Motor causing Rx interference?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Motor causing Rx interference?
Page: [1]
Login
Motor causing Rx interference? - 1/17/2011 8:39 AM
saleens7
Score: 105
Last Login: 2/28/2012
Status: offline
So i've been having issues with my RC going out of range easily. I'm running a Hitec Agressor SRX pro on my brushless tamiya DF-03 buggy.
If i get more than 30 - 40 feet away, I experience throttle blipping and sometimes momentary cut-outs where I have no control. My receiver seems to be working fine, the antenna is wired up right (it does pass close to the motor, which may cause some interference?). I'm not sure if it's my radio system, or just the set up. My friend has a traxxas rustler with the stock AM tx/rx setup, no problems what so ever. I even switched my brushless setup over to it one day to see how fast it went. In between the 60mph wheelies, I noticed his car didn't get any interference at all, despite running my same motor/esc/batt setup, and we would get it as far as 200 feet away. The only difference is that his has the antenna wired up to the front of the car, away from the motor, where mine passes within an inch of the motor where it wires through the antenna tube. Could my motor be causing the interference?
_____________________________
saleens7, the wookie of RC
Hide Signatures
       Post #: 1
RE: Motor causing Rx interference? - 1/17/2011 12:53 PM
BuschBarber
Score: 104
Last Login: 5/20/2013
Status: offline
I am not an experienced RC Car person so I have not used that particular radio. It appears to be 2.4Ghz?
http://www.hitecrcd.com/products/new-products/aggressor-srx-pro-2-4ghz.html
Have you tried moving your Rx, on the buggy, to get further away from the motor, just as a test, and then Range Testing it?
http://www.hitecrcd.com/products/surfacerra/2-4ghz/atom-3.html
It appears to have one antenna. Perhaps reorienting the direction of the antenna?
Have you tried another Rx on your chassis? Did you say you tried your Rx on someone else's chassis?
Rich
byronf16@gmail.com
Hide Signatures
(in reply to saleens7)
       Post #: 2
RE: Motor causing Rx interference? - 1/17/2011 4:02 PM
saleens7
Score: 105
Status: offline
I have the FM version of the pro. It has the removable module, so I could switch to 2.4 if i can find one. I don't really have any other FM Rx's to use at the moment, so I'm going to have to buy one to see if it works out. I tried looking for the 2.4 module, but all I'm finding it their 6+ channel ones for their plane controllers.
I'm going to try a different antenna placement. If that doesn't work, I think I'll try a different Rx.
Hide Signatures
(in reply to BuschBarber)
       Post #: 3
RE: Motor causing Rx interference? - 1/18/2011 2:14 AM
safeTwire
Score: 100
Last Login: 7/1/2012
Status: offline
Check for any metal to metal contact, a possible source of RF interference.
Motor bearings, wheel bearings, exhaust manifold & muffler/pipe, etc.
Get a helper and do a range check as per factory specs.
RX been in a crash?
Try a shield insulating motor from antenna?
Just a few thoughts...
Hide Signatures
       Post #: 4
RE: Motor causing Rx interference? - 1/18/2011 7:35 PM
saleens7
Score: 105
Status: offline
quote:
ORIGINAL: safeTwire
RX been in a crash?
I got the Tx/Rx used, so I'm not sure if its been in a crash. It comes very close to the motor, so I wouldn't be surprised if that's interfering with it. I have to wait for some parts to come in before I can run it again, but I'll try re-routing the antenna. If that doesn't work, hobby king does have that 20$ 2.4 system
Hide Signatures
(in reply to safeTwire)
       Post #: 5
RE: Motor causing Rx interference? - 1/19/2011 4:05 AM
safeTwire
Score: 100
Status: offline
Sounds like a plan! Good luck and let us know how you made out.
Hide Signatures
       Post #: 6
RE: Motor causing Rx interference? - 1/19/2011 4:42 AM
dirtybird
Score: 173
Status: offline
The control system for a brushless motor is a good RF interference generator. An FM-PPM system is especially vulnerable to this RF. The best solution is to move to 2.4GHZ.
Hide Signatures
       Post #: 7
RE: Motor causing Rx interference? - 1/19/2011 1:15 PM
saleens7
Score: 105
Status: offline
quote:
ORIGINAL: dirtybird
I'll take this in mind
Hide Signatures
(in reply to dirtybird)
       Post #: 8
RE: Motor causing Rx interference? - 1/19/2011 1:20 PM
BuschBarber
Score: 104
Status: offline
I believe they used to connect Capacitors, across certain wires on electric motors, to reduce RF noise that bothered PPM. I would think modern RC Car motors would have them already.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 9
RE: Motor causing Rx interference? - 1/19/2011 2:47 PM
carrellh
Score: 179
Last Login: 5/19/2013
Status: offline
If you make your installation as much like your friernd's truck as possible, I think you have a good chance of solving the problem without changing radios.
I found a lot of links to the Hitec 2.4 module but all say 'out of stock' until late February (which may really mean July).
One link http://www3.omnimodels.com/cgi-bin/woi0001p?&I=HRCL4100&P=0
- Carrell
Hide Signatures
       Post #: 10
RE: Motor causing Rx interference? - 1/19/2011 11:26 PM
saleens7
Score: 105
Status: offline
I could always try to find a second hand Tx/Rx from traxxas or something like that as well.
Hide Signatures
(in reply to carrellh)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
