RE: What Aircraft are you installing your DLE20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Page: <<   < prev  29 30 [31] 32 33 34 35 36 37 38   next >   >>
Login
RE: What Aircraft are you installing your DLE20 - 4/12/2011 3:25 AM
MetallicaJunkie
Last Login: 5/17/2013
Status: offline
Ok finally some pics of my hybrid Yak from VVRC .... i have hitec 5925 on ailerons(140oz) a 5985(180oz) on elevator, a 5625(130oz) on rudder, and a 225mg on throttle. Im also using a 42% opto engine kill... the first one i had back in 08 took a crap on me... i hope to have better luck with this one. I also decked it out with some aluminum wheels from http://aztechaero.goods.officelive.com/SpotOnWheels.aspx acording to Azahr the owner they will be selling larger sizes soon!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to zoaartcc)
       Post #: 751
RE: What Aircraft are you installing your DLE20 - 4/12/2011 5:45 AM
Indiomike
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: MetallicaJunkie
Now maybe my thinking is wrong but between ailerons, elevator, and rudder, I have been led to believe the rudder is the one control surface that should have the strongest servo, especially for 3D type flying. You have the weakest one there (excluding the throttle servo) Wouldn't it be better to swap your rudder and elevator servos in your set up? Just an observation on my part. Of course you should do as you please.
Mike
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 752
RE: What Aircraft are you installing your DLE20 - 4/12/2011 6:07 AM
MetallicaJunkie
Status: offline
quote:
ORIGINAL: Indiomike
Mike
the reason i did it that was,since it only uses one servo for the elev stab, i wanted to use a beefier servo .... if i see that the rudder is inefective ill put a 7985 on it...and swipe one from the throttle on one of my gassers and happily replace it with a 5625 more than sufficient for throttle
Hide Signatures
(in reply to Indiomike)
       Post #: 753
RE: What Aircraft are you installing your DLE20 - 4/12/2011 6:38 AM
microdon2
Last Login: 5/14/2013
Status: offline
MetalJunkie - LIKE the shiny metal wheels!! I might just have to go there myself.
Hide Signatures
       Post #: 754
RE: What Aircraft are you installing your DLE20 - 4/12/2011 7:29 AM
zoaartcc
Last Login: 6/23/2012
Status: offline
Great looking aircraft and nice looking wheels. Love the photo of the engine box bet it is the cats meow!
Dr. Dan, M.D.
M.aster of D.isaster
Hide Signatures
       Post #: 755
RE: What Aircraft are you installing your DLE20 - 4/12/2011 8:39 AM
MetallicaJunkie
Status: offline
quote:
ORIGINAL: zoaartcc
thanks! many thnks to Jody of VVRC for answering all my PMs, he really helped me
Hide Signatures
       Post #: 756
RE: What Aircraft are you installing your DLE20 - 4/12/2011 1:07 PM
SpinnerRow
Status: offline
Your rudder servo will be fine. I loved mine (for three flights any way) so I know you are going to have fun with yours.
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
       Post #: 757
RE: What Aircraft are you installing your DLE20 - 4/12/2011 1:51 PM
Clay Walters
Status: offline
Just wanted to report that my DLE-20 proved to be a great combination in my Pulse 125XT this past weekend. Mine weighs 10lbs 3 ozs dry, has great speed and vertical with an APC 16x8 prop. I need to find a different main gear though as our field is grass and somewhat uneven and the nose over tendancy with the stock gear is pronounced.
Regards,
Clay
If it ain''''t yours; don''''t touch it!
Hide Signatures
(in reply to SpinnerRow)
       Post #: 758
RE: What Aircraft are you installing your DLE20 - 4/12/2011 6:51 PM
MetallicaJunkie
Status: offline
quote:
ORIGINAL: Clay Walters
Regards,
Clay
Glad you liked it.... The DLE 20 is the perfect replacement for .90 - 1.20 glow engines ,,,,,,,,,,you might want to consider reversing the landing gear... i had to do it on a pulse 60 i had, and a buddies 125 with a saito 150
*edit Just got back from maidening http://www.valleyviewrc.com/Yak%2054%20Pro%20SD%20Model.htm i was amazed at how well it flys. It does a great knife edge, decent snaps, awesome flats pins, and killer knife edge spins. Its deinitely THE BEST profile i have ever flown... not to mention the DLE 20 is perfect for this plane, mine came out at 8.2 #s RTF(no gas) and the CG Jody of VVRC gave me was spot on,, right on the wing tube
Hide Signatures
(in reply to Clay Walters)
       Post #: 759
RE: What Aircraft are you installing your DLE20 - 4/20/2011 10:09 AM
sandyjain
Last Login: 5/7/2013
Status: offline
Just curious if any one has tried this combo - Seagull Edge 540 60-90 with the DLE20
Specs of the model are:
Wingspan: 68.2 in (173.2 cm)
Overall Length: 60.6 in (254 cm)
Wing Area: 753 sq in (48.6 sq dm)
Flying Weight: 8.4–8.8 lb (3.8–4 kg)
Engine Size: .61–1.00 2-stroke; .91–1.25 4-stroke
I was until recently flying the DLE20 in a Seagull Extra 260 90 having similar specs as above and it was a great combo.
Thank in advance for any tips and pix.
Cheers....
Sandy Jain
Hide Signatures
       Post #: 760
RE: What Aircraft are you installing your DLE20 - 4/20/2011 1:25 PM
a1pcfixer
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: sandyjain
Nobody yet has in this thread, but you'll find 18 hits on such when you search the New DLE20cc gas eng thread.
The DLE20cc gasser=1.20 glow (on steroids), so if it fits you might be good to try it.
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
(in reply to sandyjain)
       Post #: 761
RE: What Aircraft are you installing your DLE20 - 4/20/2011 2:13 PM
sandyjain
Status: offline
Thanx Jim. I am indeed following up with those guys in the other thread as well.. :-)
Cheers....
Sandy Jain
Hide Signatures
(in reply to a1pcfixer)
       Post #: 762
RE: What Aircraft are you installing your DLE20 - 4/20/2011 8:02 PM
abreimeris
Last Login: 3/12/2013
Status: offline
I have this Seagull Edge 540 combo. It is real nice...tons of power! Post 14 has a picture of it.
Hide Signatures
       Post #: 763
RE: What Aircraft are you installing your DLE20 - 4/20/2011 8:38 PM
RCplanman
Last Login: 4/24/2013
Status: offline
abreimeris, Sir, does the plane set on it's wheels with the wing off? thanks, Bill
Hide Signatures
(in reply to abreimeris)
       Post #: 764
RE: What Aircraft are you installing your DLE20 - 4/20/2011 9:09 PM
sandyjain
Status: offline
quote:
ORIGINAL: abreimeris
Thanx...great to know that it flies well.
What is the CG that you are using ?
Are you using rudder pull pull or the servo at the tail ?
are you using stock U/C or different - I found the stock U/C to be very light and small.
Any more pics of your build will be very welcome....
Cheers....
Sandy Jain
Hide Signatures
       Post #: 765
RE: What Aircraft are you installing your DLE20 - 4/20/2011 9:24 PM
abreimeris
Status: offline
Yes the plane sits on the wheels with the wings off.
Hide Signatures
(in reply to RCplanman)
       Post #: 766
RE: What Aircraft are you installing your DLE20 - 4/21/2011 7:17 AM
TimBle
Status: offline
shoe! That's a relief. If it did not sit on its wheels, hand launching could be tricky...
Hide Signatures
       Post #: 767
RE: What Aircraft are you installing your DLE20 - 4/21/2011 8:02 AM
mschulz531
Status: offline
quote:
ORIGINAL: TimBle
Gold Wing Su-26m/DLE-30, Twist 60/Saito 1.15, Airtronics 2.4 Ghz SD-10G.
Hide Signatures
(in reply to TimBle)
       Post #: 768
RE: What Aircraft are you installing your DLE20 - 4/22/2011 6:09 AM
Planeclothes
Last Login: 5/10/2013
Status: offline
I am confused here, your plane does not look like this http://www.horizonhobby.com/Products/Default.aspx?ProdID=SEA4000#quickSupport
Are they not the same?
I'm only in it for the money...
Hide Signatures
       Post #: 769
RE: What Aircraft are you installing your DLE20 - 4/22/2011 8:43 AM
sandyjain
Status: offline
Hey Planeclothes, to me it looks the same and I have the same being built right now....
It is the Seagull Edge 540 60
Cheers....
Sandy Jain
Hide Signatures
(in reply to Planeclothes)
       Post #: 770
RE: What Aircraft are you installing your DLE20 - 4/22/2011 9:29 AM
mschulz531
Status: offline
What is the weight of the Seagull Edge 540 60 size?
The Horizon Hobby web site does not show the weight.
Hide Signatures
       Post #: 771
RE: What Aircraft are you installing your DLE20 - 4/22/2011 11:11 AM
a1pcfixer
Status: offline
quote:
ORIGINAL: mschulz531
Sure it does, under the 'Specs' tab.
Jim L.
Hide Signatures
(in reply to mschulz531)
       Post #: 772
RE: What Aircraft are you installing your DLE20 - 4/22/2011 3:52 PM
mschulz531
Status: offline
quote:
ORIGINAL: a1pcfixer
 Don't know how I missed that.  Thanks. Must need new glasses.
Hide Signatures
       Post #: 773
RE: What Aircraft are you installing your DLE20 - 4/22/2011 4:43 PM
Planeclothes
Status: offline
quote:
ORIGINAL: sandyjain
I am looking at the pictures he posted (post #14) and the ones from the plane's manual. His plane has an engine box that I don't see in the manual's pictures. Am I missing something?
Hide Signatures
       Post #: 774
RE: What Aircraft are you installing your DLE20 - 4/22/2011 7:44 PM
planebow
Last Login: 10/31/2012
Status: offline
I have an early version and a newer version.  They both have engine boxes but are slightly different.  Are you sure you are looking at the  correct manual as they have a couple different 540's
Hide Signatures
       Post #: 775
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.250RCU1
