xtm 24.7 rrp clutch bell
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> xtm 24.7 rrp clutch bell
Page: [1]
Login
xtm 24.7 rrp clutch bell - 8/3/2003 5:28:52 PM
Maxxer
Status: offline
I need to know if the RRP hardened steel clutch bell for the
T-MAXX will stand up to the xtm 24.7?! I keep striping stock ones.
       Post #: 1
Even A stock one should hold up to it! - 8/3/2003 6:36:06 PM
Legendary
Status: offline
I have yet to completly strip out a clutch bell and I am running a Force .25 which has about the same power as the 24.7. Maybe there is a problem with how it is fitting together?? If it is too tigh or too loose it can cause problems as well as if it is not centered right.. The best thing for you to do is get an 1/8 setup for it! Maybe the added size will help?? If it is not the other stuff?
(in reply to Maxxer)
       Post #: 2
xtm 24.7 rrp clutch bell - 8/3/2003 11:59:41 PM
adeoliver
Status: offline
Stock bells are not prone to strip unless your mesh is out of wack, Ive stripped 1 cluth bell due to the engine mount comeing loose, and that was with a worn out OS Hyper .15. My buddy has been running a Hyper 21 with a stock maxx setup and only stripped 1 clutch bell due to a bad mesh, so its not the parts that are failling its the mesh your useing!!
_____________________________
Email= protmaxx_os@hotmail.com
       Post #: 3
xtm 24.7 rrp clutch bell - 8/4/2003 12:22:24 AM
SixVi6-Camaro
Status: offline
Its probably because you are runnning a steel spur gear and an extended chassis that is flexing. when the chassis flexes, usually on the landing of a jump, the mesh gets out of whack and if you are on the throttle it mangles the clutchbell.
       Post #: 4
xtm 24.7 rrp clutch bell - 8/4/2003 12:41:34 AM
Maxxer
Status: offline
I am running a RRP steel spur gear, but what is the proper mesh?
I've heard you should be able to run a piece of paper through the gears without the paper ripping.
       Post #: 5
xtm 24.7 rrp clutch bell - 8/4/2003 3:01:17 AM
littlepiston
Status: offline
[QUOTE]Originally posted by adeoliver
Stock bells are not prone to strip unless your mesh is out of wack, Ive stripped 1 cluth bell due to the engine mount comeing loose, and that was with a worn out OS Hyper .15. My buddy has been running a Hyper 21 with a stock maxx setup and only stripped 1 clutch bell due to a bad mesh, so its not the parts that are failling its the mesh your useing!! [/QUOTE]
HEHEHEH FUNNY ive striped two in less than three gallons and one a long time ago on my MBX
       Post #: 6
xtm 24.7 rrp clutch bell - 8/4/2003 11:16:51 PM
adeoliver
Status: offline
[QUOTE]Originally posted by littlepiston
HEHEHEH FUNNY ive striped two in less than three gallons and one a long time ago on my MBX [/QUOTE]
And what was the cause? Running a steel spur gear in that mbx??
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
