RE: I need help selecting the best Throttle Servo for a DA-50 in a 30% Yak    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: I need help selecting the best Throttle Servo for a DA-50 in a 30% Yak
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 1:47 PM
on_your_six
Last Login: 5/18/2013
Status: offline
Interesting... I did not hear him say anything about doing any servo testing of any sort to arrive at that conclusion. I do not see centering accuracy specifications listed anywhere on any servos by any manufacturer. Any results you obtain with your method (which seems somewhat reasonable), are merely a random sample that may or may not represent ANY sort of statistical accuracy. To make such a statement which is derogatory towards a particular manufacturer... you (or he) should have more evidence. It would take a representative sample and a blind study to arrive at this conclusion. Everyone here has manufacturers preferences that shade, if not blind, their recognition of the truth. I am not saying you are wrong about your conclusions, just put up more than what has been mentioned here. I have never seen such a study of competing products. Further, you would have to test with various radios... as the radio could make a difference... one brand of servo might be better with a certain brand of radio... I just don't know.
While you always drag up your experience (which is considerable), the hobby changes quickly. The "best" choice a month ago may no longer be. This is especially true when it comes to electronics. Others have posted wonderful experiences with $3 micro servos in small helis... I have been using $9 servos with great results and have also used $50 and $90 servos.
Your condescending attitude towards differing opinions has been noted...the big boys might agree. If someone disagrees with you, it should not ding your ego one bit.
"If you listen more than you talk, you might hear something."
quote:
ORIGINAL: Tired Old Man
For evidence take a couple of those 645's and mount them on a piece of light ply. Make a long pointer by adding a length of anything to the servo arm that is aligned with the arm. Place a protractor against the side of the servo case, or somewhere the pointer can overlay the degree arc of the protractor. Now run the servo through end points and back to neutral again, over and over. Write down the numerous different degree positions. You can do that with any servo of any brand.
Of course there's an easier way for those that have them in planes already. Just move the control surfaces and note all the different places a surface ends up when the servos come back to neutral. You need to get to the top of the Hitec line before you achieve ''good'' centering but even then you won't match the centering and resolution of the upper end Futaba, Airtronics, and JR servos. Each brand has their strong points and one has to learn what they are and how they might benefot before making a servo selection. It's not just about ''the best'' but also about what will best suit the user and the application. Those are not always one and the same. BTW, the difference between a 5925 and a 5945 is the gearing. That's what establishes that difference in speed and torque between the two servos. The inner workings are identical.
I'm not going to add much more to this thread since it seems to be mostly newbies feeding false data to other newbies. I don't have a clue where some of the info in this thread originated, but a whole lot of it is pretty much useless and misleading. For those of you just getting into gas giants I'll suggest you talk to people that already fly tham and have been doing so for a looong time. Not too bright using people with as little or less experience than yourself as your source of product and operational info.
As for nylon gears...the 8411 was the servo of choice for TOC giant aircraft before the metal geared stuff came along. Many of the Comp Arf assembly manuals still note the use of an 8411 in their planes. The upper end before that was the 4721. Now if you want a high end plane, look at a Compy, Zlin, SebArt, or similar. That's the big boys folks. All servos wear and develop slop. Once you know anything about servos, or anything else mechanical, you understand there is no such thing as ''good forever''. Eventually everything wears out, with some faster than others. Then you have installation errors compounding the speed of wear, and many of you do quite well at wearing stuff out as fast as it can through poor installation and set up practices.
So Happy New Year and good luck. I'm heading back over to the big toys forums at a significantly more advanced site.
Hide Signatures
(in reply to Tired Old Man)
       Post #: 51
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 1:57 PM
JNorton
Last Login: 5/17/2013
Status: offline
What I heard was put your spring back on so the throttle plate doesn't wear out. Nylon gears are fine for a throttle. You don't need massive torque ratings. You do need repeatability. I ignore perceived emotions on these threads because of the failure of the written word to convey intent. What I look at is the amount of time someone uses to help others. Time is precious. Postings about people personalites are a waste of my time, I look for content I can use.
John
_____________________________
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to on_your_six)
       Post #: 52
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 2:18 PM
summerwind
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: on_your_six
While you always drag up your experience (which is considerable), the hobby changes quickly. The ''best'' choice a month ago may no longer be. This is especially true when it comes to electronics. Others have posted wonderful experiences with $3 micro servos in small helis... I have been using $9 servos with great results and have also used $50 and $90 servos.
''If you listen more than you talk, you might hear something.''
Very well said. (to on_your_six)
it would be nice to just have a discussion without someone coming in and answering in the typical rude fashion that has become so typical. the "i am tired of answering" is another reason to just not answer at all.
there is no reason to use a cheap servo or even a typical standard servo in throttle application regardless of how well the linkage is setup.
the use of a high end servo is to ensure the same operation again and again.
AMA 70865
Team Satellite
Hide Signatures
       Post #: 53
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 4:53 PM
Tired Old Man
Last Login: 1/16/2012
Status: offline
on your six,
I use Hitec servos a lot and have been since they first came into the U.S., with the highest end servo for me being the 7985's. I also set planes up for other people using the top of the line products. I recently set up a 30cc plane for myself and another person using 645 servos. Setting up the elevators was a real pain because the servos function at different speeds and have yet to achieve a consistent center position. The JR 821 standard digital does a lot better in both speed consistency and centering.
The upper end servos are better but still don't center with absolute repeatability. Speeds are better matched but netural often "wanders" a tiny amount. That amount is not much, just a couple of degrees, but I would not want to try pattern with them because I would always be chasing a trim position. I find them plenty good enough for the type of flying I do while others may not. I'm aware that they can be a little better set up using a servo programmer but in my humble opinion one should not have to purchase a programmer for a servo to work the way it should. I don't care if a servo does not come out of the box exactly matched in throws to the one in the next box, but operational speeds and neutral matters.
My opinion has the best servos on the market for speed consistency and precision to be Futaba or Airtronics but they cost more than most are willing to pay. They also require some gear service periodically to maintain that level of precision, which is also something many people do not want to deal with. We have a lot of choices open to us and we need to determine what will best fit what we want to do. If you want install and forget, Hitec is the best option with their titanium gear products. That's not 100% but high enough up the ladder for those with that desire. If one is willing to spend a little time taking care of things other products may be a better opption
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to summerwind)
       Post #: 54
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 4:59 PM
Nitro-Tom
Status: offline
Tom,
My name is Pat and I've been in the RC part of the hobby for about 40 years now. Control line before that. I've come from having to cut all my own wood and using tissue for covering, to full composite uav's today. All I do anymore is engines but I've been seriously involved with all aspects of GS for a very long time. I've watched as digital servos first came about and participated in the use of the less reliable early versions. To minimize aircraft losses I had to learn what made each servo brand work better or worse than the next one. I think ARF's are great but I believe there's a lot to be gained for all if they got to build a real kit. I'm also one that believes people should have a go a gliders in order to learn about aerodynamics and energy management. Makes them better power flyers.
I've been around RCU for a long time and have assisted many with their entry into giant scale and gas engines. Used to do a lot of radio and servo set up stuff but that became more arguementative than engines. Helped a few manufacturers with improving their products or customer support methods along the way. Ran as fast as I could from supporting any particular ARF distributor (though I still have a favorite or three) because of extreme brand loyalties with people supporting other products. That should explain the post count.
I've been known to spend far more than I needed to in order to complete a plane to what I thought to be the highest levels of quality and reliability. In performing that process I've learned that using the most expensive or most technologically advanced products wasn't always the best way. The most expensive perhaps, but not always the best way. A lot of the tech ''advancements'' aren't advancements at all, but lateral moves intended to generate new sales to invigorate a slumping market. In learning all that there are times I hope to share that education with others so they won't make the same ''mistakes'' I did and spend far more than needed to assemble a high quality, high performing aircraft. That can be extremely frustrating at times since a lot of what is considered ''old'' still works as good as the ''new'' stuff. I also try to provide information intended to prevent people from buying stuff and doing things that won't work out as well as they hope. It's cheaper if they listen and often they get to keep their planes longer.
You won't ever read about me condeming anyone for purchasing a top of the line engine. You'll get your money's worth and have a better resale should you ever decide to let it go. I have a little of everything and everything has a place, you just have to know what those places are. Same applies to the better airframes and solid radios. I can't help you with the flying side of things aside from telling you to burn a lot of gas. A flight sim and a foamie complete that cycle. The sim lets you develop the hand, eye, thumbs talenst while the foamie is slow enough and easy enough to repair to develop the confidence you'll need to get low and slow. The operative word there is confidence because you must have complete confidence in your equipment, especially the engine, and your own ability before you can be more than average. You don't need to be daring or reckless, just confident in your ability through lots of practice. The plane itself will not be what makes you better, that will all be you.
I'll admit to being grumpy but that's what happens when the same things are said over and over because the words were rejected by people that succumbed to some good advertising or a conversation with a sponsored flyer. A flyer is sponsored because they will win contests on a consistent basis, and would do so if using the worst products available. They also have to be good ''spokespersons'' for the hobby. You might equate ''salesperson'' with that description, although the real competition superstars are the ones that go out of their way to help people regardless of the products in use. So they are given products in order to subliminally convince people the stuff on the plane is what won the contest, not the operator. People don't really think a pair of Nike sneakers wins basketball games, or that Budwieser makes for better football players, do they?
So that's who I am. I try to help and educate but also try to have fun. Sometimes that doesn't work out quite the way I would prefer.
Well Pat.....
I am glad to say if a UAV is flying over MY house (Local Law Enforcement, property survey, who knows) I am glad they purchased it and it was setup from YOU!
As you said, one can get tired if the same questions are asked again and again, and my boss has a rule, Google it first, BEFORE you ask him.... so the answer better not be in the top three or 5 responses on google.....so I get that for sure....
and like you said, the new 2.4.....all the advancements in technology.....many times are an exercise just to get back to where we were before that product came out.....many times we are lucky to get back there.....and work equally well....we still have some 72Mhz at our field and I still have an old AM radio (Hi-tec) for my cars
I agree with you on the quality issue....which is why I picked up a DA-50
It's my first gasser and it's good to have the support behind you and it has come in handy......not to mention they sell Lawn Boy Ashless (For break in) (Hard to find in my area)
And I think and hope I did the same..... thanks to the help of you and others, in this forum, in selecting my throttle and choke servo's....
Now I am going to get this over priced bird in the air, and work on my torque rolls, hovers, knife edges, etc......and clean out the bench for my next project....
My local scratch builder has me buying some wood from Balsa USA......sending that and some plans to a guy local here that laser cuts it, and I am going to scratch build an Alpha 40 style trainer......then he can start me on my covering lessons.....and once the bird is done, I can sell it and move on so I can do another.....
I really want to get into building because as many have said, the ARF's are OK, but if you want it done right.....sometimes you have to do it yourself....
and Pat, you're gonna love this....check out the new coffee cup my Wife got me for my birthday (12/29).......
Classic!
Thanks again for all the help! Happy New Year!!!
Click to see fullsize image.
Click for fullsize
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 55
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:04 PM
Nitro-Tom
Status: offline
quote:
ORIGINAL: GreaTOne_65
Hey, Tom. Will reading your question, and the answers. I must tell you until 5 years ago, I never used anything but Futaba S148's on everything in my gas powered airplanes. 5 years ago, I dicided not because of any failures, that maybe on the BME 540 Edge I had just bought, maybe I'd better at least run MG servos. But I still used S148's for the throttle and the choke. I have only had one servo failure, that was on a Bud Nosen Mustang, that is from 30 years of flying. If your looking for a good MG servo, I have been useing Hobbico with very good luck. Here is a servo that will more than fit the bill. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNRP9&P=7
Thanks....it's amazing that Hi-tec and now Spektrum are right there with these guys on price......I bet those HobbyCo servo's drop even more over the next 6 months.....as the new 2011 line from Spektrum and Hi-tec and many others are putting preasure on them, as for only a few dollars more you get a "Name Brand"......
but if it is like electronics I work with (Computers) then there are reall yonly a few guys making servos all together.....
Thanks again for the tip!
Happy New Year!
Nitro - Tom
General R/C Addict
Hide Signatures
(in reply to GreaTOne_65)
       Post #: 56
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:09 PM
JNorton
Status: offline
Hide Signatures
       Post #: 57
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:11 PM
Nitro-Tom
Status: offline
quote:
ORIGINAL: RCER88
I find this thread kind of amusing. The battle of $ vs intelligence. I will not spend $46.00 on a throttle servo when a $10.00 or less analog will do the job just as well. I am using a analog nylon gear un-name brand standard servo that I bought for $8.00 new for throttle on my quadra 35 in my 116 inch Davis D1W. I am in no way concerned if that servo fails because I have a built in redundancy. (ie remote engine kill.) I would just line up on the runway kill the engine and land.
It is very easy to reduce the effect of vibration on your throttle servo. Ever heard of nyrod? I know there is engine vibration and using nyrod it does not ''feedback'' to the servo. I learned that years ago. The plastic will not vibrate like a solid metal rod would thus reducing stress on the servo. In twenty plus years of R/C flying I have only had two servo failures. I had one throttle servo failure on a glow airplane that I had flown for six seasons. Before I switched to nyrod. One I caught on the ground during preflight on airelons on a High speed airplane that had four seasons of heavy flying.
Many of your ''high dollar named brand servos'' are built in the same factory as some of the NO Name servos using the same components.
But to each there own. It is your plane do what you are comfortable with. I prefer to be smart in my selection of equipment and setup so I have more cash for other things. (like more airplanes)
Happy Flying!
good point and I have the Sullivan Nylon rod's for both throttle and choke here....not only to dampen the vibration but to isolate the ignition.....from the Rx.....
I would never connect a servo to a gasser up front with a metal rod, although I have seen it done......and really I doubt ignition interference is a big deal unless you're clip comes off the plug boot or the wire is frayed,etc....
but none the less, I have used a good plastic rod to get both isolation and vibration dampening........
and I wish I knew what servos were made where, for sure you could save some $$$$ there.....
I wish I had a 9CH and I would have added the kill switch.....I probably should have done that anyway and went with a lever on the choke as pointed out earlier in this thread....save weight.....
Nitro - Tom
General R/C Addict
Hide Signatures
(in reply to RCER88)
       Post #: 58
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:17 PM
Nitro-Tom
Status: offline
quote:
ORIGINAL: Eganwp
To the OP, I run a simple PowerHD DS090 on my throttle. Works great @ $19.
On the note of servos and $$ spent, I 100% agree with Tom and others here. People sometimes laugh at me for using such cheap stuff, but the real funny thing is, in nearly every case my planes stay flying while others are long gone...
I use $5 std sport servos from HK in all my .40 sized planes. They work great, center well, have no slop and are reasonably fast. One plane I have does 115mph and has over 300 flights using these servos. A few others are past the 100 flights mark and I've never had a single one fail. It all depends on application though. As TOM said, each needs to do his own research and QA to discover what works for a particular application. I don't even want to think about the $$ hundreds of dollars I've saved in this hobby by not simply ''throwing money at it''. I bet TOM is in the 10's of the thousands, if not more!
To each their own.
True....I have the same issue at work, and throwing money rearly solves the root cause......
I have had mixed luck with hobby king.....stuff stuck in customs for 50 days and if you pay the Credit card.....then you have to go back and dispute it later, yuck!
at some point in the equation you need to add in your time......
I had brain surgery 5 years ago (That explains alot ) and my time on this rock is short......so I do not mind throwing a few dollars at it when it saves me time.
I do not have to wait 60 days for Hobby king and homeland security to x-ray my $9 servos
But you live in the great white north, so you do not have that issue....I guess.....
When I move, I am going to Canada or Australia......if they'll have me
Nitro - Tom
General R/C Addict
Hide Signatures
(in reply to Eganwp)
       Post #: 59
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:26 PM
Nitro-Tom
Status: offline
quote:
ORIGINAL: JNorton
John
Nice desk john!
I don't know that I agree on the nylon gear.....it seems MANY do....and many are doing it.....
but if there were ever a reason for metal gear (not easy to wear out) would it not be on a vibrating engine?
I know the plastic rod dampens that considerably....especially when long enough.....
heck, I saw one guy use a sulivan "Cable" and his throttle servo was WAY in the back of his yak, near the rudder servo....
agree on the torgue, except my choke is new, and is giving the 80oz DS-821 a hard time.....to pop it open once closed....it has that Ball and spring...I guess all these walboro carbs are the same...not sure.
and I agree 110% on the written word......many times fails in transit.....we should have to have a license to email
Happy new year! Thanks for the input....but I am waisting the extra $25 and going Hi-tec metal gear.....
Nitro - Tom
General R/C Addict
Hide Signatures
(in reply to JNorton)
       Post #: 60
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:30 PM
Nitro-Tom
Status: offline
quote:
ORIGINAL: JNorton
John
and this is another good point....thanks to T-O-M (Pat)
the spring does act as a spacer and I can see that, if you just un-hook it from the throttle as DA recommended me to do, it still acts as that spacer, just no return....
However I put it back on as OEM......because T-O-M is right, it has MAYBE 1-2 oz/in of torque (just guessing here) I have no way to measure that small amount, but it is not hurting my new Hi-tec that's for sure.....and it maay help go back to idle in a failure senerio.....
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 61
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 5:47 PM
Tired Old Man
Status: offline
About 20 ounces of resistance but once that is pushed into position it's a non issue for the servo. You're ailerons at speed probably generate more resistance.
Get rid of the Lawnboy. You don't want to deal with the aftermath. Once an engine finishes breaking in you don't want to take another 5 gallons of gas to clean out the carbon and additives left behind from the Lawnboy. Just use what you plan on running all the time. The DA suggestion of Pennzoil for break in if you feel the need for a separate break in oil is a much better choice.
If you use 40-1 Stihl you won't see any appreciable wear at 100 hours. There's a lot of DA's broken in and run where I'm at, and they start life with the Stihl HP Ultra.
Hide Signatures
(in reply to Nitro-Tom)
       Post #: 62
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 6:14 PM
Nitro-Tom
Status: offline
Alot of folks here recommend Amzoil.....I have a lot of motorcycle shops around....bel-Ray, Amzoil....I am sure if I look I can find anything.....Since I mixed up the first gallon, I will use it...but then I am onto the synthetic for sure......
One thing I am confused about (moving forward after break in)(And I agreee - Qucik break in) after the switch to synthetic.....lots of folks are anti 100-1
Lot's of folks swear 50-1.....32-1 ....I am not sure about the correct ratio
I should have added - I am guessing 50-1 any good synthetic.....
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 63
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 6:53 PM
JOHNS3D
Last Login: 10/28/2011
Status: offline
... i hope one day you have enough info on your mind on this hobby like Pat and others gurus has.
< Message edited by Rcpilot -- 1/2/2011 10:50 PM >
OMP Extra 300 100cc - DLE111
AW Extra 300 50cc - DLE55
Hide Signatures
       Post #: 64
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 6:59 PM
JOHNS3D
Status: offline
quote:
ORIGINAL: Nitro-Tom
Tom, i think you need to have time to read and search on this forum about all the questions that you have..........there is a lot of threads with differente oil brands out there, but let me resume it for you. Amsoil is the worse oil for our engines...it will build carbon and ruin your engine in a few hours. Whats the best oil? ratio?.
In almost all the thread the Stilh hp ultra, belray and redline are the winners in that order, it seems that protect the engine better than other oils available. On the ratio, 32:1 for brake in, 40:1 or 50:1 is the most ratio used.
Remember...one thing is motorcycle shops and other is persons that actually fly airplanes with gas engines.
Hide Signatures
       Post #: 65
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 8:02 PM
Nitro-Tom
Status: offline
I mean 16000 + posts......the man has taken TONS of his time in the name of helping others, I am sure.....
he knows his stuff, and again, I doubt I will live long enough to even come close to that mark....I have been here 4 years and have like less than 200
and I can't type either
Seems most of the whopla is "Centered" (pardon the pun) around some comments about some servo's not centering well.....and how that affects this and other applications....
All I can say on that subject, with my limited experience, is I have seen servos that center well and others that do not....again the "Newbie" is likely to think "That servo cost $132 so it must be good".....when that may not be the case......
But no doubt T-O-M has contributed alot to the hobby and helping others.......Grumpy or not.....
< Message edited by Rcpilot -- 1/2/2011 10:49 PM >
Nitro - Tom
General R/C Addict
Hide Signatures
(in reply to JOHNS3D)
       Post #: 66
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 8:08 PM
Nitro-Tom
Status: offline
[/quote]
NO need to resist (That's my motto)
Stilh HP Ultra at 32:1 for the remainder of my break in (At this point I might as well finish the first gallon with lawn boy ashless) then after 5 or 6 gallons move to 50:1 (After break in)
I have some guys useing redline at 50:1 at my field , again saying 100:1 is to "Lean" if you will
Thanks and Happy New Year!
Nitro - Tom
General R/C Addict
Hide Signatures
       Post #: 67
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 8:52 PM
wesaysoracing
Last Login: 4/11/2013
Status: offline
Pat since oil was brought up what do you think of this article by a two stroke racing engine builder?
The total amount of time that it takes for a drop of oil to get from the carburetor, to the lower end bearings, to the top end, and out the exhaust port is called "oil migration time". As peak rpms increase, the amount of time that a drop of oil remains inside the engine is drastically shorter. In other words, a 9000 rpm race engine would need a mix ratio of about 32:1 to maintain the same internal lubrication presence that a stocker would have with a 50:1 mix. There are several oil brands that claim that their oil can provide equal lubrication at a leaner mix ratio (60:1 or 80:1) because of a claimed better lubrication quality. In my 20 years of working on racing motors, I have never experienced this to be true nor has any oil manufacturer, to my knowledge, proven it to be true. It's like running your truck on two quarts of a special oil instead of four quarts of a standard type oil. The quality cannot make up for the quantity...ever.
It''s too bad that stupidity isn''t painful.
Hide Signatures
       Post #: 68
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 10:16 PM
rmh
Status: offline
the correct mixture for the prop load (controlling temperature) is far more important than the oil brand or the specific mix
to restate - use a accepted brand at recommended mix- THEN be sure you get the mix in the correct fuel to air ratio
personally - 32-1 on synthetic - from day one
Libby is still watching you
Hide Signatures
       Post #: 69
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 10:42 PM
on_your_six
Status: offline
Thanks, there was not a darn thing in my post that anyone should have objected to...
If you are going to spread the word to beginners that X-brand is better than all others, you need to provide some proof... when it comes to engine advice, I think T.O.M. is usually right on. When it came to this matter, there is room for disagreement.
and there is no reason to start the foul language. Disagree if you want on an intellectual level. Cite a published article, or study, don't shoot from the hip.
For the record... I would welcome a carefully crafted servo comparison to get these answers... a consumers report on servos if you will. If you want to talk about servo speed and centering, I think the heli guys are the ones to ask.
quote:
ORIGINAL: summerwind
it would be nice to just have a discussion without someone coming in and answering in the typical rude fashion that has become so typical. the ''i am tired of answering'' is another reason to just not answer at all.
Hide Signatures
       Post #: 70
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 10:56 PM
rmh
Status: offline
The servo of choice is not a important as the installation ( hookup) I have used servos costing 10 bucks to 100 bucks an d honestly all you need is a good 75 in ounce servo -preferrably of std size for better gears which will take the punishment
making certain the geometry is correct and using 100% of throw is a must as you then get best idle trim setups
If you have over 35 bucks to blow - there are any number of full metal geartrains and 150 in ounce servos too.
eliminate all slop and use light pushrods
a very light return spring on the carb is a good idea. this further reduces hammering the servo.
Hide Signatures
       Post #: 71
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 11:06 PM
JNorton
Status: offline
http://www.servodatabase.com/servos/all
John
Edit -> added http://www.rcmodelreviews.com/reviews.shtml
Hide Signatures
       Post #: 72
RE: I need help selecting the best Throttle Servo for a... - 1/2/2011 11:28 PM
on_your_six
Status: offline
Great... good stuff... but the argument was about centering accuracy (for example; do the ailerons always return to the exact same position when the stick is released on the radio)... and to my knowledge, that data is not available. Thanks for the try.
I would like to see it if someone has a cite.
quote:
ORIGINAL: JNorton
John
Hide Signatures
       Post #: 73
RE: I need help selecting the best Throttle Servo for a... - 1/3/2011 12:14 AM
JNorton
Status: offline
Do it yourself with the servos you use and let us know.
It is so easy to post the question you did to TOM to refute his experience just by asking for proof when none exists. By and large my experience parallels Pat's. I use Hitecs almost exclusively but I fly sport no 3D so centering is much less a problem for me with the reduced throws.
John
Hide Signatures
       Post #: 74
RE: I need help selecting the best Throttle Servo for a... - 1/3/2011 1:19 AM
on_your_six
Status: offline
go back and look at his post... T.O.M. was the one saying such and such centered better than everything else.... I innocently asked him for some proof. I called him on it, and proved my point, he had none.
Experience is great, I have some myself (5- 50cc planes built and flown), but don't let your brand loyalty color your glasses. I like HiTec servos. I choose brand and servo by the application. I also have some JR and Futaba stuff. I really don't like what Tower did to me repairing a high torque rudder servo.
I poked around on the site you mentioned in your second link.... looks like he is doing some servo testing... I have bookmarked that site.... Anything I do would be anecdotal evidence in an uncontrolled environment... I would get ripped for publishing anything like that here. If that guy ever posts something, I will be interested in reading it. It sounds like he has a lot of incomplete projects going.
Hide Signatures
       Post #: 75
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: I need help selecting the best Throttle Servo for a DA-50 in a 30% Yak
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.496RCU1
