Ulmer 049 wonder plans?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Ulmer 049 wonder plans?
Page: [1]
Login
Ulmer 049 wonder plans? - 12/24/2010 12:31 PM
franklin_m
Score: 103
Last Login: 5/11/2013
Status: offline
A while back a gent by the name of PT Ulmer (?sp) had a website where he had downloadable plans for several 1/2A planes. These included what I remember being a 049 Sig Wonder type plane. Does anyone have the files they could send me?
Frank
_____________________________
" If at first you don''t succeed....then carrier landings are not for you! " ........FLY NAVY
Hide Signatures
       Post #: 1
RE: Ulmer 049 wonder plans? - 12/24/2010 4:03 PM
Andrew
Score: 105
Last Login: 5/23/2013
Status: offline
I think it was the Das Wunder. Right-click the pdf attachment and choose "save target as" to save the file to your machine.
andrew
Click to see fullsize image.
Click for fullsize
Click to see the file in new window.Attachment.txt Click to see the file in new window.Attachment.pdf
the "other" andrew
I'm not older than dirt, but I can remember when it was patent pending
Hide Signatures
(in reply to franklin_m)
       Post #: 2
RE: Ulmer 049 wonder plans? - 12/24/2010 7:37 PM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to Andrew)
       Post #: 3
RE: Ulmer 049 wonder plans? - 12/25/2010 1:25 AM
franklin_m
Score: 103
Status: offline
quote:
ORIGINAL: Andrew
I think it was the Das Wunder. Right-click the pdf attachment and choose ''save target as'' to save the file to your machine.
andrew
Andrew
Thanks so very much. That's exactly the one I wanted to find!
Frank
Hide Signatures
       Post #: 4
RE: Ulmer 049 wonder plans? - 1/19/2011 6:25 PM
dieFluggeister
Score: 102
Last Login: 9/11/2012
Status: offline
Here are a couple shots of the Wunder that I built along side of Patrick Ulmer's legendary DNU.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: Ulmer 049 wonder plans? - 2/1/2011 11:27 PM
franklin_m
Score: 103
Status: offline
die flug...
Nice looking planes....
Hide Signatures
(in reply to dieFluggeister)
       Post #: 6
RE: Ulmer 049 wonder plans? - 2/4/2011 1:57 AM
flyinrog
Score: 109
Status: offline
I ran off a copy myself , should be a blast!...Rog
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
Hide Signatures
       Post #: 7
RE: Ulmer 049 wonder plans? - 3/21/2011 10:28 AM
simonta
Score: 100
Last Login: 7/9/2011
Status: offline
Hi there
Speaking of Pat Ulmer's 049 wonder plans.... does anyone have his Blink delta plans (for an .049 engine)? Patrick's site seems to be down.
All the best
Simon
Hide Signatures
(in reply to flyinrog)
       Post #: 8
RE: Ulmer 049 wonder plans? - 3/21/2011 1:35 PM
Andrew
Score: 105
Status: offline
Simon -
Here you go...........
andrew
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
< Message edited by Andrew -- 3/21/2011 6:36 PM >
the "other" andrew
Hide Signatures
(in reply to simonta)
       Post #: 9
RE: Ulmer 049 wonder plans? - 3/25/2011 4:05 PM
simonta
Score: 100
Status: offline
quote:
ORIGINAL: Andrew
Simon -
andrew
Brilliant.... Thanks Andrew!.... Incidentally, do you know of an good build logs etc?
@B
Simon
Hide Signatures
       Post #: 10
RE: Ulmer 049 wonder plans? - 3/26/2011 12:09 AM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: simonta
This is, I believe, the original thread with plan development: http://www.rcuniverse.com/forum/m_3511490/anchors_3511490/mpage_1/key_blink/anchor/tm.htm#3511490
andrew
the "other" andrew
Hide Signatures
       Post #: 11
RE: Ulmer 049 wonder plans? - 3/31/2011 12:44 AM
ptulmer
Score: 100
Last Login: 6/19/2011
Status: offline
http://dnu.ulmercom.com/
Sorry I haven't been around guys, but life happens. I can't say the files I've got up are the most recent versions, but they looked to be. Gotta go through a lot of files one day and get it straightened out.
dF, Legendary? I needed that today.
Coming soon to a grass field near you...
Hide Signatures
       Post #: 12
RE: Ulmer 049 wonder plans? - 3/31/2011 2:23 PM
franklin_m
Score: 103
Status: offline
No worries. Pat, there used to be another on your website, a sort of sheet wing racer as I recall. Do you still have the files for that too?
Frank
Hide Signatures
(in reply to ptulmer)
       Post #: 13
RE: Ulmer 049 wonder plans? - 4/2/2011 2:07 AM
ptulmer
Score: 100
Status: offline
Frank, it's around here somewhere. But you can experiment easily by making a fuse just big enough to bolt the engine on and a wing with 110-120 sq in! As soon as I find it, I'll add it though.
Hide Signatures
       Post #: 14
RE: Ulmer 049 wonder plans? - 4/2/2011 4:47 PM
dieFluggeister
Score: 102
Status: offline
What was it called Patrick?
Hide Signatures
       Post #: 15
RE: Ulmer 049 wonder plans? - 4/2/2011 4:56 PM
franklin_m
Score: 103
Status: offline
That would be awesome Patrick. Got laid off about a month ago, so I'm trying to spend more time flying stuff that's a little easier on the fuel wallet!
Hide Signatures
       Post #: 16
RE: Ulmer 049 wonder plans? - 4/2/2011 6:55 PM
Andrew
Score: 105
Status: offline
quote:
ORIGINAL: dieFluggeister
I think I found it: Killer Buzz
I have most of Patrick's plans that he posted on his site - just couldn't remember what it was called.
andrew
the "other" andrew
Hide Signatures
       Post #: 17
RE: Ulmer 049 wonder plans? - 4/2/2011 6:58 PM
dieFluggeister
Score: 102
Status: offline
I was wondering if that was the one. Always been on my 'to build' list!
Hide Signatures
       Post #: 18
RE: Ulmer 049 wonder plans? - 4/2/2011 8:53 PM
ptulmer
Score: 100
Status: offline
Yeah, I had a six pack of Warsteiner that night.
Hide Signatures
       Post #: 19
RE: Ulmer 049 wonder plans? - 4/2/2011 9:03 PM
ptulmer
Score: 100
Status: offline
August 27th was my last day on the job after 14 years. It sucks!
Do a search on SWR's or sheet wing racers. Man, those are FUN! Combatpigg did a lot of different ones with some off-the-chain bearing engines. At 110 square inches the AUW must be less than 8.5oz or they come in like augers. Vertical stab is 15% of the wing area and horizontal stab is 20%. Both numbers can be reduced a bit, depending on the planform. That's all from memory and not reliable.
Hide Signatures
       Post #: 20
RE: Ulmer 049 wonder plans? - 4/3/2011 12:46 PM
franklin_m
Score: 103
Status: offline
Patrick,
Sorry to hear of your situation. I think there's more of that going around than folks admit. Thanks so much for the killer buzz info. It looks fun!
Frank
Hide Signatures
       Post #: 21
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
