RE: GP Waco?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: GP Waco?
Page: <<   < prev  39 40 41 42 43 [44] 45 46 47 48   next >   >>
Login
RE: GP Waco? - 11/5/2012 9:19 PM
wore-out-pilot
Score: 100
Last Login: 12/20/2012
Status: offline
At that price I got one two
Hide Signatures
(in reply to kochj)
       Post #: 1076
RE: GP Waco? - 11/6/2012 2:44 AM
Sandyt
Score: 100
Last Login: 6/19/2013
Status: offline
Kochj
I am using the older OS 1.20 Gemini twin, which IIRC is exactly the same size as the 1.60. I had a friend make me some aluminum stand-offs and the engine bolted up perfectly. I put more effort into the fuel tank, which is way too high in the stock location, considering that these engines do not use muffler pressure and the carb is under the cylinders. I cut the inside of the fuse until a Sullivan 24 oz. tank would fit as low as possible. I still had issues with the mixture changing too much during the flight until I realized I didn't need that much fuel anyway. Now I fill the tank and then pump out fuel for 5 seconds and however much fuel is left in the tank is plenty for a 12 minute flight. YMMV literally
In any case, the only cuts to the cowl are for the needle valve and air-bleed screw (I have on-board glow), and a small square section at the bottom where the two exhaust pipe extensions exit. The sound of the twin is amazing!
SandyT
Hide Signatures
(in reply to kochj)
       Post #: 1077
RE: GP Waco? - 11/6/2012 4:37 AM
kochj
Score: 143
Last Login: 6/15/2013
Status: offline
Thank you for the comments...Sandy
I had the same issues with my Chipmunk and the twin's carb ( it is the older airbleed style) and the tank located too high...
I have had many thoughts on converting it to gasoline w/walbro carb...but Idealy it should have 1-carb per cyl... so 2 carbs total...
Would be a tight fit.. or very clever placement...
The Twin is already spark ignition... from the original C&H ignition.
I had also thought about doing a perry pump, and rout the oil outlet through a catch container prior to going through the perry pump...
I would have to open the catch can and drain it occasionally...
Perhaps one could use a I-V style bag for fuel tank??? This would keep the fuel low, and never change position in relation to the carb-fuel tank line...
I have thought about that from time to time.. but fuel draw may be a issue... due to no clunk??? I guess I should post that q in a dif. forum post!...
_____________________________
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
(in reply to Sandyt)
       Post #: 1078
RE: GP Waco? - 11/6/2012 10:23 AM
patniven
Score: 100
Status: offline
Tower just  changed the price back to $499.  Did I get lucky, or did someone get fired this weekend at Tower?  Or both?
Apache Pilot: Because fighter pilots need heroes, too...
Hide Signatures
(in reply to kochj)
       Post #: 1079
RE: GP Waco? - 11/6/2012 5:48 PM
kochj
Score: 143
Status: offline
I felt I should have purchased the p-40 when it was 400$ but you have to purchase retracts ect.... and that would have been another 600$ to the price...
At least this plane doesn't require any additions to it's price....
I just hope I don't run into issues with the twin setup...(gas tank possition that is..)
Cheers...
Hide Signatures
(in reply to patniven)
       Post #: 1080
RE: GP Waco? - 11/6/2012 6:55 PM
Dick T.
Score: 136
Status: offline
quote:
ORIGINAL: patniven
I often wonder if this isn't a sneak 24 hour sale. A friend landed a giant TF Corsair a month ago for less than half the current price. When he telephoned me about it the web site had the reduced price but the next morning it was back to current.
I have seen other big, limited time price reductions on Tower's site. Pays to browse it daily.
Dick Tristao
ModelGrafix
Hide Signatures
       Post #: 1081
RE: GP Waco? - 11/7/2012 4:47 AM
nitro wing
Score: 125
Status: offline
I would have grabbed it for sure, but RC funds and time are low right now, maybe next time
Hide Signatures
(in reply to Dick T.)
       Post #: 1082
RE: GP Waco? - 11/8/2012 5:18 AM
Mpizpilot
Score: 100
Last Login: 6/17/2013
Status: offline
I've already got one flying and was looking for spares when I noticed the reduced price. Just snagged another one for $270 using my discount!!
Hide Signatures
(in reply to nitro wing)
       Post #: 1083
RE: GP Waco? - 11/8/2012 2:31 PM
raptureboy
Score: 183
Status: offline
It would be nice if they would give the club members a quick email saying like "one day sale" or something. I think it was a complete error on the webmasters part, because they seem to be always playing with the pricing right now. I mean a $180 drop in price from Tower?  I'm sure that business is slow these days.
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 1084
RE: GP Waco? - 11/8/2012 2:43 PM
Lifer
Score: 153
Status: offline
I believe it is doing exactly what Tower has in mind: They want us looking over their website on a frequent basis. I am certain the same thing is going on in the car, and boat sections of their website as well.
Hide Signatures
(in reply to raptureboy)
       Post #: 1085
RE: GP Waco? - 11/8/2012 2:57 PM
kochj
Score: 143
Status: offline
Has anyone modded the wing so you can leave the center attached?
Would the metal supports be enough or would you need to do more?
Hide Signatures
       Post #: 1086
RE: GP Waco? - 11/8/2012 6:44 PM
welder101
Score: 100
Status: offline
 The price was because it was in there daily sale items. I was watching it go done in price for about a week. They will put stuff in there if they have an overstock.
Hide Signatures
(in reply to kochj)
       Post #: 1087
RE: GP Waco? - 11/8/2012 9:21 PM
cannonball200
Score: 105
Status: offline
Here is a full scale Waco YMF-5 that can be bought cheap! Two guy's in it, no injuries! Longville, Minnasota in 1997>> A bad crosswind landing...bounced, weather vaned, hit a ditch off the runway nose first & flipped on its back.
Click to see fullsize image.
Click for fullsize
< Message edited by cannonball200 -- 11/9/2012 12:54 AM >
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
(in reply to welder101)
       Post #: 1088
RE: GP Waco? - 11/8/2012 11:52 PM
Chillybee
Score: 100
Status: offline
Ouch! I hope no one was hurt!
Hide Signatures
(in reply to cannonball200)
       Post #: 1089
RE: GP Waco? - 11/9/2012 7:13 AM
kochj
Score: 143
Status: offline
I guess I can't complain then....
I recieved my plane today.... It had 2 gaping holes all the way through both boxes and looks like a elephants wrinkled trunk on both ends!
I guess that means it was crushed...
Some minor damage to the balsa covering and the belly pan....
The main surprise was the amount of wrinkles....
My others planes of recent didn't have any....
The other thing, is the monokote seems to be a bad run....
The color goes to a lighter shade when heated...and stays tha way....
Kind of a Tie dye effect....
With monokote, you have to put in on right the 1st time, or it is a mess....
It could be the shrinking effect of wood but I am not going to agree with that...
I have been dealing with monokote for a long time, and can apply it right, even though, it was changed somewhat....
Monokote typically will not discolor unless it is heated soo high, that the paint boils and you get mottled.... NOT color change...
It is almost as Acetone or trim solvent, and leaches it .....
I will call up Tower tommorow.....
I just got done defending Monokote/ Topflite, and now this happens...
Hide Signatures
(in reply to Chillybee)
       Post #: 1090
RE: GP Waco? - 11/9/2012 11:21 AM
Lifer
Score: 153
Status: offline
My PT-17 had the same issue with the yellow Monokote. Most of the discoloration was on the bottom wing so I ignored it. The plane is a year old, so the QC issue must go back quite a ways.
Hide Signatures
(in reply to kochj)
       Post #: 1091
RE: GP Waco? - 11/9/2012 1:53 PM
wore-out-pilot
Score: 100
Status: offline
kochj i wonder if they sent you the one that was on scratch and dent list. The only thing was the covering had lots of wrinkles. I received mine and it looks ok I will have to go over it to get some small wrinkles out.
Hide Signatures
(in reply to Lifer)
       Post #: 1092
RE: GP Waco? - 11/9/2012 6:05 PM
raptureboy
Score: 183
Status: offline
Ditto on the color issue., I have both a roll of cub yellow and the Pt-17 and the colors don't match and when you add heat it changes color and stays that way. My top wing color is different than the bottom wing. I saw the Waco on the scratch and dent sale and it's gone now, hope they didn't send that one. It was listed for 350 when the new ones were 319.00 I am going to recover mine sometime in Solertex, what a superior product next to monocrap.
Hide Signatures
(in reply to Lifer)
       Post #: 1093
RE: GP Waco? - 11/11/2012 11:14 PM
kochj
Score: 143
Status: offline
Tower is talking care of it....
Sending out another.....
As far as the covering is concerned.....I don't know if I suddenly have figured out Monocoat, but I was able to take out the wrinkles....
The trick was to Push down the the sheeted areas with the Iron on hot, but not hot enough to discolor...
I used the iron as a squeegee and pushed the wrinkles to the edge, and had great results..
I used a heat gun for the open areas.....It shrunk up very nicely in those areas.....
Hide Signatures
       Post #: 1094
RE: GP Waco? - 11/12/2012 7:55 PM
raptureboy
Score: 183
Status: offline
I've had similar success using the trim iron and poking tiny holes with the tip of a new #11 blade over the solid areas.
Hide Signatures
(in reply to kochj)
       Post #: 1095
RE: GP Waco? - 11/12/2012 8:50 PM
wore-out-pilot
Score: 100
Status: offline
Kochj, Glad you are getting taken care of, I think tower is great to deal with, they are first class.
Hide Signatures
       Post #: 1096
RE: GP Waco? - 11/17/2012 4:50 AM
kochj
Score: 143
Status: offline
Tower sent out another...recieved it yesturday...
UPS picked up the damaged one....
Couldn't believe it..... There was a HOLE in the EXACT same place as the previous box!.... WTH???
UPS BITES.... Big time...
I was lucky in that it got the other end of the box this time....
Did I mention, that the hole went through BOTH BOXES? The inner and outer box....
No damage on inside this one though....
I understand why Extreme flight doesn't use UPS... they use a dif. carrier...
THe only downside is....
I paid NO SHIPPING for the same size box as my 78" extra from extreme flight....
I paid 100$ from Extreme flight ....for shipping....
In the future If I buy from EF again... I would try to buy from a local Hobby store... but
NONE of them ever order from EF....
The covering is less wrinkled, but the spots over the solid wood, is wrinkled skin look....
Not sure if I can get those out....
I must that I I may strip this out when the covering is shot....and fabric it....
I may make my wings removable so the center wing stays on the plane....
The bottome wing may be more challenging, being the top wing is already in 3 parts....
I considered a 5cyl saito on this plane, but it would require some work on the cowl...
I have no doubt that it could take the extra weight, and still fly great....
This is a 1400+ sqauare area plane....
That would be considered great for a 50cc 3d plane...
I would have to make some bigger Spoons on the sides of the cowl
This cowl fits inside of the Top Flite staggerwings cowl... and the 325 radial just fits inside that
cowl....
Hide Signatures
(in reply to wore-out-pilot)
       Post #: 1097
RE: GP Waco? - 11/17/2012 7:24 PM
flyntruk
Score: 105
Last Login: 4/1/2013
Status: offline
Hey Kochi ... UPS uses box hooks at this time of year ... One solution is to order through your LHS ..
spitfire brotherhood #47 West Coast Squadron
Hide Signatures
(in reply to kochj)
       Post #: 1098
RE: GP Waco? - 11/25/2012 4:02 AM
kochj
Score: 143
Status: offline
quote:
ORIGINAL: flyntruk
No one is local!...
All hobby shops are about to go into foreclosure.....wait, it isn't just hobby shops...it is ALL shops.....
The economy is a fish tank that has lost power to the heater, and filter, and bubbler....more fish will continue to be flushed down the toilet, as they start to die off.
We will all look back 5-10 years from now, and say ...WOW those crappy years turned out to be the GOOD YEARS....
Because it just continued to go bad from there and never recovered....
Hide Signatures
(in reply to flyntruk)
       Post #: 1099
RE: GP Waco? - 11/25/2012 5:06 PM
kochj
Score: 143
Status: offline
Looks like the P-6e hawk is sold out now....
I have to get mine up in the air, before parts are scarce again...
Hide Signatures
(in reply to kochj)
       Post #: 1100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
