RE: What Aircraft are you installing your DLE20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Page: <<   < prev  34 35 [36] 37 38 39 40 41 42 43   next >   >>
Login
RE: What Aircraft are you installing your DLE20 - 7/15/2011 4:33 AM
stanordave
Score: 100
Last Login: 5/19/2013
Status: offline
Just finishing up a Mojo 65..
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to codimasta)
       Post #: 876
RE: What Aircraft are you installing your DLE20 - 7/15/2011 5:37 PM
boostoman
Score: 100
Last Login: 5/7/2013
Status: offline
Im  Have the attached bi-plane
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15402
Pitts Phython S-12 54" wing span.
do you guys think  a DLE-20 will not be too heavy for this plane?
Hide Signatures
(in reply to stanordave)
       Post #: 877
RE: What Aircraft are you installing your DLE20 - 7/15/2011 5:46 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: boostoman
Pitts Phython S-12 54'' wing span.
Too big, too powerfull, too much for such a little bipe.
It's designed for an electric setup, and the DLE20cc gasser might just rip the wings off that bipe!
Go back to the beginning of this msg thread, and read Post #3.
You'll do good with a model that requires a glow in the .90 - 1.20 size range.
That's what the DLE20cc replaces well.
_____________________________
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
(in reply to boostoman)
       Post #: 878
RE: What Aircraft are you installing your DLE20 - 7/21/2011 6:09 PM
stanordave
Score: 100
Status: offline
Maidened a GP reactor bipe w/the DLE-20 today!
Good match for the plane.
Had fun w/the electric version and the gasser is just as fun only..no waiting for batteries to charge!
cheers,
Mike
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to a1pcfixer)
       Post #: 879
RE: What Aircraft are you installing your DLE20 - 7/21/2011 6:58 PM
steinywi
Score: 105
Last Login: 5/20/2013
Status: offline
Yep, been flying this combo for a while! What a blast!
Steiny
I did go ftom a 17x7 to a 16 x8 for clearance.
Hide Signatures
       Post #: 880
RE: What Aircraft are you installing your DLE20 - 7/22/2011 4:56 AM
stanordave
Score: 100
Status: offline
I'm going to the 16x8 also. While I prefer the 17x6, I don't really notice the difference..
Hide Signatures
(in reply to steinywi)
       Post #: 881
RE: What Aircraft are you installing your DLE20 - 7/22/2011 7:29 AM
boostoman
Score: 100
Status: offline
i just finished building the Hobbyking Pitts Python S-12 54" and I was thinking of installing my DLE 20 on it. with a 16x8 prop there is loads of clearance for a 17"prop which would be great for 3D. my only worry is that the wing area is alot less 712 sq in compared to 1145 sqin of the Reactor.
Hide Signatures
       Post #: 882
RE: What Aircraft are you installing your DLE20 - 7/22/2011 12:36 PM
steinywi
Score: 105
Status: offline
My Reactor came in at 7.5lbs with 2-1500 batts (still on 72mhz). What would be the all up weight with the motor? The Reactor flies very lite, loves to float in on landing. I'm not sure on your combo,
Steiny
Hide Signatures
       Post #: 883
RE: What Aircraft are you installing your DLE20 - 7/22/2011 1:55 PM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: boostoman
i just finished building the Hobbyking Pitts Python S-12 54'' and I was thinking of installing my DLE 20 on it. with a 16x8 prop there is loads of clearance for a 17''prop which would be great for 3D. my only worry is that the wing area is alot less 712 sq in compared to 1145 sqin of the Reactor.
Insuffecient wing area, wing loading, it's designed for electric power NOT a gas -or- glow eng, and airframe is ONLY 4.1 lbs.
How many bad points do ya need, to know it's a very bad combo?
Sure hope you have good insurance if you do make the mistake of going that route.
Over the past 10 months, many have posted asking "Is this engine
a good match to this xxx-xxx model?
Some don't do their homework (read this thread), some don't understand
this engine's incredible power. Others are just new to gassers.
So maybe a very rough guideline of sorts might help some in deciding
if this DLE20cc gas engine is -or- is not a good match for their model.
This DLE20cc gas engine, is a drop in replacement for most any model
aircraft requiring a glow engine of .90 -to- 1.20 size.
So, if the specs on your model states .90 -to- 1.20, then this DLE20cc
is very likely a good match!
If your model states ONLY .90, then maybe. Things like wing area, wing
loading, assembled weight, and so on will determine if it's a good match.
If your model's specs state anything less than a .90 size engine, then
most like it's NOT a good match! There are a few exceptions.
Overall, roughly speaking; this DLE20cc will be good for many model
aircraft requiring a glow engine of a range of between .90 -to- 1.20 size,
and weighing between 7 lbs -to- around abouts 20 lbs.
For 3D'ing
; 7-9 lbs but the closer you get to 9 lbs, the slower pull-outs
from a hover, will be.
General sport flying; 9-13 lbs (roughly speaking), and still be spirited.
Scale flying; 10-20 lbs, but as you exceed 14 lbs it may be a bit sluggish.
A long take-off may be needed, a large wing span WILL be helpfull!
In ALL cases, reinforcing the firewall for the stresses of a gas engine
is a very wise move!!!
One other issue to consider in matching this DLE20cc gas engine to your
model will be prop -to- ground clearance. The sweet spot of engine
torque/thrust for this engine is with a 17" prop. Yes, DLE states the
prop range as 14x10 - 17x6, but the 17" props are right in it's power band.
That brings up issues of ground clearance on some potential selections of
models. Some warbirds (and other models) may have issues of prop -to- ground
clearance. If your chosen model states .90 -to- 1.20 then you should be OK.
If you can stuff this DLE20cc into your model, but have ground clearance
issues, then a 3 or 4 bladed prop may be required, or go with a smaller
prop.
This DLE20cc gas engine has more power than a CRRC Pro 26 or a Saito 1.25
(Saito FG-20/gasser) and is a drop in replacement for most any model
Proceed accordingly!
Jim L.
Hide Signatures
       Post #: 884
RE: What Aircraft are you installing your DLE20 - 7/22/2011 2:01 PM
lazyace
Score: 100
Status: offline
+1 read this thread !!!!!
charlie AMA 8916
WACO brotherhood #67
Hide Signatures
       Post #: 885
RE: What Aircraft are you installing your DLE20 - 7/22/2011 5:07 PM
steinywi
Score: 105
Status: offline
Reactor Bipe. 60 size! Great combo!! just proves your not right all the time!
Steiny
Hide Signatures
       Post #: 886
RE: What Aircraft are you installing your DLE20 - 7/22/2011 5:37 PM
boostoman
Score: 100
Status: offline
pcfixer,
the electric setup i have on this plane is just 200 grams lighter than a DLE setup I actually weighed all the items require for the dle setup and the items needed for an electic setup.  so if this plane flys well with the elctgric setup then i will convert it to the DLE20 and see how it goes.
Hide Signatures
       Post #: 887
RE: What Aircraft are you installing your DLE20 - 7/22/2011 6:25 PM
a1pcfixer
Score: 168
Status: offline
Steiny,
Never said I was, but if YOU think so.....thanks!
His bipe is NOT a good candidate for a DLE20. In his case it's like putting an eng 3x the recommended size in it.
Being designed for EP, how long do ya think it's frail firewall might handle the vibrations of a gasser?
My guide is just that, only a guide, not law, not rule. As such it's up to others to determine if they have the wing area to handle this eng, without over loading the wing loading values and creating a barely enjoyable model combo. Consider yourself very lucky.....so far. I'll be curious to see how many .60 models with a DLE20 will still be flyable come next year.
Reading is fundamental, comprehension is an acquired skill!
Jim L.
Hide Signatures
       Post #: 888
RE: What Aircraft are you installing your DLE20 - 7/22/2011 7:30 PM
boostoman
Score: 100
Status: offline
i appreciate your help in this forum pcfixer and i understand your frustration.
but can you give me YOUR opinion what is the most enjoyable wing loading or cubic load numbers for a good acrobat plane and a mild 3D plane?
Hide Signatures
       Post #: 889
RE: What Aircraft are you installing your DLE20 - 7/22/2011 9:11 PM
MetallicaJunkie
Score: 243
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: steinywi
Steiny
a 60 2s has the same case as a 90 2 stroke... an OS 120ax is just a fat hair bigger...the DLE 20 is a drop for a 120 2 stroke ..... a plane that light and balanced properly should make for some wicked 3d
just dont do any abrupt full throttle maneuvers, like snaps, walls or blenders
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
       Post #: 890
RE: What Aircraft are you installing your DLE20 - 7/22/2011 9:46 PM
a1pcfixer
Score: 168
Status: offline
I'd go with a minimum W/A of at least 950sq.in. or higher, and an AUW of around abouts 7-8lbs.
Something suggesting a glow eng size range of .90 - 1.20
I have one at 952 sq.in. w/a & 8 lbs, another at 1224 sq.in. w/a but only 7 lbs.
For 3D models they fly great and are very predictable.
The biggest exception so far has been with various warbirds. Some have mounted this DLE20cc
into .60 sized warbird airframes with good results. Even though their w/a might be low, and wing
loading high, such are designed for a bit of speedy flying so it's doable.
Your bipe at 712 sq. in. w/a would be one handful to control & fly enjoyably.
You'd really need to stay on top of it at all times!
Ever hear experienced flyers say "he's flying behind the model" -or- "he's flying ahead of the model"?
Flying behind the model is what you'd have with a DLE20 on your bipe, always correcting it at every manuever.
Constantly staying on top of it just to keep control. Not my idea of enjoyable flying.
But what do I know. It's your call, I'd just like to see you with some sort of good combo, one you enjoy flying,
NOT one that causes you stress every time you fly it.
Proceed as you please.
Jim L.
Hide Signatures
       Post #: 891
RE: What Aircraft are you installing your DLE20 - 7/23/2011 6:59 AM
boostoman
Score: 100
Status: offline
pcfixer,
thanks for all the info. once i get it in the air with the electic setup. i will know how she flys, the other option i had was a 15cc gas engine which i know the power to weight ratio isnt good but its lighter than the DLE 20, so the wing loading will be less.
I have the DLE20 on a TMPro Katana 70 profile 945 sq in and its a joy to fly with amazing 3D flying.
Hide Signatures
       Post #: 892
RE: What Aircraft are you installing your DLE20 - 7/24/2011 2:26 AM
SpinnerRow
Score: 152
Status: offline
I'm putting together a Great Planes PT-17 with a JTech Standard size Pitts Muffler. Throttle has a ball link on it and was fairly easy to set up. I'll be using Power-HD DS090M on the control surfaces and a Hitec 5485HB on the throttle.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
(in reply to zoaartcc)
       Post #: 893
RE: What Aircraft are you installing your DLE20 - 7/24/2011 7:07 AM
Planeclothes
Score: 104
Last Login: 5/10/2013
Status: offline
Has anyone tried this plane? http://www.generalhobby.com/gold-wing-extra-300lp-20cc-65in-airplane-p-250.html
Seems perfect for the DLE20.
I'm only in it for the money...
Hide Signatures
(in reply to SpinnerRow)
       Post #: 894
RE: What Aircraft are you installing your DLE20 - 7/24/2011 7:31 AM
a1pcfixer
Score: 168
Status: offline
Perfect indeedy!
Sharp looking too.
But ya better hurry & order, only 4 left.
Jim L.
Hide Signatures
(in reply to Planeclothes)
       Post #: 895
RE: What Aircraft are you installing your DLE20 - 7/24/2011 2:49 PM
gregg660
Score: 100
Status: offline
SpinnerRow,
The PT17 and DLE20 is a great combo. You're going to like it for sure. Been flying hat combo for a few months now.
Gregg
Hide Signatures
       Post #: 896
RE: What Aircraft are you installing your DLE20 - 7/24/2011 3:37 PM
a1pcfixer
Score: 168
Status: offline
I found yours and 2 others whom have already done the same combo.......
http://www.rcuniverse.com/forum/fb.asp?m=10266107
http://www.rcuniverse.com/forum/fb.asp?m=10254336
http://www.rcuniverse.com/forum/fb.asp?m=10201342
That fake radial eng adds that extra bit of cool factor!
Jim L.
Hide Signatures
(in reply to gregg660)
       Post #: 897
RE: What Aircraft are you installing your DLE20 - 7/25/2011 9:42 PM
captain2
Score: 115
Last Login: 4/30/2013
Status: offline
the DLE20 with the SAPAC Extra330 - figure on starting with a Xoar 17x6. 69.5" span, comes in just below 10 lbs. - previously had a CRRC26/MA 16x8 in it, and it was great - lots and lots of pull. The DLE is bench running stronger than the CRRC and is 12 oz lighter. Amazing engine the DLE......
Hide Signatures
       Post #: 898
RE: What Aircraft are you installing your DLE20 - 7/25/2011 11:35 PM
Lifer
Score: 148
Status: offline
Plus 1 on the Captain's comments. I have a DLE 20 in a Seagull Miles Sparrowhawk and hope to test it tomorrow.
Hide Signatures
(in reply to captain2)
       Post #: 899
RE: What Aircraft are you installing your DLE20 - 7/26/2011 4:21 AM
Planeclothes
Score: 104
Status: offline
quote:
ORIGINAL: a1pcfixer
Perfect indeedy!
Sharp looking too.
Now it is down to 3, I just ordered one.
Hide Signatures
       Post #: 900
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
