RE: What Aircraft are you installing your DLE20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Page: <<   < prev  48 49 [50] 51 52 53 54 55 56 57   next >   >>
Login
RE: What Aircraft are you installing your DLE20 - 11/17/2011 7:11 PM
ahicks
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: acdii
I must have missed it, but what is the diode for?
Let's see if I can get this right.....
For our purposes here, power going through a diode is dropped by a little less than 1 volt (1 volt for planning purposes). Power through 2 diodes drops a little less than 2 volts (etc.). We're using the diode to limit power from a fully charged battery pack (7+ volts) to that found safe for use with the 6 volt max limits on the ignition modules. Works great in practice, and can't get much simpler.
Hide Signatures
(in reply to acdii)
       Post #: 1226
RE: What Aircraft are you installing your DLE20 - 11/17/2011 7:29 PM
Indiomike
Status: offline
I currently have a DLE20 in a OMP Fusion. Very nice but one day down the road it will no doubt meet its end. In looking for a replacement plane for the DLE20 I came across a Phoenix Model 540 Edge (.90- 1.20 size) at Tower Hobbies. It is a 65" wingspan and AUW of about 9 pounds. I did a search here but there is no information about this specific plane. Does anyone have it and can report the quality of the ARF and how well it flies?
Mike
Hide Signatures
(in reply to ahicks)
       Post #: 1227
RE: What Aircraft are you installing your DLE20 - 11/17/2011 7:54 PM
Glyder
Last Login: 12/5/2012
Status: offline
I have it. Not finished yet but seems to be a nice kit. I have to put the radio gear in and Ill be ready for the maiden.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Indiomike)
       Post #: 1228
RE: What Aircraft are you installing your DLE20 - 11/17/2011 9:20 PM
acdii
Status: offline
quote:
ORIGINAL: ahicks
quote:
ORIGINAL: acdii
Hmm never thought to use a diode to reduce voltage, always used them to filter voltage or rectify AC to DC.  I know a Zener diode has been used for regulating voltage though.  When I played with electronics, I used a voltage regulator to do it, has 3 legs, one as input, one as output and the third to ground to bleed off excess voltage. Of course it had capacitors and diodes too.
I used diodes also to setup wigwag lights to prevent positive voltage from bleeding from one light to the other on a common ground circuit in a car.  Never tried them to reduce voltage though, will have to dig out my box of parts and see the drop for myself. Interesting.
_____________________________
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 1229
RE: What Aircraft are you installing your DLE20 - 11/17/2011 9:25 PM
SpinnerRow
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: acdii
The voltage drop is load dependent but I found it to be about .8 volts on a half amp load.
"Hey!!! That tree was NOT there when I took off!!"
Hide Signatures
(in reply to acdii)
       Post #: 1230
RE: What Aircraft are you installing your DLE20 - 11/17/2011 10:23 PM
Indiomike
Status: offline
quote:
ORIGINAL: Glyder
Glyder. Excellent. Please post your impression of the plane once it has been flown.
Mike
Hide Signatures
(in reply to Glyder)
       Post #: 1231
RE: What Aircraft are you installing your DLE20 - 2/13/2012 1:54 AM
SpinnerRow
Status: offline
I'm building a Texas RC .60 Sized Drastick with an ES Composites tuned pipe.
Hide Signatures
(in reply to zoaartcc)
       Post #: 1232
RE: What Aircraft are you installing your DLE20 - 2/14/2012 1:00 AM
acdii
Status: offline
I found this to be just right, no worries, and no soldering or other mess. badbradgraphics.com/images/regulator_2.jpg   $11, and not voltage dependent.
Hide Signatures
(in reply to SpinnerRow)
       Post #: 1233
RE: What Aircraft are you installing your DLE20 - 3/30/2012 6:51 AM
oldtyme
Last Login: 5/6/2013
Status: offline
Well, I'm getting ready to install a DLE20 in my TF 60 ARF P47, my GP PT17 and my Seagull Zero.................hopefully this will work well, these are my first 3 gasser's.
AMA 16066
Hide Signatures
(in reply to acdii)
       Post #: 1234
RE: What Aircraft are you installing your DLE20 - 3/30/2012 11:29 AM
Lifer
Status: offline
oldtyme,
I have the DLE 20 in my TF P-47 and GP PT-17. Good fit and good power! I used a 17x6 Xoar in the PT, and a Xoar 16x8 in the P-47.
Hide Signatures
(in reply to oldtyme)
       Post #: 1235
RE: What Aircraft are you installing your DLE20 - 3/30/2012 12:03 PM
sandyjain
Last Login: 5/7/2013
Status: offline
I have installed the DLE20 and flown the following models:
Seagull extra 260 60-90, 2 more at our field
Seagull edge 540 60-90 3 more
Seagull MXS-R 90
Phoenix YAK 54 90
Currently building Black Horse PC9 90 with air retracts......
Cheers....
Sandy Jain
Hide Signatures
(in reply to Lifer)
       Post #: 1236
RE: What Aircraft are you installing your DLE20 - 3/30/2012 1:35 PM
abreimeris
Last Login: 3/12/2013
Status: offline
quote:
ORIGINAL: sandyjain
Seagull MXS-R 90
Phoenix YAK 54 90
How do you like the Seagull MXS-R 90?
I have the Edge 540, and love it!
Anthony
Hide Signatures
(in reply to sandyjain)
       Post #: 1237
RE: What Aircraft are you installing your DLE20 - 3/30/2012 7:23 PM
sandyjain
Status: offline
I actually built it for a friend. Mine is still in the box.
Had 2 flights tho....
Looks great, great cockpit, tad heavy, easy to fly....
The extra260 or the Edge 540 are better for 3D.
Cheers....
Sandy Jain
Hide Signatures
(in reply to abreimeris)
       Post #: 1238
RE: What Aircraft are you installing your DLE20 - 3/30/2012 8:18 PM
oldtyme
Status: offline
quote:
ORIGINAL: Lifer
oldtyme,
Hi Lifer............I'm wondering..........I'm using the Dubro Vibration mount in the PT17 and I'm having to hog out a bit of the triangle stock on the firewall for it to fit........did you do that or just use the stock mount. I made a drill template based on the Tower instruction manual and am going to drill and mount the mount today.
Andy
AMA 16066
Hide Signatures
(in reply to Lifer)
       Post #: 1239
RE: What Aircraft are you installing your DLE20 - 3/30/2012 10:43 PM
Lifer
Status: offline
Oldtyme,
I really like the H-9 metal mounts. I used those and added spacers to project the thrust washer to where it needs to be. I would like to discourage the use of the soft or vibration dampening mounts. I believe that it is best to hard-mount these engines. Just my 2 cents.
Hide Signatures
       Post #: 1240
RE: What Aircraft are you installing your DLE20 - 3/31/2012 2:10 AM
oldtyme
Status: offline
Do you have a picture of your installation? If so could you guide me to it?
Andy
AMA 16066
Hide Signatures
(in reply to Lifer)
       Post #: 1241
RE: What Aircraft are you installing your DLE20 - 3/31/2012 2:19 AM
w8ye
Status: offline
The H9 metal mounts
http://www.horizonhobby.com/products/metal-engine-mount-p-51d-blue-nose-60-HAN242024
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 1242
RE: What Aircraft are you installing your DLE20 - 3/31/2012 2:31 AM
ghoffman
Status: offline
After over 300 flights on my 2 DLE-20's, I now have the first Mintor 22cc in the US.  My friend Matt and I are building the ultimate 68 inch Velox. We found a NIB yellow Velox from CA. Matt has contributed the Hitec 5565 ultra fast HV servos on the wings and elevators, and a 7954 on the rudder with Azhars's cool Secraft CNC servo arms. We are using CF/Ti pushrods, 10 oz Fiji bottle tank, Tech Aero IBEC, JR922 DMSX receiver, with dual 1300 mah 20C Sky-Lipos for power, Nachos cheese graphics. The Mintor 22 hopefully swing a 18 inch Vess. This will be the ultimate cool Velox, best of everything.  It will be very interesting to see how it performs compared the trusty DLE-20.
Hide Signatures
(in reply to w8ye)
       Post #: 1243
RE: What Aircraft are you installing your DLE20 - 3/31/2012 1:00 PM
Lifer
Status: offline
No pictures at this time and all the planes are buttoned up. If I need to remove the cowls, I'll take pictures at that time. Given the fact that the DLE's are purpose-designed model engines, they really don't have a different appearance than a glow engine.
Hide Signatures
(in reply to ghoffman)
       Post #: 1244
RE: What Aircraft are you installing your DLE20 - 3/31/2012 1:08 PM
ghoffman
Status: offline
Hide Signatures
(in reply to Lifer)
       Post #: 1245
RE: What Aircraft are you installing your DLE20 - 4/1/2012 3:07 AM
unclecrash
Last Login: 5/13/2013
Status: online
Here is where my dle 20 is a. In my cmp butcherbird. I did a 5minute spray bomb paint job. I hide the on off switches under the panel on the side. The cowl has 4 pegs on the ring that index it to the fuse and 2 rare earth magnets hold it from going anywhere. One more pic of the magnet and index holes that the cowl goes into.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
I Ain''''''''t Buildin No TuG Boats
Hide Signatures
       Post #: 1246
RE: What Aircraft are you installing your DLE20 - 4/1/2012 5:07 AM
unclecrash
Status: online
Here are a few more pics. I wish they would have slanted the plug back. It seems like it would have helped getting the cowl to hide on some of the birds like the P51 where the cowl curves up on the botrtom. Mine is sticking out, just the plug cap maybe 1/2 inch tops.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to unclecrash)
       Post #: 1247
RE: What Aircraft are you installing your DLE20 - 4/1/2012 8:47 AM
oldtyme
Status: offline
I know this was covered briefly in earlier posts.......way earlier.........but I'm an old guy trying to learn new tricks. When you rotate the carb 180 do you or should you rotate the reed block as well or just the carb??
Thanks for humoring an old fart.......
Andy
AMA 16066
Hide Signatures
       Post #: 1248
RE: What Aircraft are you installing your DLE20 - 4/1/2012 1:48 PM
mjohnst3
Last Login: 5/15/2013
Status: offline
Hey Andy,
you only rotate the carb, the reed block orientation is specific to the crank case in how it draws in the air fuel mixture. At least that is how I understand it.
Hide Signatures
       Post #: 1249
RE: What Aircraft are you installing your DLE20 - 4/1/2012 2:00 PM
w8ye
Status: offline
The reed block is the same on one side as the other. It would make no difference.
Original AMA #31261
Hide Signatures
(in reply to mjohnst3)
       Post #: 1250
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
