Can E85 give more power in a DLE-55?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Can E85 give more power in a DLE-55?
Page: [1]
Login
Can E85 give more power in a DLE-55? - 1/10/2011 7:06 PM
wingspan99
Score: 100
Last Login: 6/22/2012
Status: offline
I know some people have used methanol on gassers in the past and got more power. Would E85 give more power and what oil and ratio should be used? I'm assuming a synthetic oil should be used so that it blends well with the E85, but with the lower lubricity of the ethanol at 85%, I should probably use more than 1:30 oil/E85 mix. Anyone tried this?
_____________________________
Tom in Yoder, CO
Hide Signatures
       Post #: 1
RE: Can E85 give more power in a DLE-55? - 1/11/2011 1:22 PM
gkamysz
Score: 120
Last Login: 2/6/2012
Status: offline
You aren't going to see more power with E85 unless you increase compression ratio to take advantage of octane rating. The lubricant needs to be compatible with alcohol, castor or synthetic. There aren't many choices for lubricant, Klotz KL-200 is one I've used. Oil ratio is a good question, let us know what you find.
Greg
Hide Signatures
(in reply to wingspan99)
       Post #: 2
RE: Can E85 give more power in a DLE-55? - 1/11/2011 3:25 PM
jeffie8696
Score: 120
Last Login: 5/25/2013
Status: offline
An old article but a good place to get started. http://journeytoforever.org/biofuel_library/ethanol_drane.html
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to gkamysz)
       Post #: 3
RE: Can E85 give more power in a DLE-55? - 1/12/2011 7:04 AM
Kweasel
Score: 100
Last Login: 5/4/2013
Status: offline
I know people in Florida that successfully ran 20:1 KL200 in their Sachs 3.2 and 4.2 when burning methanol. Dont know how low you can go but tipping the can never hurt. Try a full length tuned pipe with E85 for insane power.
Hide Signatures
(in reply to jeffie8696)
       Post #: 4
RE: Can E85 give more power in a DLE-55? - 1/12/2011 2:55 PM
wingspan99
Score: 100
Status: offline
I have a .61 size pipe, would it be big enough for a DLE-55? I know the DLE runs at half the speed the .61 used to run at, but the opening is very small. Any suggestions on a pipe for the -55?
Tom in Yoder, CO
Hide Signatures
(in reply to Kweasel)
       Post #: 5
RE: Can E85 give more power in a DLE-55? - 1/14/2011 7:46 AM
TimBle
Score: 162
Status: offline
you will need one of the "canisters" for a DLE55. These are specially designed for gasoline engines and takes advantage of the massively increased gas flow that a 55cc engine has and lower rpm.
The engine porting and hence timing on the DLE is optimised for gasoline so E85 is going to give you no gain, you will have less power. It may burn faster but it yields a lower temperature of combustion which also means possibly increase friction since the engine block will reach its design temperature.
well thats my 2c
Hide Signatures
       Post #: 6
RE: Can E85 give more power in a DLE-55? - 1/14/2011 9:18 PM
Sport_Pilot
Score: 233
Last Login: 5/24/2013
Status: offline
Actually there will be some power increase, just not as much as if you raise the compression ratio.  The same can be said for methanol, but E-85 power increase will be moderate compared to methanol.
Hot rodders have found that both ethanol and methanol will increase power with no mods.  Cam and port timing are related to the RPM that peak horsepower and torque are required, not the fuel.  The fuel increases the combustion pressure which increases torque at this peak thus also increasing horsepower.
I think the confusion is because of efforts to regain some economy when running E85, increasing compression increases power and economy.  But only moderate fuel economy when using the max power, so timing is altered to decrease power and to produce power at a lower RPM thus increasing economy.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 7
RE: Can E85 give more power in a DLE-55? - 1/16/2011 3:26 AM
wingspan99
Score: 100
Status: offline
I have mixed some E85 with 10% castor mixed in and I'm going to try it. I know the castor isn't the best oil for a gas engine, but it blends in the E85. I have some KL-200 too, I'm going to try mixing 6% KL-200 in E85 and see what rpm I get compared to 30:1 gasoline.
Tom in Yoder, CO
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 8
RE: Can E85 give more power in a DLE-55? - 1/29/2011 9:19 PM
moe7404
Score: 100
Last Login: 5/13/2012
Status: offline
what this cat has is a project car. if he was driving a daily driver he wouldnt have as a glowing report. also some of his info is wrong. also i have worked on and owned LOTS of that carb he used , on scale of 1 to 10 that carb is a 3. that carb is good ONLY if you know how to work on it, he doesnt.
Hide Signatures
       Post #: 9
RE: Can E85 give more power in a DLE-55? - 3/20/2011 10:32 PM
moe7404
Score: 100
Status: offline
i dont know what i was thinking on post #9 it looks like i posted something on this thread that was realy for somewhere else. sooooo, thats my mistake for the year , sorry
Hide Signatures
(in reply to moe7404)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> RC Fuels >> Can E85 give more power in a DLE-55?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
