RE: What Aircraft are you installing your DLE20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: What Aircraft are you installing your DLE20 - 12/16/2010 2:10 AM
K 5054
Score: 100
Last Login: 12/21/2012
Status: offline
I am installing it in a ESM Spitfire
Hide Signatures
(in reply to a1pcfixer)
       Post #: 26
RE: What Aircraft are you installing your DLE20 - 12/16/2010 2:42 AM
scooterinvegas
Score: 141
Last Login: 7/7/2012
Status: offline
quote:
ORIGINAL: ghoffman
I have my first one in an Ultra Stick 60, and it has spectacular performance.
Any pictures of your install? Did you cut the firewall?
I have a G-26 on a US lite, and the firewall had to be cut. I have 2 US 60's, one has a 95AX and the other is NIB. Was thinking about a DLE-20 on the US 60, Im loving the gas motors I have.
_____________________________
Maybe I should just take rubbing alcohol with me to the field and rub the props down before starting any of my planes!
Hide Signatures
(in reply to ghoffman)
       Post #: 27
RE: What Aircraft are you installing your DLE20 - 12/16/2010 2:57 AM
wesaysoracing
Score: 100
Last Login: 4/11/2013
Status: offline
my DLE 20 was put on a jerrys bigboy, took a saito 150 off of it
It''s too bad that stupidity isn''t painful.
Hide Signatures
(in reply to scooterinvegas)
       Post #: 28
RE: What Aircraft are you installing your DLE20 - 12/16/2010 3:03 AM
daisy shoot
Score: 105
Last Login: 5/13/2013
Status: offline
Sbach 65" profile from "the balsa store". Awsome awesome awesome plane!!! The second dle 20 will most likely go in another sbach 65!!!!!! My buddy is slapping one in a Decathalon, should be a blast if he ever gets it done
Hide Signatures
       Post #: 29
RE: What Aircraft are you installing your DLE20 - 12/16/2010 3:17 AM
ghoffman
Score: 163
Last Login: 5/24/2013
Status: offline
No, it was easy. I will post a few new pics tomorrow.  I have about 30 flights on it.  It is the highest performance Stick in our club by far.
Hide Signatures
       Post #: 30
RE: What Aircraft are you installing your DLE20 - 12/16/2010 3:28 AM
joebob
Score: 100
Status: offline
quote:
ORIGINAL: daisy shoot
Sbach 65'' profile from ''the balsa store''. Awsome awesome awesome plane!!! The second dle 20 will most likely go in another sbach 65!!!!!! My buddy is slapping one in a Decathalon, should be a blast if he ever gets it done
Me too! You got it flying yet? Mine's ready to go, just waiting on the weather to cooperate.
Click to see fullsize image.
Click for fullsize
Joe Andrews
Hide Signatures
(in reply to daisy shoot)
       Post #: 31
RE: What Aircraft are you installing your DLE20 - 12/16/2010 3:46 AM
tony0707
Score: 115
Last Login: 5/23/2013
Status: offline
HI
IF your 60 size stik performs that well-a lot of people will be paying a lot of good attention to what you are up tomaking an IKON
in this hobby perform better than before sure works for methats what we are hear to do-this process keeps all things that fly and improve -even more FUN than before to be good at this hobby all one must do is copy that which he see's working real well at the flying field( or waking at night with a brain storm ! ) i have a lot of planes and fly for 20 years more than most-just so happens my MIDWEST 60 SUPER STIK is the plane i have loged the most RC hours on the plane will fly in any conditions and handle them well or a go to to relax
a good performing SMALL gas engine could very well change the way we look at our RC powerplants in the futureBRAVO
MERRY CHRISTMAS REGARDS TONY
" The power and performance glo fuel , 15 % Morgan Omega "
Hide Signatures
       Post #: 32
RE: What Aircraft are you installing your DLE20 - 12/16/2010 1:37 PM
littlera
Score: 133
Status: offline
I am considering putting one in a 1/3 scale Druine Turbulent I am going to build from a vintage Precedent (UK) kit. I scored this kit from another RCU member after seeing a 6 year old post by him regarding the kit. I believe it has an 87" span, and will probably weigh in the 10 lb. range. Should be a relaxing floater! I would prefer possibly an OS 160 twin, but in recent years these have gotten unreasonably expensive with the high value of the Yen vs. the USD.
Precedent made nice kits. I built their 1/4 Aeronca Champ. Too bad their new parent company took all their wood kits off the market after buying the company about 10 years ago.
littlera
AMA #386
Hide Signatures
(in reply to tony0707)
       Post #: 33
RE: What Aircraft are you installing your DLE20 - 12/16/2010 2:15 PM
ghoffman
Score: 163
Status: offline
Here are some pics of the DLE-20 on the UStick 60. The ignition box is in the nose where the fuel tank used to be.  Since it gets such good gas mileage, the smaller tank is good for about 15-20 minutes and since it is at the C/G it does not change as it drains.  The small circuit board near the tank is the Syssa IBEC and I have it in the "gear" port on the JR921Rx that is under the Life battery. This way, I have an easy on/off switch on the Tx, with a small LED on the right side that indicates if the ignition is hot, and it regulates the voltage into the ignition to 5.6v.  As you can see, the rudder and elevator servos are rear mounted and the C/G is perfect this way.  The all up weight is 7 pounds. 14 oz.
< Message edited by ghoffman -- 12/16/2010 2:38 PM >
Hide Signatures
       Post #: 34
RE: What Aircraft are you installing your DLE20 - 12/16/2010 2:24 PM
w8ye
Score: 318
Status: offline
Looks good.  That's my kind of plane.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 35
RE: What Aircraft are you installing your DLE20 - 12/16/2010 2:51 PM
ghoffman
Score: 163
Status: offline
Thanks, it is fun and is no hassle to take it out.  All I do I make sure it is charged up (the 1800mah LiFe will last all day and then some, it is overkill), and put gas in it and go.  Turn it on, flip the prop and we are flying.  No oil on the bottom, and 3 flights cost about a quarter.  Other planes handle better and will do things that this Stick could never do, but it hovers at 1/2 throttle, takes off in (seriously) 5 feet and accelerates vertically better than my electric AJSlick.  It is also the fastest plane I have, I need a radar, but it must be doing 90 MPH anyway in a straight line, even with the 17-6.  Any more speed than this will probably make it flutter or rip the wings off.  The guys at the club say things like "Wow Gary, do you think you have enough motor on that thing"?
Hide Signatures
(in reply to w8ye)
       Post #: 36
RE: What Aircraft are you installing your DLE20 - 12/16/2010 7:07 PM
picard1
Score: 100
Status: offline
I am building a GP Extra 300 for mine. If it runs as good as everyone says, I am thinking of a TF B-25 with Two DLE-20
Mike
Hide Signatures
       Post #: 37
RE: What Aircraft are you installing your DLE20 - 12/16/2010 7:41 PM
zoaartcc
Score: 100
Last Login: 6/23/2012
Status: offline
quote:
ORIGINAL: picard1
Mike
I can not wait to see that B-25 in the air. Can already hear those twin 20's screaming over the runway.
My extra 300 will be on hold until after the X-mas Holiday. My work area will be used for family dinners.
Dan
Dr. Dan, M.D.
M.aster of D.isaster
Hide Signatures
(in reply to picard1)
       Post #: 38
RE: What Aircraft are you installing your DLE20 - 12/16/2010 9:01 PM
tonyob
Score: 110
Last Login: 12/30/2012
Status: offline
That looks a good setup. I've got a Great Planes Big Stik 60 I'm about to maiden (no dle20 sorry), Any comparison between the GP stik and the Ustick? Have been thinking a DLE20 could be good for my next 60 size stik.
Hide Signatures
(in reply to zoaartcc)
       Post #: 39
RE: What Aircraft are you installing your DLE20 - 12/16/2010 10:20 PM
cloudancer03
Score: 122
Last Login: 5/14/2013
Status: offline
great thread.would love to see some video of the DLE20 at work! I had a ultrastick but they stopped making the arf.I would love to install the DLE20 in a warbird ..my dle30 is in my seagullextra 260 180.God its great to have gassers in our everyday planes without having to go giant ..not that is bad either but I dont plan to fly any glow next year other than my satios.I would love to see how the 20 works in the 68 3dh velox!! that might be my next plane although extreme flight is releasing a 60 inch extra soon..
Hide Signatures
(in reply to tonyob)
       Post #: 40
RE: What Aircraft are you installing your DLE20 - 12/16/2010 11:27 PM
5150flyer
Score: 100
Status: offline
I am waiting for a reasonably quiet muffler to hang on a DLE20. The stock setup is just too loud for my ears and my field.
The bitterness of poor quality lingers long after the sweetness of low price is forgotten.
Hide Signatures
(in reply to cloudancer03)
       Post #: 41
RE: What Aircraft are you installing your DLE20 - 12/16/2010 11:39 PM
codimasta
Score: 100
Status: offline
Installed my DLE 20 on a PT-17 ..Works just fine..plenty of power.
Using 17 X 8 prop..123 Battery with Limiting Diodes (3) for the Ignition system.
It is the Great Planes PT-17 Recovered.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by codimasta -- 12/17/2010 6:15 AM >
Hide Signatures
       Post #: 42
RE: What Aircraft are you installing your DLE20 - 12/17/2010 1:45 AM
tail heavy
Score: 105
Status: offline
Which PT-17? I may be interested in a similar setup.
AL
"No mans life, liberty, or property are safe while the Congress is in session." - Mark Twain
Hide Signatures
(in reply to codimasta)
       Post #: 43
RE: What Aircraft are you installing your DLE20 - 12/17/2010 3:01 AM
ghoffman
Score: 163
Status: offline
The UStiick does not have any dihedral and flys just as well inverted.   It has the split flaps and the control surface area is greater.  While by no means a 3D plane, it it still a very high performance aircraft.  It is easy to fly in all but stupid wind and if you cant land this, you should take up R/C cars.  I still have fun flying this even with the other "better" planes I have.
< Message edited by ghoffman -- 12/17/2010 3:24 AM >
Hide Signatures
       Post #: 44
RE: What Aircraft are you installing your DLE20 - 12/17/2010 3:11 AM
seagull extra
Score: 100
Status: offline
I have a NIB Showtime 90 and Sig Mayhem. I have a YS 110 and I have a DL 20 on order. I will probably go with the YS 110 with the showtime and Hitec 985 servos and put the DL 20 in the Mayhem with Hitec 5625 servos.
Hide Signatures
       Post #: 45
RE: What Aircraft are you installing your DLE20 - 12/17/2010 5:47 AM
alex_scratch_built
Score: 100
Last Login: 4/30/2013
Status: offline
The P-51D Blue Nose 60 ARF by Hangar 9
should be a perfect match for this baby!!!
Hide Signatures
(in reply to seagull extra)
       Post #: 46
RE: What Aircraft are you installing your DLE20 - 12/17/2010 2:04 PM
tail heavy
Score: 105
Status: offline
codimasta... Nice install job! That is a good looking Bipe. Does she fly scale or is there power to burn??
AL
Hide Signatures
(in reply to alex_scratch_built)
       Post #: 47
RE: What Aircraft are you installing your DLE20 - 12/17/2010 2:57 PM
ml3456
Score: 100
Last Login: 4/20/2013
Status: offline
Going to start with a GP Skybolt kit I have. Was originally going to use a YS, but they are too finicky and glow Fuel is $$$. I also have a CG Ultimate kit that I might go DLE also instead of the ST 90K that I have.
ML
Hide Signatures
(in reply to tail heavy)
       Post #: 48
RE: What Aircraft are you installing your DLE20 - 12/17/2010 4:15 PM
microdon2
Score: 110
Status: offline
Have my DLE 20 installed on a 70" Great Planes Revolver - about 9lbs. Have only two days of flying in it so far, but it looks VERY powerful! Am using an APC 16x7. Still some carb fine-tuning to do, but I think this plane will be a rocket. The DLE looks to have power similar to my other one Revolver with a YS 140.
Hide Signatures
       Post #: 49
RE: What Aircraft are you installing your DLE20 - 12/17/2010 4:18 PM
microdon2
Score: 110
Status: offline
btw - codimasta - your PT-17 is gorgeous! What's the wingspan?
Hide Signatures
(in reply to microdon2)
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: What Aircraft are you installing your DLE20
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
