RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF
Page: <<   < prev  6 7 8 9 10 11 [12] 13 14 15   next >   >>
Login
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 3/20/2012 1:45 PM
bigwes1962
Score: 100
Last Login: 5/11/2013
Status: offline
mine are doubled
Hide Signatures
(in reply to n8622t)
       Post #: 276
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 3/20/2012 2:09 PM
Condor060
Score: 156
Last Login: 4/9/2013
Status: offline
I didn't get enought to be doubled. I received whats on the plane and three extras. Of course, if they sent a manual with the kit that might be helpful.
Still, the metal is so soft, you can fold them in half with your fingers with little effort.
Hide Signatures
(in reply to bigwes1962)
       Post #: 277
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 3/21/2012 2:03 AM
R/C Foolish
Score: 105
Last Login: 5/4/2013
Status: offline
So is Hobby King the only supplier of the 30cc version? Does that version come with oleo struts for the gear or just wire?
R/C Foolish
Hide Signatures
(in reply to Condor060)
       Post #: 278
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 3/21/2012 1:17 PM
ultra6a
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: R/C Foolish
R/C Foolish
The other supplier of the 30cc version is Giant Model Products. However, they are currently out of stock. The Hobby King version does not come with oleo struts and I can tell you from experience that the wire gear SUCKS!!!!!!
Hide Signatures
(in reply to R/C Foolish)
       Post #: 279
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 3/22/2012 11:59 AM
R/C Foolish
Score: 105
Status: offline
Has anybody flown or put together the 20cc version? How is quality?
R/C Foolish
Hide Signatures
(in reply to ultra6a)
       Post #: 280
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/7/2012 10:43 AM
Fisher SEA
Score: 100
Last Login: 5/22/2012
Status: offline
Hello,
I'm following this thread with a lot of interest (I'm a GeeBee lover!). I should order a 50cc version when restocking on GMP web site. As I understood, a lot of weight is needed on the nose of the plane for a correct centring. Like a lot of modelers, I don't like to add weight on my planes... So, the solution is to put a heavy monster engine. It's a bit disappointing to install a 80cc engine on a 81" plane...! Is there someone of you who has put a 50cc engine with some additional weight ? If yes, how many weight has been necessary for a correct centring ?
Thank you for your response,
Hide Signatures
       Post #: 281
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/10/2012 1:51 AM
grossy2
Score: 100
Last Login: 5/14/2013
Status: offline
I have the 50cc version. I'm running a GF55 II twin up front. I've had to mount the 2 A123 battery packs in the engine cowl. I fitted fiber glass extensions on the top of the firewall and fitted the batterys to them. They are sitting over the Cylinder heads. This works for me. The only issue I have with it is tracking. I think the fin is no big enough. I wants to crab all over the place. Your forever kicking it straight with rudder.
Cheers
Hide Signatures
(in reply to Fisher SEA)
       Post #: 282
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/10/2012 3:18 AM
gjhinshaw
Score: 109
Status: offline
Check the wheel pants. If they are off just a little....... the plane will crab!!
_____________________________
www.GiantModelProducts.com ,Team Hitec,
Smart-Fly, JetCat, Jet Central, Fly Eagle Jets
Hide Signatures
(in reply to grossy2)
       Post #: 283
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/10/2012 9:18 AM
Fisher SEA
Score: 100
Status: offline
Grossy, this is an interesting coment. I was also thinking to put a 50cc twin gas engine, why not the new DLE-60 ? I'm using Lipo packs only (still fighting against the weight ! [>:]) Positioning some lead on the spinner should allow to have a very limited additional weight.
Regarding Robart gears, any news ?
Hide Signatures
(in reply to gjhinshaw)
       Post #: 284
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/10/2012 10:00 AM
Fisher SEA
Score: 100
Status: offline
Oops... I mean some lead "inside" the spinner !
Hide Signatures
       Post #: 285
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/14/2012 6:04 AM
grossy2
Score: 100
Status: offline
What DLE-60?? Talk of it, but have not seen it!! The GF 55 Twin has more than enough power. Carefull with adding weight to the end of your crank shaft, can lead to other issues. Especially if anything is not running ture, or out of balance.
Re; Crabbing. It does it both ways. All depends on which way you are turing. I have a 97" Gee Bee senior with a DL-100 up front. The wheel spats are much bigger and no crabbing issues.
In my opinion, the wheels spats having nothing to do with crabbing.....
Hide Signatures
       Post #: 286
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/14/2012 2:30 PM
mikes68charger
Score: 106
Last Login: 5/19/2013
Status: offline
 I have the 30cc from GP Modles and I love it.  Put 11 flights on it this weekend and used up a whole gallon smoke fuel with a BME 50cc 22x8 prop
GPM has been there for me any time I needed anything Wich is way more than I can say for Hobbyking
My mods; put fuel tank almost over CG so I can fit smoke tank in, no lead, added hardwood blocks in wing to use 4-40 pull pull cables to keep wire gear strong 4.5 in tires. This bird will land nice and slow like my 540 Aroworks Edge just use rudder and keep the prop speed at 21-2200 and it's very graceful
Hide Signatures
       Post #: 287
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/14/2012 11:49 PM
Fisher SEA
Score: 100
Status: offline
Here are the new gas engines from DLE and DA, should be available for this summer:
- DLE 35R
- DLE 55R
- DLE 60 twin
- DA35
- DA100 twin inline
- DA70 twin
Regarding DLE 35R and DLE 55R, main changes are a new spark orientation (to the back) and the muffler connected to the back of the cylinder.
Putting some weight inside the spinner should be possible. The most important is to add a limited weight (no more than ~10oz) and keeping a good balance. In fishing hobby shops, we can find some cylindrical lead with a hole in the center (called "carp" or "watch" leads).
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to mikes68charger)
       Post #: 288
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 5/15/2012 2:19 AM
mikes68charger
Score: 106
Status: offline
If you need nose weight Vess and Hobbyking sell a balancing plate that gose outside the prop with a bunch of holes so you can put Allen cap screws to help get rid of vibrations
Hide Signatures
       Post #: 289
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/14/2012 6:43 PM
Sharpeye22
Score: 120
Status: offline
I finaly got back to my 30cc Gee Bee to work on the struts.  Here are some pictures of the progress.
1st pic just checking fit
2nd pic the lower anchor points for bracing wire
3rd pic it all layed out
4th pic checking again after strut tubes were cut to fit
5th pic the new bigger music wire bent and ready for upper anchor points
6th checking fit of new music wire.  I did not have to enlarge the wing opening at all.
7th pic doubled up on the shimming tubes for the attachment of the music wire to the robart struts tubes
8th pic checking fit for wing attachment
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Larry
Saito Club #692
Hide Signatures
       Post #: 290
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/14/2012 6:59 PM
Sharpeye22
Score: 120
Status: offline
and some more pictures.
9th pic fitting struts to wing
10th pic attaching lower anchor points to wire bracing
11th pic wing anchor points for wire bracing
12th pic fusalage anchor point for wire bracing.  I made the aluminum attachment that spreads the load from the 4 wires to the two blind nuts in the fusalage.
13th pic I found that the gear want to fold forward when the plane sits on them.  To solve this I made the aluminum braces you see going between the two struts.
14th pic all braced and ready for maiden flight.
I am going to deal with installing the paints after the maiden.  Meanwhile I am adding a layer of carbon vail and glass composite to strength them.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Larry
Saito Club #692
Hide Signatures
(in reply to Sharpeye22)
       Post #: 291
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/27/2012 5:48 PM
europatc74
Score: 100
Last Login: 4/4/2013
Status: offline
I have a question. I fly the 30cc. Needs a little repair work. Wonder what type red covering is used. Unlike monocoat,ultracoat oracoat which has a transparent adhesive, the original covering has a "white" adhesive backing to it. It is not a covering that needs to be pealed off. The adhesive is white. Any ideas? Thanks Dave. Sharpeye22, an incredable job constructing the struts. How do you intend to cover them. Copy originals in fiberglasss ?
Hide Signatures
       Post #: 292
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/27/2012 6:07 PM
Sharpeye22
Score: 120
Status: offline
 I will undo the assembly and reassemble them inside the original paints.  Right now I am reinforcing the paints like others have done with carbon vail and fiberglass.
Today I am bring it to the flying field to test taxi the plane.  If all goes well the next time will be the maiden.
Larry
Saito Club #692
Hide Signatures
(in reply to europatc74)
       Post #: 293
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/27/2012 7:46 PM
bigphil
Score: 100
Last Login: 5/9/2013
Status: offline
Hey Euro,
Gary says the covering is oracover. However, as you have noted, it does not have the white backing like the stock stuff does. I haven't found a perfect match but the Ultracoat Flame Red is pretty close. I used it to fix mine although without the opaque white backing it is not an exact match.
Big Phil
AMA 6762
Hide Signatures
       Post #: 294
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/28/2012 4:03 PM
gjhinshaw
Score: 109
Status: offline
I will contact them and see if I can get a 100 foot roll of thr red and white... So I will have some to sell, Sound good??
Hide Signatures
(in reply to bigphil)
       Post #: 295
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 7/28/2012 6:10 PM
Sharpeye22
Score: 120
Status: offline
 Sounds great!
Larry
Saito Club #692
Hide Signatures
       Post #: 296
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 9/30/2012 2:07 PM
TonyBuilder
Score: 143
Status: offline
 Has anyone thought of, or modified there Gee Bee with carbon fiber gear built into the fusalage? I know it's not scale but it is more functional. No wires needed, no struts, transport is easyer, setup is easyer. I did that with my 50cc lion after a few landings the wing mounted gear just gave out. I'm thinking of doing that with the Gee Bee.
TB
Fly, fly, fly!!!!
Hide Signatures
       Post #: 297
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 10/3/2012 6:27 PM
gjhinshaw
Score: 109
Status: offline
Do you have ANY pictures???
THE CONTAINER IS PAID FOR!!!  GMP WILL BE GETTING GB'S IN AROUND MID NOVEMBER!!!  THEY HAVE A LIMITED SUPPLY COMING IN!!!  BETTER PRE-ORDER YOURS BEFORE THEY ARE ALL GONE!
Hide Signatures
(in reply to TonyBuilder)
       Post #: 298
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 10/4/2012 3:50 PM
Mustangman40
Score: 181
Status: offline
hmmmmmmmm this plane has been calling to me for ahwile now, looks great and with the right power will fit the bill on speed.....
Ultra Sport Brotherhood #92
Hide Signatures
       Post #: 299
RE: Giant Model Products Introduces a 50cc GeeBee R3 ARF - 10/4/2012 4:57 PM
gjhinshaw
Score: 109
Status: offline
YEP...... Most are putting bigger engines in!  So a 30cc, put a 50cc in and a 50cc they are dropping in a 85cc!  SWEET SWEET POWER!!
Hide Signatures
(in reply to Mustangman40)
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.875RCU1
