Volfy
Joined: 1/4/2002 From: Houston, TX, USA Status: offline
[QUOTE]Originally posted by Geistware As far as the tail wheel, I removed part of the wheel bracket and mounted a 1-1/4 inch wheel. The one supplied is ridiculously too small! [/QUOTE] Geistware, that sounds like good idea to try. Do you have a picture of your setup? If it doesn't work out, I'll replace it with a CBA/Tatone leaf spring tailwheel bracket. I've used several of these on other planes. They may be a tad heavy, but man, are they indestructable! Chances are, I could use some tailweight anyhow, since I will be hanging a 60 Oz. Poulan 46cc on the nose, more than likely.
_____________________________
Si vis pacem, para bellum.
