Sport_Pilot
GA, USA Status: offline
[QUOTE]Originally posted by JWN As the methanol evaporates, the empty space in the jug is replaced by air. In high humidity areas, this means water is coming into contact with the methanol left in the jug. If evaporating the empty space is replaced by more methanol evaporating behind in, it would take some airflow across the jug to get air in it. In my case it was during the summer in a hot covered storage shed the fuel was in a 5 gallon plastic can similar to a 5 gallon bulk paint can, the heat made the pressure build and popped the top. However if during the course of a year there is likely to be some temperatures below its flash point where the vapor would contract pulling in a small amount of air. Even so this would be a small amount of air. Even a whole gallon of air would not contain to sufficiently contaminate the fuel. Air would have to be exchange on a continuous basis, but, it would not take much airflow to accomplish this. If you've found something that works for you, great. But, having tried to run a couple of gallons of fuel in the past that had been left open, I'm not willing to try adding anything else to it. It's easier and less frustrating for me to simply replace the entire jug. I'm not saying it's not contaminated (well actually all our fuel is, just not enough), it very likely is. But, unless the water is causing the oil to separate out, it won't hurt to run it up on the ground. I've had little problems with grass, but regular old weeds keel over in about 4 days after a little glow fuel drink You have a point, I have some Bermuda that keeps overgrowing and spreading into the landscaped areas. For some reason it takes two or three times the roundup to get rid of it. John [/QUOTE]
