iskandar taib -> RE: Simple Method To Find T.D.C. (top dead center) (7/25/2011 4:47 PM)
I used to carve up cheap RC sport engines and use them in Combat. Just retiming the crank did wonders, I didn't try raising the exhaust. My "usual" numbers for the crank were 35 degrees ABDC to 57 degrees ATDC (or sometimes 65). Very crudely measured - I scratched lines on a stiff piece of transparent plastic, lined up two crosshairs with the mold flashing and the bottom of the mounting lugs, lined up the middle of the crankpin with a marking, and scratch a line on the shaft. Then grind with a stone. OS engines had TOUGH cranks, Brats, Leos and Magnums were considerably softer. I'd run 7x6 Taipans on .28s and Scimitar 8x6s on .36s. Typically on 25% nitro. Always slower than a Nelson, of course - the Magnum .36 had a 12.5mm crank, the Nelson a whopping 17mm. The Magnum would be about as fast as an unmodified Mark IV, but it eventually spit the front of the crank out, along with the front bearing. Iskandar
