XLT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> XLT
Page: [1]
Login
XLT - 11/28/2010 2:05 AM
PatternPilot
Score: 125
Last Login: 6/18/2013
Status: offline
anyone have a set of plans for the Bridi XLT ? need the root and tip airfoil for wing and stab.. plus the layout of the wing and stab...
scott
_____________________________
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
       Post #: 1
RE: XLT - 11/28/2010 2:35 AM
pitstop000
Score: 105
Last Login: 6/16/2013
Status: offline
Scott,
The tip airfoil is not on the plans; Root airfoil would also be in question if taken from plans since they were not drawn for cutting.
I have at least one set of original cores here though plus canopies. Are you planning a build?
Paul Pappas, AMA 42520
www.NECPO.org
Hide Signatures
(in reply to PatternPilot)
       Post #: 2
RE: XLT - 11/28/2010 4:05 AM
Paternguy
Score: 100
Last Login: 5/10/2012
Status: offline
I have them, shoot me a PM with your email and I will send it out to you.
Hide Signatures
       Post #: 3
RE: XLT - 11/28/2010 4:31 AM
pitstop000
Score: 105
Status: offline
Well that’s good, I had pulled them out to trace the airfoils but if Paternguy has them even better.
www.NECPO.org
Hide Signatures
(in reply to Paternguy)
       Post #: 4
RE: XLT - 11/28/2010 6:13 AM
PatternPilot
Score: 125
Status: offline
Yes looking to build so I need plans and the airfoils and or a set of wing and stab cores.
scott
Hide Signatures
(in reply to pitstop000)
       Post #: 5
RE: XLT - 11/28/2010 6:24 AM
PatternPilot
Score: 125
Status: offline
Paul,
I still might need the tracings, I will let you know.
scott
Hide Signatures
       Post #: 6
RE: XLT - 11/28/2010 8:07 AM
Paternguy
Score: 100
Status: offline
My plans don't show the airfoils. Sorry
Hide Signatures
       Post #: 7
RE: XLT - 11/28/2010 4:50 PM
PatternPilot
Score: 125
Status: offline
Thanks to all that sent the plan files... now looking for airfoil drawings for wing, root / tip and stab root / tip
scott
Hide Signatures
       Post #: 8
RE: XLT - 11/28/2010 5:29 PM
doxilia
Score: 136
Status: online
Email sent
David.
Hide Signatures
       Post #: 9
RE: XLT - 11/28/2010 6:35 PM
SteveW
Score: 108
Last Login: 6/14/2013
Status: offline
quote:
ORIGINAL: PatternPilot
scott
I have an XLT kit in my stash. I could get a set of profiles from the cores if you like.
Hide Signatures
       Post #: 10
RE: XLT - 11/28/2010 7:59 PM
vertical grimmace
Score: 164
Last Login: 6/17/2013
Status: offline
Maybe if someone could identify what the airfoil was, that might make it easier. I am sure it was probably just an NACA 0015. This info would be better anyway, so when you make your templates or get your foam cut, the airfoil will be accurate and not a trace job. Many of the foam cutters offer the NACA series as standard.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to SteveW)
       Post #: 11
RE: XLT - 11/29/2010 1:15 AM
PatternPilot
Score: 125
Status: offline
Dox, I will check mail...
Steve.. Yep I might need those tracings to check with my airfoil program and make the templates and cut the wings..
Hide Signatures
(in reply to vertical grimmace)
       Post #: 12
RE: XLT - 12/1/2010 3:05 AM
pitstop000
Score: 105
Status: offline
Hi Scott,
So are you all set now for your build?
www.NECPO.org
Hide Signatures
       Post #: 13
RE: XLT - 12/1/2010 10:00 PM
PatternPilot
Score: 125
Status: offline
No... need the airfoils for wing and stab root / tip
Scott
Hide Signatures
       Post #: 14
RE: XLT - 12/1/2010 10:39 PM
doxilia
Score: 136
Status: online
Scott,
drop me a line in reply when you can. Since you will be cutting XLT cores, my email may be somewhat related.
Regarding airfoils, would it not be possible to extract these from the fuse side plan? One would need to compensate for the sheeting and such as well as for the planform but it sounds doable.
Maybe Paul managed to get you something.
David.
Hide Signatures
       Post #: 15
RE: XLT - 12/2/2010 9:39 AM
SteveW
Score: 108
Status: offline
Okay, I'll get it unpacked today.
Hide Signatures
       Post #: 16
RE: XLT - 12/3/2010 6:40 PM
Roguedog
Score: 105
Status: offline
Scott,
Here you go. I made these templates right off the XLT plans as mine show the dihedral locations on the side view. I am speculating that the oulline for the wing tip and stab tip ribs represent the actual size.
The plans call for 1/16" sheeting which is represented on the attached templates.
Bryan
Click to see fullsize image.
Click for fullsize
Click to see the file in new window.Attachment.pdf
Any society that would give up a little liberty to gain a little security will deserve neither & lose both-Benjamin Franklin
Hide Signatures
       Post #: 17
RE: XLT - 12/3/2010 10:52 PM
Taurus Flyer
Score: 123
Status: offline
Bryan,
Airfoil of the root looks like n64015a (more exact n64014.5a).
The airfoil of the stab also looks like n640xxa but not so exactly as the wing.
Tip airfoils? Not yet verified. Who knows?
Cees
Click for fullsize
Hide Signatures
(in reply to Roguedog)
       Post #: 18
RE: XLT - 12/23/2010 1:31 PM
pitstop000
Score: 105
Status: offline
Hey Scott,
Have you gotten what you needed for the cores?
www.NECPO.org
Hide Signatures
       Post #: 19
RE: XLT - 12/23/2010 3:08 PM
EscapeFlyer
Score: 120
Status: offline
quote:
ORIGINAL: Taurus Flyer
Bryan,
Airfoil of the root looks like n64015a (more exact n64014.5a).The airfoil of the stab also looks like n640xxa but not so exactly as the wing.
Cees
Wow.
How do you guys know this stuff??
Wouldn't it be funny if Mr. Bridi simply drew out the profile, independant of airfoil NA numbers, etc...
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to Taurus Flyer)
       Post #: 20
RE: XLT - 12/23/2010 6:39 PM
stuntflyr
Score: 137
Status: offline
They trace it out and find which published airfoil it fits. A lot of models use airfoils traced off the side of a size 11 wingtip dress shoe!
Chris...
Hide Signatures
(in reply to EscapeFlyer)
       Post #: 21
RE: XLT - 12/23/2010 7:19 PM
EscapeFlyer
Score: 120
Status: offline
quote:
ORIGINAL: stuntflyr
Chris...
LOL
I LOVE IT!!!!
Hide Signatures
(in reply to stuntflyr)
       Post #: 22
RE: XLT - 12/23/2010 8:26 PM
Taurus Flyer
Score: 123
Status: offline
quote:
ORIGINAL: Ilikebipes
Bryan,
Cees
Wow.
Brian
Brian.
Redesign and reconstructing a model is as important as designing a new one IMO and there are more important reasons to find out the original airfoils.
First the right dimensions of airfoils can be very important, especially these of this model and with fully sheeted wings. When using a NACA 24xx we have a much easier job to do, not so critical.
Knowing the basic airfoils we also can print all individual ribs with an Excell program and when some parts are lost, reconstructing them is easy.
Old plans are often copies of copies or we see not accurate airfoils examples of a kit.
There can be a difference between root and tip airfoil, part of design consideration of the designer.
To show the difference between two of them, NASA Langley 64 012 and 64 012A: Cutting with a too hot wire and you make the 64-012 instead of the 64-012A LOL
After some time you can read an airfoil like a character.
Cees
Click for fullsize
Hide Signatures
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.531RCU1
