Maudib
Joined: 7/16/2002 From: Ashland, KY, USA Status: offline
There is a plywood plate in there followed with solid balsa... I did as they recommended... just make sure you harden the holes with CA and let it CURE before proceding. The screws are pretty long and because there are 4 of them in each horn, I feel comfortable with them. AND you don't have those block of black on the top of the surfaces... It's personal preference tho... [QUOTE]Originally posted by Barry The control horns that come with Patty have what appears to be a mounting plate for the opposite side of the control surface to receive the screws. The instructions have you drill 1/16" holes and than use #4 wood screws, no backplate, don't go all the way through. What did everyone else who used the stock horns do? [/QUOTE]
