1/6 SCALE TWIN OTTER BUILD
My Feedback: (13)
TX
i am building this airplane for a friend of mine.its the 1/6 scale from john labelle plans.130inch wingspan.got finished going through all the pieces and sorting them out of the short kit...from what i see so far everything looks good. its not going to be a full blown to scale contest airplane...it will have some details and it is more meant to be an everyday flyer..
i will start posting some pics soon..so everyone interested please feel free to chime in whenever and enjoy
gene
gene
My Feedback: (13)
TX
RE: 1/6 SCALE TWIN OTTER BUILD
ok here is the first few pics. decided to start with the horiz stab...the spars were made undersize and capped with balsa to ease in sanding to get the correct shape for the sheeting. it doesnt hurt any with strength.just makes sanding to shape much easier...if you look close at pics you will see what i am talking about...will show better when i get to that point
My Feedback: (13)
TX
in the first pic you will see the rear spar for horiz stab....it was made in 2 parts...reason for this is much easier to cut the slots for the elev hinges, and in the 2nd pic. shows the spar laminate glued and supported to an aluminum angle
makes it more stable and keeps the warps out
TX
gblass777, think this is your L-19, correct? http://www.youtube.com/watch?v=8v36aGuNiNc
SIMCO, give me heads ups before maidens. Your planes are always interesting.
C-47 maiden at about 4:30: http://www.youtube.com/watch?v=8v36aGuNiNc
Thunderbolt: http://www.youtube.com/watch?v=RxC5nEFupeY
Skyraider at about 3:55: http://www.youtube.com/watch?v=p32W_GHQpqQ
gb
gb
My Feedback: (13)
TX
elevs connected to horiz stab for hinge alignment...elevs will stay removeable until horiz stab is mounted to vertical...so far everything is fitting nicely
My Feedback: (13)
TX
in these pics are the plate for the main gear. 6 of the eight slots had to be extended to match the other 2 for proper fit on bulkheads...also cut the bevel on the sides to match the contour of the fuse skin..much easier to do that before it is glued in. you can see in the pics the before and after
My Feedback: (13)
TX
here is the main landing gear plate fitted; and glueing in place. slow setting epoxy used to allow time to make sure everything is all square and set right
Subscribing,I have Johns kit as well and will follow with interest,I'm finishing up some other projects and hope to start soon on this one ,keep up the good work...
Steve
Steve
My Feedback: (37)
I'm interested in this plan but can't get on John's website (www.johnsplansandkits.com). Are the plans and kits still available?
My Feedback: (13)
TX
yes i think the plans and kits are still available....the one i am building was cut and shipped a few weeks ago...i havent heard anything different...................been working on horiz stab and rudder....it takes a little time since it is built on the airplane and not over the plans...will have some more pics soon
My Feedback: (13)
TX
ok heres a few more pics...getting everything aligned with the verticle stab and rudder........little slow going here....measure twice and cut once rule applies...had to make the rudder spar measuring off the back of the vert spar .....need to sand down the tail sectionto get ready for some sheeting so it is time to make a temp move to the garage....sawdust in the house is a nono with the wife.....balsa dust seems to get everywhere...have to agree with her
Rosisco (01-27-2023)
