will love the way it fly's.
Jeff
Hide Signatures
(in reply to mach2)
       Post #: 472
RE: 30cc Edge 540 build - 4/30/2012 2:45 PM
skippyc5
Score: 100
Status: offline
Eliminate the decal headaches, and purchase the custom graphics package from Aeroworks.
Hide Signatures
       Post #: 473
RE: 30cc Edge 540 build - 4/30/2012 3:32 PM
greg palmer
Score: 100
Status: offline
Bad Brad graphics makes a very good graphics set for this plane.
Hide Signatures
(in reply to skippyc5)
       Post #: 474
RE: 30cc Edge 540 build - 5/14/2012 2:08 AM
jchorsejeff
Score: 100
Status: offline
I went with the B&E graphics on my plane and really like them. Flew eight flights on the edge today and it is rockin. Probably have more than 100 flights and knock on wood the plane is holding up great and the DLE is a great engine. I like it the engine so much I bought the 55cc version.
Jeff
Hide Signatures
       Post #: 475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
