RE: New Great Planes Escapade 61.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mikado Logo XXTREME Combo - RTF
Seller:  Hegemonoius
Details:   $2,975.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: New Great Planes Escapade 61.
Page: <<   < prev  4 5 6 7 8 9 10 11 12 [13]
Login
RE: New Great Planes Escapade 61. - 9/10/2012 6:58 PM
coronabob
Score: 110
Last Login: 5/18/2013
Status: offline
My buddy received his replacement Escapade this past Friday. He is very happy with the exception that he now has to buy a new engine, batteries, etc. Great Planes is A OK in my book.
Hide Signatures
(in reply to suburban95)
       Post #: 301
RE: New Great Planes Escapade 61. - 9/18/2012 4:33 PM
suburban95
Score: 100
Last Login: 5/16/2013
Status: offline
Well I did get a reply from Hobbico to send whatever parts I had left from the crash and pictures along with a copy of the email from them to Hobby Services and they would look into it. They also mentioned that they had a 90 day warranty policy so I should include a copy of the receipt which I did.
Been a week now and have not heard from them although they did recieve the parts the next day after I shipped it. I guess only time will tell. Still haven't found the wing and probably never will. If I had the wing I would be better able to tell if the wing tabs delaminated but either way something let loose and caused the wing departure.
Maybe BAX can tell me the status............
HOLD ON!!! JUST WALKED INTO MY OFFICE AND FOUND THAT UPS DROPPED OFF A HUGE BOX FROM HOBBY SERVICES ITS A NEW PLANE!!!!
WAY TO GO GREAT PLANES!!!!!!!!!!
< Message edited by suburban95 -- 9/18/2012 5:40 PM >
Hide Signatures
       Post #: 302
RE: New Great Planes Escapade 61. - 9/19/2012 2:51 AM
GTMUSTANGCS
Score: 100
Last Login: 12/6/2012
Status: offline
I was thinking of the Escapade as a second plane. It's only a little more than the 4 star 60 kit. Is this a good choice? I would be happy to build the 4star, but the Escapade is such a nice looking plane. Thanks Joe
Hide Signatures
       Post #: 303
RE: New Great Planes Escapade 61. - 9/19/2012 2:14 PM
fast_eddie70
Score: 100
Last Login: 10/28/2012
Status: offline
I think the Escapade is a great second plane in 40 or 60 size..
_____________________________
Fast Eddie
Club AAM / Colorado - www.arvadamodelers.com
Hide Signatures
(in reply to GTMUSTANGCS)
       Post #: 304
RE: New Great Planes Escapade 61. - 9/19/2012 3:31 PM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Ditto, easy to fly in my opinion. Doesnt even need a huge engine to fly well.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to fast_eddie70)
       Post #: 305
RE: New Great Planes Escapade 61. - 9/19/2012 5:06 PM
suburban95
Score: 100
Status: offline
I agree the Escapade flew great right out of the box, as I mentioned in my earlier post it only required a couple of clicks of elevator to fly hands off. I had an OS91 4 stroke in mine and it flew well but definitely not a speed demon. I wanted to change the prop to see if that would make it a little faster but the WING DEPARTED before I had a chance.
KEEP IN MIND to re-enforce the wing Root tabs before you fly it there have been several reports of the plywood root rib tabs delaminating and the wing dropping out of the aircraft (Ask me how I know!) Other than that its a very nice airplane.
Hide Signatures
(in reply to jeffie8696)
       Post #: 306
RE: New Great Planes Escapade 61. - 9/30/2012 3:54 PM
Super08
Score: 135
Last Login: 5/17/2013
Status: offline
I went out flying yesterday with the new stab I bought from Tower after the first one fell apart in the air after three flights. This one only lasted two before it broke. My plane has the 95AX on it and it is just too fast for what the airframe will allow. The tail either needs flying wires of be built stronger. The damage is not from high G but from high speed level flight. I repaired it last night and added hardwood supports and I am going to go back out and test it today and see how it holds up. Every Escapade up here has broke in the same way whether it was a 40 or 60 size version. They break right at the point of the trailing edge spar where the hard wood doubler stops. Then the leading edge will fracture some point inboard from that. This time it was right in the center. Usually it is about 2" out from center. I attached pictures showing where I cut out a section of the balsa trailing edge and fitted in a section of 3/16" x 3/8" hardwood.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
       Post #: 307
RE: New Great Planes Escapade 61. - 12/12/2012 7:17 PM
VictoryRoll
Score: 100
Last Login: 5/5/2013
Status: offline
Based on above comments on both the wing and the stabilizer failing, I was very interested in buying, but now am VERY hesitant.  I have a brand new Saito FA-100 GK, and don't want to lose almost $350, in addition to my digital servos, receiver, et al.
I love to ARF bash and add wing wires, drop the elevator and rudder servos in the back of the fuse w/ short 4-40 rod setup, etc.  Hence, I wouldn't want to put all that work in, and then have either the wings or the stab fail.
Am I too fearful or .....?????
Thank you in advance for your suggestions/comments.  They are truly appreciated.
Don
AMA#905932
Club Saito Member #691
Hide Signatures
(in reply to Super08)
       Post #: 308
RE: New Great Planes Escapade 61. - 12/12/2012 8:19 PM
landeck
Score: 137
Status: offline
I have been flying my Escapade 40 with a Magnum 46 for five years and my Escapade 61 with a Fox 74 Eagle IV for two years without any problems. The plane calls for a 61 to 75 two stroke engine; puting a 95 two stroke in it overpowers the plane and puts stress on it it was not designed for. You should be fine using a Saito 100 four stroke engine.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
(in reply to VictoryRoll)
       Post #: 309
RE: New Great Planes Escapade 61. - 12/12/2012 11:00 PM
VictoryRoll
Score: 100
Status: offline
Thank you, once again, Bruce... you be da' man !
I was wondering about the Pulse vs. the Escapade... If you  were in my shoes, (Intermediate Flyer on cusp of advanced) which one would you choose (w/ this powerplant FA100) and why would you make that decision?
It also seems that NO ONE has stepped forward on these posts/threads for the Pulse, should  I read something into that?
I don't want to go too low and have something that is going to be boring, but I am also afraid of pushing too hard and failing.  You seen to have quite a bit of knowledge and experience (although I am not sure you have the Pulse 60), so any and all of your comments/suggestions/ideas, are truly appreciated and respected.
As you know, I also have the Revolver 70" as #1 on my top-4 list... It looks the best of the crowd and performs like a top... next i would say is the Escapade (as long as I can be convinced it will hold-up to some snaps, fast-straights, and fast spins, third is the Pulse 60, love the looks, the Saito FA-100 GK looks awesome in her and it seems like it could be somewhat fun.... last is the Hanger 9 Decathlon 70" (I believe)... I KNOW it has some great sport/aerobatic capabilities, but the look is so much like other high-wing'rs I already own.
Am I right in understand the Escapade is more "sport/aerobatic" than the Pulse?   I love flat-spins and am trying to perfect them, so maybe that would help in your assessment??
Please feel completely open to say what you want, as I am looking for good, critical-eye-type comments, and trust you from previous replies on this topic/thread!
Thanks so much for your help.
Fond Regards,
Don
AMA#905932
Hide Signatures
(in reply to landeck)
       Post #: 310
RE: New Great Planes Escapade 61. - 12/12/2012 11:34 PM
Super08
Score: 135
Status: offline
Bruce if you look again it is designed for a .61 to .95 two stroke or a .91 to 1.20 four stoke.
Hide Signatures
       Post #: 311
RE: New Great Planes Escapade 61. - 12/13/2012 12:04 PM
landeck
Score: 137
Status: offline
quote:
ORIGINAL: Super08
Super08, you are right ! I just checked the manual and that is what it says. We have two out at the field, one with a OS .91 and mine with a Fox .74. Both have been flying for a year and a half without any problems. How has yours been holding up since the modification you made to the stab?
Bruce
Bruce L. AMA# 54227
Hide Signatures
       Post #: 312
RE: New Great Planes Escapade 61. - 12/13/2012 12:13 PM
landeck
Score: 137
Status: offline
fishingships, I have both the Pulse XT 60 and the Escapade 61. I also have the Revolver 70. The Escapade 61 is more sport aerobatic than the Pulse while the Pulse tends to float more on landings. I don't think you will get quickly board with the Pulse. There is a thread on here on the Pulse. Of the three planes mentioned I would go first with the Revolver 70, then the Escapade 61, and then the Pulse XT 60 but you really can not go wrong with any of the three planes with your Saito 100 engine.
Bruce
P.S. I have been flying RC for 40 years and building and flying models for 60 years. Given all that I still consider myself only an intermediate flyer. At my age I am just happy not to be progressing backward in my flying skills.
Bruce L. AMA# 54227
Hide Signatures
       Post #: 313
RE: New Great Planes Escapade 61. - 12/13/2012 4:21 PM
Super08
Score: 135
Status: offline
quote:
ORIGINAL: landeck
quote:
ORIGINAL: Super08
Bruce
The mod works as I hoped. I could do anything I wanted and no problems with it breaking anymore. Sadly I ended up losing it in a mid air with a friend one day when we were horsing around.
Hide Signatures
       Post #: 314
RE: New Great Planes Escapade 61. - 12/13/2012 8:03 PM
VictoryRoll
Score: 100
Status: offline
HI Bruce!
 Once again, my sincere thanks.  You have been a great help to me.  It's either the Pulse, because I love the looks of this plane, AND the airelon servos are INSIDE the wing, or  the Escapade as it will be a better aerobatic.   I may, believe it or not, strip the Escapade and cover it with my own desired colors,  beef up points mentioned in this thread where fractures/failures are happening and fit with nylon pinned hinges, as I suspect all pre-hinged surfaces are CA hinges (am I right?) and put the servos inside the wing.
Any thoughts on those mods???
Problem is, do I want to do all of that on a $190 plane?
I am also thinking the Hitec HS-5496MH Digital Servos will be a nice fit.     http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAEXW&P=K
Talk about a fickle buyer, huh?
Thank you so much Bruce, and as I suspected, you have lots of experience !   I am 58 yrs. old.  I started building (an original Carl Goldberg Falcon 56 w/ OS MAX 35X) back when I was about 19 or 20.   College and money got in the way and I never finished the Falcon 56 (wish I still had her), but I still own the OS Max 35S (probably going to sell the engine soon).  I got back in the hobby about 7 years ago and now realize how much I missed.   Marriage, children, work and a very bad bicycling accident (hit by a car) got in the way until then.   I am still partially disabled but love this hobby!   It is great talking with all the knowledgable people on these forums and learning new things.
Again, you have been very helpful and thank you for taking the time for me, and all who may benefit from your experience and input.
Don
AMA#905932
Hide Signatures
       Post #: 315
RE: New Great Planes Escapade 61. - 12/14/2012 3:21 PM
VictoryRoll
Score: 100
Status: offline
Well, after all of my waffling, I went to my LHS (which isn't so local) and decided on the Revolver.  The fit & finish of this plane is so much better than the other two, with AIRE servos tucked neatly in the wing, not sticking out in the wind, a pet-peeve of mine.
I am dying to get it, but I don;t think I will see it before Dec. 24th, maybe?? (which is my birthday!)
Anyway, I am very grateful for all inputs and appreciate all of you for helping me and taking the time to help me.
I'll let you know how I make out with the build (which should be short & sweet) and it's flight.
Thanks again,
Don
AMA#905932
Hide Signatures
       Post #: 316
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.924RCU1
