CoosBayLumber
Joined: 1/20/2002 From: San Bernardino Calif Status: offline
I think Sport Pilot is expressing little real world reasoning. Most of the old kit plans I have, including Sterling, do not have the whole of the parts shown. The parts are referred to in the instructions, are shown in profile, but the configuration or thickness to the parts is often not shown, nor known simply be owning a set of plans. When the plans indicate to insert part F-2, F-3, F-4, at certain locations they seldom tell you what they look like lying flat. If you look at the actual die-cut sheet and read the part number, then the part can be identifyed as to shape. If the plan does not have a topview, how wide is the fuselage? I have done thousands of parts for lazer cutting and just having the plans does not mean you have a knowledge as to the exact shape. Plans can be scanned and inserted into CAD, but the linework via scanning is far from perfect or reproducible. The modern machines like the OCE'9500 can scan and print out the plan, but upon close magnification of each line while in CAD, you will see the makeup is a series of very small line segments which once copied, link together and become something resembling a line. Thus, and archive of the plan can be made, but not the whole kit. Wm.
_____________________________
www.mybloo.com/coosbay/laser/laser.html Thousands of Laser Cut parts, thousands
