RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
Page: <<   < prev  53 54 55 56 [57] 58 59 60 61 62   next >   >>
Login
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/22/2012 9:50 PM
kittykatjaz
Score: 100
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: RichardGee
Jaz,
Sorry for the delayed response...
The Flying Wire mounting bolts are 3mm.
Here are two pix:
Argh!!!
I took the no response as I was barking up the wrong tree and reading too much into it so I drilled them all to 4mm a few days ago.
Do you think that they are now all 4mm will be an issue?? The brass on the wire mount holes is a bit thinner now but still over a 1mm thick. I have had the wings on and tensioned since drilling them to see if they loosen up and it has held tension so far.
Just in the process of fitting the side hatch at the moment.
Hide Signatures
(in reply to RichardGee)
       Post #: 1401
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/23/2012 1:13 AM
RichardGee
Score: 105
Last Login: 5/22/2013
Status: offline
No harm... no foul!!
This now give you the opportunity to cut very short lengths of brass tubing and glue them into your flying wire mountiing holes in the wood blocks in the wing.
Do this now, and you will NOT have to do it later!!
You see, the extremely high tension and vibration of the flying wires makes the wooden holes OBLONG such that after some flying time, your flying wires will require tightening.
IF you line the holes with short lengths of brass tubing, it will prevent this from happening and your flying wires will remain perfectly tensioned, while the wing holes will NOT wear out.
_____________________________
The older I get, the faster I was...
Hide Signatures
(in reply to kittykatjaz)
       Post #: 1402
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/23/2012 8:27 AM
hannes83
Score: 100
Status: offline
My flying Wire mounting bolts are 4mm ;-)
Hide Signatures
       Post #: 1403
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/23/2012 8:32 AM
hannes83
Score: 100
Status: offline
Some more building pictures from Germany:
Hide Signatures
(in reply to hannes83)
       Post #: 1404
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/24/2012 7:00 PM
40GeeBee
Score: 100
Status: offline
What are those illuminum brackets on top of the landing gear struts, was that kitted or something you have added?
Hide Signatures
       Post #: 1405
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/26/2012 11:21 AM
kittykatjaz
Score: 100
Status: offline
Hi Guys,
Spent this evening with a new incidence meter checking the wires done by the previous owner and I have to de-solder and extend one lower hard wire plus replace the twisted braided wire on one side from the undercarriage to the fuse as it is way too short.
So some more questions.
I picked up a couple of the Benzomatic Nickel Silver brazing rods, do you think they would be ok for the wires? See photos for description.
How much of the soldered end of the wire would be safe inside the brass fitting? The one wire which needs extending has to come out around 3 to 4mm to get a safe bite on the threads.
As I have to replace one side of the braided wire, who would know of a suitable replacement without having to chase down a whole wire kit from CARF?
Jaz
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to 40GeeBee)
       Post #: 1406
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/28/2012 6:13 PM
hannes83
Score: 100
Status: offline
My new pillow, it´s real leather!
Hide Signatures
       Post #: 1407
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/28/2012 6:21 PM
rcnut101
Score: 100
Status: offline
That looks really good Hannes. You got me thinking of evolution radial as well. Im await your flight with new motor. Keep up the good work.
Hide Signatures
       Post #: 1408
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/29/2012 6:14 PM
hannes83
Score: 100
Status: offline
Some work today:
Hide Signatures
(in reply to rcnut101)
       Post #: 1409
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/31/2012 6:31 PM
rowdog_14
Score: 107
Last Login: 4/29/2013
Status: offline
Us little guys here are trying to get just one CompArf GeeBee and you have three of these bad boys. Nice work keep it up.
THE T.R.U.T.H
Hide Signatures
       Post #: 1410
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 12/31/2012 6:36 PM
hannes83
Score: 100
Status: offline
the Gee Bee is ready for the markings/decals**
Hide Signatures
(in reply to rowdog_14)
       Post #: 1411
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/6/2013 4:30 PM
hannes83
Score: 100
Status: offline
It was time to make PERFECT markings for the Gee Bee - we needed one week only for the computer work!!
Hide Signatures
       Post #: 1412
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/6/2013 10:14 PM
hannes83
Score: 100
Status: offline
Hide Signatures
       Post #: 1413
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/7/2013 5:50 AM
kittykatjaz
Score: 100
Status: offline
Hi Guys,
Could those who have completed the CARF Gee Bee post their final dry weight ready to fly?
Mine with the DA150 with KS Alloy canisters less additional weight to balance comes in 16.295kg  or 35.92lb.
To balance as is with the tail setup as standard, no pilot and all the batteries mounted directly to the back of the engine dome it will require an additional 700 grams of weight in front of the engine.
So I am going to move the switches and receiver forward in the fuse and lighten what I can in the tail. As well space the engine forward an additional 5mm which will not require mods to the canister exhausts. Even with moving this around and if I manage to get rid of the lead I cannot see this plane being 35 pounds or under.
The plan is to maiden the plane sometime in the next couple of weeks then order the graphics to finish it off.
Jaz
Click for fullsize
Hide Signatures
       Post #: 1414
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/7/2013 9:49 PM
hannes83
Score: 100
Status: offline
Some more:
Hide Signatures
       Post #: 1415
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/8/2013 7:29 PM
hannes83
Score: 100
Status: offline
Hide Signatures
       Post #: 1416
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/9/2013 12:05 AM
greatlakesgunny
Score: 100
Last Login: 4/12/2013
Status: offline
Nice touch
Hide Signatures
       Post #: 1417
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/9/2013 8:47 AM
brezel53
Score: 100
Status: offline
@Hannes: WOW -speechless-
There´s so much love and enthusiasm in your Gee Bees, especially in this one, i´m impressed!
I am afraid for this model, experience says, that the more you invest in an model airplane, the shorter is it´s life.....
Hate that, brake that, Hannes!
Best wishes,
Wolfgang
Hide Signatures
(in reply to greatlakesgunny)
       Post #: 1418
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/16/2013 7:44 PM
hannes83
Score: 100
Status: offline
Thank you Wolfgang, I do my best** :-)
Hide Signatures
(in reply to brezel53)
       Post #: 1419
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/16/2013 7:46 PM
hannes83
Score: 100
Status: offline
Here some new pictures from Germany:
Hide Signatures
       Post #: 1420
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/17/2013 5:57 PM
hannes83
Score: 100
Status: offline
The CHAMPION stickers arrived****
Hide Signatures
       Post #: 1421
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/17/2013 11:00 PM
invertmast
Score: 193
Status: online
Hannes,
Would you be interested / willing to provide a set of your decals for a 26.5% GeeBee R2? I've got everything necessary to finish my scratch built geebee except paint and markings, and would love to get a set of your markings from it.
Thomas
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 1422
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/18/2013 5:35 AM
hannes83
Score: 100
Status: offline
Hallo Thomas,
no problem, the markings are available at www.schaurich.de
Write a email to Dieter and order the stuff, he is the owner and will help you.
Hannes
Hide Signatures
(in reply to invertmast)
       Post #: 1423
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/18/2013 7:21 PM
invertmast
Score: 193
Status: online
Hannes,
Thanks!
Thomas W.
Hide Signatures
       Post #: 1424
RE: Composite-Arf 33% Gee Bee R2 - First Flight - Pics ... - 1/24/2013 9:48 AM
hannes83
Score: 100
Status: offline
The way to cool the radial down***
Hide Signatures
       Post #: 1425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
