Invert's Fiberglassing Technique 101    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Invert's Fiberglassing Technique 101
Page: [1] 2 3 4   next >   >>
Tower Hobbies Today's Special Offer! Brands Products
Login
Invert's Fiberglassing Technique 101 - 12/29/2010 1:38 AM
invertmast
Score: 153
Last Login: 5/21/2012
Status: offline
I know most of us REALLY hate when we get to the fiber-glassing part of building our models. Its time consuming, dust, itchy (if not wearing long sleeved clothing) and down right a pain in the butt! Through the years i've tried everything from sanding sealer and water base polyurethane, oil-base polyurethane, Z-poxy, etc and all have their pro's and con's.
In this thread, Its my intentions to show how I go about fiber-glassing my models. I have eliminated a vast majority of the sanding, and your typical 1/5th scale model can be ready to paint in 1 to 3 days once you get use to the technique. So, lets get to work.
First thing up is the materials you will need.
1. A quality epoxy laminate resin system. This can be west systems, Pacer's Finishing resin, whatever you prefer. I typically use Pacers finishing resin, or here more recently US Composites 635 THIN epoxy system w/ the 3:1 medium hardener.
2. Some plastic disposable cups.
3. Mixing Stick
3. Fiber-glass cloth (the weight depends on what you are doing).
5. A soft bristle brush. I'm using 1" Chip brush's from Harbor freight
6. 100% PURE Polyester cloth. it doesn't matter the color, but it MUST MUST MUST be 100% PURE polyester cloth. If it is not, it will not come off the part. You will need just as much Poly cloth as Fiberglass, I suggest getting more poly cloth than you think you will need.
7. A part ready for fiber-glassing. I am using a flap, but this method can be used for just about anything needing fiberglassing.
8. A plastic "spreader" I use a tuper-ware bowl cut to shape and the edges smoothed.
The process (If a step does not dictate a large or small part, that step is for all size parts):
1. using your part as a template, cut the fiberglass cloth to size leaving about 2" of overhang on all the edges.
2. Repeat the process for the 100% Polyester Cloth.
3. Set your fiberglass and Poly cloth "pieces" to the side.
4. Mix up your resin according to the directions.
5. Brush a coat of resin on the side of your part you are planning to fiberglass. If you have a Large part (like the bottom of the wing) Brush a long "+" shaped resin trail w/ the "+" at the center of the wing.
6. Lay your fiberglass cloth over the part.
7a. For smaller parts: Using your spreader, smooth any wrinkles or bubbles out of the fiberglass cloth, place to the side for the cloth to soak up the resin
7b. For Larger parts: Pour a small puddle of resin onto the glass cloth and use your spreader to spread the resin around on the cloth. you should not see any puddles of resin sitting anywhere on the cloth and the weave of the cloth should still be slightly visible.
8a. For smaller parts: repeat the process for the other part if applicable
8b. For Larger Parts: Continue along the part until all of the fiber-glass cloth is covered
9a. For smaller parts: Using your brush, dab some resin onto the part, then use your spreader to spread that resin around on the part to fully saturate the cltoh. Remove any Large buildups of excess resin.
9b. For Larger Parts: Continue to step 10.
10. Take your 100% polyester cloth and drape it over the part. Use your spreader to remove any bubbles,wrinkles,etc so the cloth lays down completely flat. If your resin ratio was correct, the poly cloth should soak up the excess resin, but still maintain a slightly "cloudy" look. If the poly cloth does not soak up any resin in a particular area, you need more resin in that area. If the cloth is completely saturated and appears nearly clear, you have to much resin, so take another piece of polyester cloth and lay it over the areas with to much resin.
11. Look around the edges of the part, if you notice any excess "blobs" of resin, take a balled up paper-towel and "blotch" the excess resin away.
12. Put the part aside and allow to cure.
Video:
http://www.youtube.com/watch?v=330Zh7vUc6k
Over-all, it took me about 20 minutes to fiberglass a pair of flaps that are 3" in chord and 19" long and that includes taking photo's and making the video. So if you remove the time to prep for the video and make it, I could of had those 2 flaps done in 10 minutes including cutting the cloth to size.
I will continue this tutorial in the 2nd post in this thread. I also will post up the link to the you-tube video of this part of the tutorial when it completes its upload. If you have any questions, feel free to ask.
Photos:
The Flaps, 3/4oz fiberglass flap cloth, and the 100% polyester peel-ply
The Flaps fiber-glassed and covered with the 100% polyester peel-ply
_____________________________
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 1
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 1:40 AM
invertmast
Score: 153
Status: offline
Part 2.1
http://www.youtube.com/watch?v=_8EmFzOCB-E
Part 2.2
http://www.youtube.com/watch?v=IvU4sHm46iM
Part 3:
http://www.youtube.com/watch?v=XyZTio2NP9Q
< Message edited by invertmast -- 12/31/2010 8:42 PM >
Thomas W.
Hide Signatures
(in reply to invertmast)
       Post #: 2
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 3:13 AM
Experten109/40
Score: 100
Last Login: 8/31/2011
Status: offline
awesome write-up Sir  and that video tutorial was the icing on the cake. looking foward to part 2.
Experten Flugwerks / Horrido! / SCALECRAFT parts
Bf109 BrotherHood <◄ + |
Hide Signatures
       Post #: 3
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 12:18 PM
yard-dart
Score: 110
Last Login: 5/13/2012
Status: offline
There's nothing like having a video tutorial. Good job. Looking forward to the next segment.
Hide Signatures
       Post #: 4
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 12:50 PM
Avaiojet
Score: 111
Last Login: 5/20/2012
Status: offline
GREAT THREAD!!
Long overdue.
Kudos!
Charles, owner, CFC Graphics, Vinyl graphics "Model Airplane Graphics from a Model Airplane Builder." 58 years of modeling.
Hide Signatures
(in reply to yard-dart)
       Post #: 5
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 1:07 PM
tfarmer96
Score: 125
Status: offline
well done.
www.wyliewarbirds.com
Spitfire Brotherhood #2
Hide Signatures
       Post #: 6
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 2:50 PM
YZ
Score: 100
Last Login: 5/18/2012
Status: offline
That was great, excellent job.  I must have missed it, but what is the purpose of the polyester cloth?
Hide Signatures
(in reply to tfarmer96)
       Post #: 7
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 3:20 PM
yard-dart
Score: 110
Status: offline
The cloth is applied over the glass cloth, which has a slightly wet surface. That little bit of wet is soaked up by the polyester. Once it's cured, the cloth is pulled off leaving a fine texture to the cured resin. The cloth actually helped fill in the weave of the glass, therefore preventing having to put a second filler coat of resin. Once the cloth is removed, sand until smooth, and it's ready to primer.
I'm glad I found out about this method. It's definately a time saver.
Hide Signatures
(in reply to YZ)
       Post #: 8
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 4:32 PM
davidgeorge212
Score: 124
Status: offline
This was very informative because I have never glassed a plane before but I have always wanted try it out. I see how the fiberglass goes on solid surfaces but how are you going to cover the reverse side of the flap that has the open rib structure? Will you just use an iron on paintable type fabric or do you fiberglass it as well?
WACO Brotherhood #166/ Cub Brotherhood #16
1/2 Scale Stits Sky Baby Brotherhood #1
Hide Signatures
       Post #: 9
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 5:03 PM
invertmast
Score: 153
Status: offline
quote:
ORIGINAL: davidgeorge212
The structure on the fullscale was left open for weight savings purposes. I will glass that area in the second video as well.
Thomas W.
Hide Signatures
(in reply to davidgeorge212)
       Post #: 10
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 5:57 PM
invertmast
Score: 153
Status: offline
quote:
ORIGINAL: YZ
That will be shown in the second video.
Thomas W.
Hide Signatures
(in reply to YZ)
       Post #: 11
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 8:19 PM
jlovitt
Score: 100
Status: offline
Great info and video. Is this method, is the polyester cloth serving as "peel-ply" that I have heard of in other locations before?
Thanks for posting your method.
Jeff Lovitt
Hide Signatures
       Post #: 12
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 9:35 PM
invertmast
Score: 153
Status: offline
quote:
ORIGINAL: jlovitt
Great info and video. Is this method, is the polyester cloth serving as ''peel-ply'' that I have heard of in other locations before?
Jeff Lovitt
yes
Thomas W.
Hide Signatures
(in reply to jlovitt)
       Post #: 13
RE: Invert's Fiberglassing Technique 101 - 12/29/2010 11:35 PM
YZ
Score: 100
Status: offline
Thanks.  For some reason I thought it was staying with the airplane.  Yes I can see this will give a great finish without a second coat of resin saving time and weight.
Hide Signatures
       Post #: 14
RE: Invert's Fiberglassing Technique 101 - 12/30/2010 3:23 AM
invertmast
Score: 153
Status: offline
well, part 2 will be postponed till tomorrow. the heater cut off in the shop last night, so the resin wasn't fully cured.
Thomas W.
Hide Signatures
(in reply to YZ)
       Post #: 15
RE: Invert's Fiberglassing Technique 101 - 12/30/2010 12:28 PM
DaddySam
Score: 105
Last Login: 5/3/2012
Status: offline
Very interesting and well presented. Looking forward to the next installment!
Daddysam
Corsair Brotherhood #26, Spitfire Brotherhood #7
Hide Signatures
       Post #: 16
RE: Invert's Fiberglassing Technique 101 - 12/30/2010 6:05 PM
wfmnut
Score: 100
Last Login: 5/8/2012
Status: offline
GREAT Tutorial thus far. I can't wait for the second installment. Having never been through this process, I was wondering about the under-side as well, and even more about the edges. I would have figured you would start on the underside, or in this case the "inside" of the flaps, then apply the fiberglass to the outside and "wrap" it around to the already-glassed underside (or in this case - the inside of the flap).
I think it goes with out saying that a lot of us really appreciate you taking the time to show us how to go about doing this. Most of the people in my club now show up at the field with ARFs or planes they picked up at swap meets. The art and "skills of building" seem to be getting lost in the hobby. Again - thanks for taking the time to show us newbies how to do this!!!
Loren
Hide Signatures
(in reply to DaddySam)
       Post #: 17
RE: Invert's Fiberglassing Technique 101 - 12/31/2010 4:17 AM
invertmast
Score: 153
Status: offline
Part 2 has now been added to the 2nd post in this thread.
Thomas W.
Hide Signatures
(in reply to wfmnut)
       Post #: 18
RE: Invert's Fiberglassing Technique 101 - 12/31/2010 3:57 PM
Dash7ATP
Score: 120
Status: offline
I noticed in Part 2 of your video that you are using Denatured Alcohol as your thinner. I"ve been doing that for years and IMHO it's the best reducer for alcohol.  One thing I have also been doing for years is to save my empty larger Epoxy bottles. I use several reducers for various applications.  Alcohol, lacquer thinner, and of course Acetone. I clean the residual epoxy from the bottles with the alcohol and then use them for my thinners. A small funnel makes filling them easy and reduces spillage. I don't even cap the bottles as the hole is so small evaporation is not a problem.  I use masking tape around the bottles to mark the contents.
Dash
AMA # 8870, Member since 1978.
Waco Brotherhood # 219.
Hide Signatures
       Post #: 19
RE: Invert's Fiberglassing Technique 101 - 12/31/2010 4:05 PM
invertmast
Score: 153
Status: offline
quote:
ORIGINAL: Dash7ATP
I noticed in Part 2 of your video that you are using Denatured Alcohol as your thinner. I''ve been doing that for years and IMHO it's the best reducer for alcohol.  One thing I have also been doing for years is to save my empty larger Epoxy bottles. I use several reducers for various applications.  Alcohol, lacquer thinner, and of course Acetone. I clean the residual epoxy from the bottles with the alcohol and then use them for my thinners. A small funnel makes filling them easy and reduces spillage. I don't even cap the bottles as the hole is so small evaporation is not a problem.  I use masking tape around the bottles to mark the contents.
Dash
I have never thought of that, but that is a Great tip! I use alot of denatured alcohol and acetone (for cleaning contact adhesive off of lithoplate). We learn something new every-day!
Thomas W.
Hide Signatures
(in reply to Dash7ATP)
       Post #: 20
RE: Invert's Fiberglassing Technique 101 - 12/31/2010 8:42 PM
invertmast
Score: 153
Status: offline
Part 3 has been added to the 2nd post..
and here is the link to the youtube video as well:
Thomas W.
Hide Signatures
       Post #: 21
RE: Invert's Fiberglassing Technique 101 - 1/1/2011 12:02 AM
Dash7ATP
Score: 120
Status: offline
Thomas,
I noticed you are using what appears to be a polyester filler over your epoxy covered wing. I'm talking about the blue mixture you said sands so well.  I have always heard Epoxy over poly works well, but poly over Epoxy doesn't xure properly, if at all. Comments regarding that?
Grottoes, huh? I used to live in Weyers Cave between '80 and '82.  I flew a Beech 99 out of the airport.
Dash
Hide Signatures
       Post #: 22
RE: Invert's Fiberglassing Technique 101 - 1/1/2011 1:04 AM
invertmast
Score: 153
Status: offline
quote:
ORIGINAL: Dash7ATP
Thomas,
Dash
I haven't experienced any compatibility issues with the two and i have been using some sort of automotive body filler over epoxy/fiberglass surfaces for a few years. I ought to update my location, im actually in shenandoah now, but fly Kingair 90's out of Bridgewater airport.
Thomas W.
Hide Signatures
       Post #: 23
RE: Invert's Fiberglassing Technique 101 - 1/1/2011 1:18 AM
IFLYRC-RCU
Score: 100
Status: offline
Happy New Year !
Question: Maybe I am slow here, but what is the true advantage of the cloth? Is it to get the surface virtually free of excess expoy ?
Is the intention to virtually eliminate the sanding stage ?
Thanks in advance . . .
IFLYRC - IMAA
Hide Signatures
       Post #: 24
NCIS
Score: 130
Last Login: 6/29/2011
Status: offline
Nice thread. I have been working with glass for 40 years and still can always learn. Liked the video and am waiting for the next segment. Here is a cowl I repaired for a fellow modeler that 1/3 of it was missing. Unlike others I can't wait to get to the finish work and glassing is my favorite part. I always wear surgical gloves though to keep from getting any on myself. I hate the feeling of it on my hands.
Barry
Click to see fullsize image.
Click for fullsize
Barry - Owner of Canopy Rails For Warbirds
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
0.750RCU1
